I know what you mean, but coding for speccy on PC has no poetry for meI wanted to edit alasm sources on PC only in the work, when I get ideas from time to time. Otherwise, here in the Czech Republic we use only real machines, mainly 128s or +2 or +2A original machines by the Sinclair Research. It has a real poetry to sit at their keyboards.......
But thanks for answers anyway. I think, I will write my code on PC in TXT and then easily import it on speccy in Alasm.
Hood
anyway you get exactly the same machines codes as a result
Ответить с цитированием
