Speccy - наш выбор!
-   Софт (http://zx-pk.ru/forumdisplay.php?f=10)
-   -   Fatall (Фаталл) - копировщик для HDD/SD (http://zx-pk.ru/showthread.php?t=7238)
VELESOFT 20th March 2010 16:31
I reformat same CF to FAT32 and copy trd+scl files to root directory. Enter and exit from SCL is correct. Enter to TRD - OK, exit from TRD incorrect....(after press enter on line signed as ".." is blue clear window with message DISK EMPTY. If press enter to any file in TRD image then in right window is chaotic chars.....
I reformat same CF card 256MB to FAT32 with clusters 512bytes:
- SCL work correct
- after enter to trd ZX blocked or show incorrect characters(chaos). Exist from trd = same chaos.
After reformat to FAT32 with clusters 512bytes,1kB,2kB is same problem. 4kB clusters is impossible use for small medium 256MB. Result: on CF 256MB is impossible work correct in FATALL if FAT32 format is used.
savelij 20th March 2010 16:40
Выход из TRD образа возможен при нажатии на любом файле, а не только на ".."
Выложи сюда TRD образ с которым происходит некорректный выход из образа.
VELESOFT 20th March 2010 16:42
I test also next small CF cards, HDD, SDtoIDE adapters with SD/MINI SD and MICRO SD cards from 64MB to 8GB formatted as FAT16 and FAT32 with different cluster sizes, partitions, etc...
Is possible in FATALL delete files ? :v2_conf2:
savelij 20th March 2010 16:52
Удаление пока невозможно из-за отсутствия таких функций:( Еще много нюансов с тем что уже есть.
---------- Post added at 15:52 ---------- Previous post was at 15:47 ----------
В каком эмуляторе с divide и образом винта можно запустить fatall для проверки?
VELESOFT 20th March 2010 19:33
DIVIDE interface is emulated in ZX emulators: SPIN, FUSE, SPEC EMU, EightyOne. But DIVIDE interface = IDE ports + extrernal rom and ram memory. Emulators enable only full DIVIDE emulation with extra memory and disable parallel emulation of TRDOS :v2_mad:
But I can create image of my CF card and test it in emulator UNREAL SPECCY with NEMO IDE support :v2_wink2:
Where can I find a utility for creating image of CF for UNREAL ? ( *.HDD )
VELESOFT 20th March 2010 23:38
This is HDD image of my CF card 256MB with FAT32:
http://velesoft.speccy.cz/other/cf25...t32-fatall.zip
(*.HDD file for using in UNREAL SPECCY emulator)
savelij 21st March 2010 00:14
Проблема есть. Малый размер буфера для кластеров при открытии файла когда размер кластера=размеру сектора. Уничтожаются переменные фат драйвера.
VELESOFT 21st March 2010 19:11
But I test it with FAT32 formatted with cluster size 512bytes, 1kB and 2kB. This is maximal cluster size on FAT32 for 256MB medium. :v2_confu:
Next test with CF 512MB - FAT32:
cluster 512bytes - error
cluster 1kB - error
cluster 2kB - error
cluster 4kB (it's maximal length of clusters for FAT32 on 512MB medium) - all work correct !!!
CF 512MB - FAT16
cluster 8, 16 and 32kB - all work correct !!!
Ewgeny7 21st March 2010 21:03
Нашел программу для издевательств над CF/SD, называется Paragon Partition Manager. Очень понравилась :)
Но Фаталл, видящий диск на НемоХДД, упорно не видит файла Fatall.C$.
При этом, если Фаталл запущен, то по флешке он лазиит нормально.
Что удивительно, WDC 1.3 умудрился инсталлироваться на CF, и теперь прекрасно стартует и работает с флешки...
savelij 21st March 2010 21:26
Так я тебе про нее и говорил что может сделать более 1 раздела на флеши и писюк потом дает доступ только к первому разделу ;)
---------- Post added at 20:26 ---------- Previous post was at 20:25 ----------
А что значит не видит?
