Speccy - наш выбор!
-   -   MultIDE (http://zx-pk.ru/showthread.php?t=15535)
Black_Cat 11th May 2011 15:12
Originally Posted by vlad (Post 383863)
3-ри вывода выделить для I2S DAC для проигрывания MOD`ов. Ну или Soundrive докрутить с выходом на I2S DAC...
ЦАПов точно не будет, ибо не звуковая это карта, а мысль про связь DMA и I2C попрошу объяснить подробней, как ты это представляешь
vlad 11th May 2011 17:10
I2S а не I2C :) http://en.wikipedia.org/wiki/I²S
Black_Cat 11th May 2011 18:07
vlad, я спрашивал как ты представляешь DMA
VELESOFT 11th May 2011 21:24
Originally Posted by БК-0010 (Post 383835)
можно - переписать софт под divIDE
3 WAYS:
1) Yes. Rewrite ports in DIVIDE systems enable full compatibility with old russian devices. But all new software must be rewrited for this ports :(
2) Or implement only DIVIDE memory with NEMO IDE ports (need modification of DIVIDE software, but can be used on other russian ZX clones for software with NEMO IDE drivers.
3) Add software/hardware switch for enable/disable DIVIDE ide ports.
VELESOFT 12th May 2011 01:41
1 Attachment(s)
I change adress of ide ports in DEMFIR 0.5b. In equations of A_GAL chip must be change this two lines:
Code:
ideio0        = A0*A1*/A2*/A3*/A4*/A5*A7
ideio1        = A0*A1*/A5*/A6*A7
After this modification will use this IDE ports adress: 110xxx11
And adress of DivIDE control register is 11000011 (dec 195)
This ports is compatible with GENERAL SOUND :) but incompatible with some Kempston mouse versions :(
In attachment is BIN file for DIVIDE rom 8kB.
next info about DEMFIR:
- use 128kB memory paging via LD A,64+16+page : OUT (253),A then used ZX clone must on adressation of port #7FFD detect A15-A14 and A13-A8 must be ignored !!!
- use software detection of 128kB memory page then run correct only on 128kB models or if 128kB mode is set (on Pentagon computers must be memory set to 128kB mode (set lock D2 on port #EFF7).
Black_Cat 12th May 2011 01:47
Originally Posted by VELESOFT (Post 384088)
set lock D4 on port #EFF7
D2 #EFF7
D4 is a TURBO
VELESOFT 12th May 2011 01:52
Originally Posted by БК-0010 (Post 384089)
D2 #EFF7
D4 is a TURBO
Sorry, D2 is correct :)
Black_Cat 12th May 2011 01:57
Why?
VELESOFT 12th May 2011 02:02
Originally Posted by БК-0010 (Post 384094)
Why?
Original ports are unusable with GS (same ports)
Black_Cat 12th May 2011 02:04
zst, изменения в схеме: вместо HCT245_1 будет HCT373, при этом на ПЛИС надо завести с неё оба сигнала управления! Т.е. ещё минус 1 нога. И вместо АП5 будут две 555КП11
AY_CLK - выбрасывай, на каждой рассыпушной плате он есть
Итого 8-1+1=8 ног в запасе.
