Question about Orel bk-08
Hello it's my first post here I hope I poste it in goos section.
I have a Orel bk-08 since some week I like this computer and I would know if is it possible to connect a divide on it? I know the expansion bus is not in the same format but with a little chance with an adapter it will works. If it's doesn't I think I need found a beta disk interface cause tape loading is verry long and not verry stable. Thank you in advance for your help. Galine. |
Wiring Diagram http://zx-pk.ru/showthread.php?t=158...EE%F0%E5%EB%FC ---------- Post added at 21:48 ---------- Previous post was at 21:45 ---------- That's where I put the scheme eagle redraw itself, it is possible that there are errors in the diagram .. http://zx-pk.ru/showpost.php?p=362739&postcount=127 |
really thank you I will see that I forgot to ask if the Betadisk is compatible with the HXC?
I think I can answer to this topic http://zx-pk.ru/market/viewtopic.php?f=4&t=1013 maybe I'm to young here for it?
Hummm... sometimes I'm not waken up thank you again ^^.
it's a verry good news for The HXC.
In my research for have a "mass storage" solution for the Orel I fond this verry interesting pieces of hardware http://bk-evo.perestoroniny.ru/page/...eplika-smk-512 but this last seems discontinued. -_-. |
You can check local clone of divide http://zx.pk.ru/market/viewtopic.php...719fa3a0f1f648, but Betadisk is better |
| All times are GMT +4. The time now is 00:49. |
