Speccy - наш выбор!
-   -   Сборка Пентагон 128к (http://zx-pk.ru/showthread.php?t=12993)
Shockwav3 11th February 2013 11:46
@andy150677: it works "mostly fine" in 48k mode, but still crashes there occasionally. TRDOS usually crashes within seconds. I'll try to get a RAM Test ROM soon. Sadly I only have 41256 RAMs to test, but will try to order 4164 ones if the problem persists.
Scheme for connecting the Pentagon to my TV is just the ordinary one, R, G, B on the corresponding pins + Sync on pin16 (blanking), ground for r_ground, g_ground, b_ground, shield and blanking (pin18). Didn't use any amplification as shown in pentagon.pdf (470ohm -> kt315b/bc547 -> 75ohm -> scart socket for R, G, B & Sync), since it didn't make a difference on my TV
zorel 11th February 2013 15:38
1 Attachment(s)
Shockwav3, And if you connect to another TV, the picture is the same?
There is an oscilloscope or frequency? Need to see what's on the input - output meter DD11, DD12,
If it's a manual for the assembly, transfer to translate.google.com.ua
andy150677 11th February 2013 18:34
zorel, нашел фотки, которые при сборке делал. Там мало что изменилось - только кондеры, которые навесным напаяны, по-человечески припаял, и для второй линейки ОЗУ блокировочных поставил на обратной стороне. В любом случае - не стало ни лучше, ни хуже.
http://i54.fastpic.ru/big/2013/0211/...30da421e2f.jpg
http://i54.fastpic.ru/big/2013/0211/...2ed41250a3.jpg
http://i54.fastpic.ru/big/2013/0211/...6ea8a3f0b8.jpg
zorel 11th February 2013 19:17
1 Attachment(s)
сигнал на +5 посажен через кондер.
andy150677 11th February 2013 19:22
Оптическая иллюзия :)
На самом деле это блокировочный кондер, он впаян в шины питания, переходное отверстие посередине не затронуто.
Shockwav3 12th February 2013 03:40
Turned out I had C7 connected to an incorrect via (PCB print is slightly confusing there), which seems to have fixed the random RAM garbage appearing on screen (yay). Sadly the machine still seems to be slightly unstable (crashes in TRDOS after 5-10 seconds and after roughly a minute in 48k basic) and the SYNC still isn't working correctly, but we're getting there :)
zorel 12th February 2013 05:05
Need to check the meter DD11, DD12, frequency counter or oscilloscope. And check out the Pentagon on a second TV.
Shockwav3 19th February 2013 00:30
Just as a little follow up: I've built my second Pentagon and it has exactly the same issue :(
I have pretty much tripple checked everything by now and used the Pentagon with another tv (even tho the tube TV I first used works fine with my Pentagon1024SL) ... I'm starting to get a little frustrated since I don't have access to an oscilloscope/frequency counter.
Could my failing RGB signal come due to me using a 74ls37 (555ЛА12) instead of a "real ttl" 7437 155ЛА12 for D72 ... wikipedia said they "should" be compatible?
solegstar 19th February 2013 01:31
Originally Posted by Shockwav3 (Post 574858)
Same goes for the quarz Q1, depending on which scheme I use I get values 14Mhz (which I used) or 14.3Mhz
try quartz on 14.3 MHz, with it the vertical sync has to be 50 Hz. if you use quartz on 14 MHz, vertical sync is 48.9 Hz. Probably in it a problem.
Shockwav3 23rd February 2013 16:13
Okay, I got my RGB issue sorted out :)
Silly me used a Scart Female plug to connect a 1:1 scart cable which meant I had to connect RGB_Sync to Pin 19 instead of 20 :v2_rolley
Shockwav3 24th February 2013 19:45
And another one ...
I've started soldering my second Pentagon, sadly it won't even start. For the ease of debugging I'm not using a ROM. Various decoupling capacitors have been placed on the board already. I'm roughly seeing the bands I should get, but they're randomly changing color between red and blue character wise.
ICs 37, 39, 38, 40, 41, 42 & 46 have been checked already. RAM has been verified as good and the problem remains consistent between 2 different sets I'm using.
A video of the problem can be found here:
http://youtu.be/mipe27poaZY
Shockwav3 3rd March 2013 00:58
Good news everyone :)
The Pentagon is working - it loads programs and plays music :)
I'm still having 2 minor issues with the video (minor "ghosting" on my LCD TV) and for some reason I can only access drive a: in TRDOS, but for now I'm happy it is working nicely.
short note about decoupling: apart from the RAM chips, I didn't have to decouple any additional chips.
EDIT: For some reason I can't find out what's wrong with the "ghosting" which seems to apply to both TVs I'm using. It always looks like some attributes/characters are embosed.
Here's a picture of how it looks like with the "bugs" being highlighted ... sadly the picture isn't every good since my camera sucks.
http://img40.imageshack.us/img40/637...buteembose.jpg
Scart is connected at a minimal approach: R, G, B & Sync on their corresponding pins + ground and 3V on Pin16, no 75Ohm resistors or transistors (tried that which only seems to make it worse)
Shockwav3 8th March 2013 01:40
Could you help me with the Kempston interface on the daughterboard?
I can't make out for sure where the pins for the directions and fire are.
http://img5.imageshack.us/img5/9717/vfghf.jpg
null_device 8th March 2013 02:39
Part of the circuit which implements the interface joystick. There are two options. Fire - or 8 output chips, or 11.
Not rule out that wiring is faulty (or just very specific divorced).
solegstar 8th March 2013 02:51
Shockwav3, my advice, just load the game and run with selected kempston-joystick option, then try to connect unknown pins IDC10 to GND and see what happen on screen.
Shockwav3 8th March 2013 02:59
Yes, I've already checked the board against the scheme. While the Pins for left (13) and right (11) are obvious, the other pins connect to legs 4, 6 and 8 on the chip :(
solegstar 8th March 2013 03:12
it isn't important as inputs are connected, the main thing that was compliance an input output of AP3 and were connected to appropriate bits of the data bus. 1533AP3 (SN74ALS240) is 8-bit data bus tranciever with inverted outputs.
Evgeny Muchkin 8th March 2013 18:37
Небельмеса
Mdesk 8th March 2013 19:53
1 Attachment(s)
I have checked wires on the PCB:
Shockwav3 8th March 2013 23:12
I've soldered a D-Sub 9 port as described, but for some reason it does not work.
When using "10 PRINT IN 31;:GO TO 10" in basic for testing I get a constant value of 255. It doesn't matter if I have a joystick connected or not.
Mdesk 9th March 2013 00:54
1 Attachment(s)
Symbols of diodes VD3 - VD5 are misdirected on the picture of this PCB for 1N4148 diodes. Cathodes of all diodes must be connected to pins 1, 19 of DD7:
Shockwav3 9th March 2013 01:16
I think I read that somewhere before, which is why they're connected opposite of the pcb prints on my board. 1n4148
EDIT3: We're getting there, adjusting the R11 with the faulty value of 1k-Ohm to 1m-Ohm allows me to access TRDOS and _randomly_ the Joystick (Test program returns values like 00000255255255, etc.)
EDIT4: It's working :) Bypassing the diodes and sending /OIRQ, /RD and A5 through OR-Gates as shown here (http://8bit.yarek.pl/hardware/zx.joystick/kjschem.gif) the kempston Joystick works along with TRDOS access.
Maybe that's something that could be fixed on the next Revision of the board?
Shockwav3 15th March 2013 15:37
2 Attachment(s)
In case anyone of you wants to build the Turbo extension on breadboard, I've made a soldering plan for myself, which I thought I could share with everyone.
Leftmost ICs are TM2/74 while the right one is ЛА3/00, other values are according to the scheme (1n4148, 1k Ohm, 100pF). The board itself is designed to be as compact as possible with the wires going over the top layer being as short as possible
Could anyone of you also be so nice and translate what the other text says?
EDIT: appears the soldering plan I uploaded was resized ... here's a bigger version: http://img854.imageshack.us/img854/3409/penturbo.png
Evgeny Muchkin 16th March 2013 00:00
Мля! НЕБЕЛЬМЕСА, В НАТУРЕ! :)
solegstar 16th March 2013 01:34
Shockwav3 , whether you can attached the original schematic diagram?
Shockwav3 16th March 2013 02:17
Sure ... it's included in pentagon.pdf tho.
http://img543.imageshack.us/img543/9972/turbos.png
Andrey F 16th March 2013 12:13
http://www.translate.ru/
Mdesk 18th March 2013 16:50
Shockwav3 попросил перевести текст со схемы Турбо доработки Пентагона 128.
Modifications on the computer's PCB.
1. Disconnect DD5-2 and DD13-28 from their circuits.
2. Disconnect DD15-1 from the +5V circuit. Connect DD15-1 with the ~RFS circuit (DD13-28).
3. Disconnect DD13-6 from DD1-8, but keep the connection of DD13-6 with the pull-up resistor.
UA3GBV 19th March 2013 20:17
Опять здравствуйте, теперь вот вопрос по контроллеру дисковода. Напомню, плата от Zorel`а, крайней серии. Такая картина. Есть три 3.5 дисковода, два новых, один начала 90хх, все проверены на 286'м. На прямом шлейфе каждый определяется диском "С", т.е. A> *"C", затем
O.K.
C>
На этом признаки жизни заканчиваются, при команде FORMAT короткое движение башки и полное зависание, только двигатель крутится. При команде LIST - стандартная ошибка, abort, ignore и т.п.
На перевернутом шлейфе определяется, как диск B, точнее только жужжит башкой, O.K. нету.
ВГ93 менял, ЛП9, ЛП11 рабочие. Куда курить надо, где методики настройки почитать? BDI впервые налаживаю.
Спасибо =)
solegstar 19th March 2013 22:10
UA3GBV, если есть в наличии дисковод 5.25 (всё равно какой, хоть 1.2Мб лишь бы у него была установлена резисторная матрица), для начала экспериментов попробуйте его посадить на один шлейф с дисководом 3.5, только выставьте его (5.25), как А, если всё заработает, то нужна подтяжка к +5В, через 1кОм резисторную матрицу, выходных буферов с "открытым коллектором" контроллера дисковода.
lisica 20th March 2013 01:13
Помоему 3.5 дисководы изначально подтянуты к +5в...
null_device 20th March 2013 04:57
В перую очередь - заклеить "окошко" плотности на дискете (если дискеты НD).
lisica 20th March 2013 11:11
Это странно. С ИД4(D98) и ТМ9D88) всё в порядке? Не попутал местами ЛН3 и ЛП9?
null_device 20th March 2013 12:31
У меня такая же история была со старой платой пентагона. Имела место ошибка разводки - шины "выбора" дисководов "В" и "С" перепутаны местами.
UA3GBV 22nd March 2013 20:17
Спасибо, за ответы, но как-то дело не продвинулось. Дисковод определяется нормально, любой, при попытке чтения - закономерная ошибка, глохнет опять-таки при форматировании. Отсюда вопрос - а на каких микросхемах можно отследить процесс форматирования? Он аналогичен процессу записи, т.е. задействется Д96(ИР16)? На н10D96 вечный ноль, на 2нД88 (ТМ9) - 1 при бездействии, 0 при любом обращении к дисководу, на 5,7,10нД88 1 всегда. Перед запайкой все микрухи проверялись, естессно )
lisica 22nd March 2013 20:25
Форматирование это запись разметки диска, так что D96 должна работать и при этом процессе на 10н D96 должен быть сигнал.
Просмотри сигналы до D96 и проверь D94 (может замкнуть выход D96) Так же просмотр этой дороги на непротрав.
null_device 22nd March 2013 20:28
UA3GBV, логику работы бета диска, и методику проверки - можно почитать в книге периферия своими руками. Довольно подробно и детально описана проверка работы узлов типового контроллера BDI.
UA3GBV 22nd March 2013 22:14
На Д96 приходят синхра на 9-ю ногу и сразу после ввода команды формат - две пачки импульсов на 6-ю ногу. Но на выходе тишина... Может и дохлая, сил выпаивать уже нету...:v2_dizzy_messed:
lisica 22nd March 2013 23:01
Originally Posted by UA3GBV (Post 585744)
Может и дохлая,
А может и выход глушит ЛН3 или замыкание?
---------- Post added at 21:01 ---------- Previous post was at 20:59 ----------
Попробуй аккуратненько 10ю ногу D96 поднять над платой и проверить выход.
UA3GBV 22nd March 2013 23:24
lisica, ненене, все буферные микросхемы на панельках стоят, ЛН3 в том числе. Проверял и без нее. Замыканий нет, выпаивания не избежать.
