Страница 4 из 13 ПерваяПервая 12345678 ... ПоследняяПоследняя
Показано с 31 по 40 из 130
Тема: ZX HID Keyboard Controller
  1. #31
    Praha
    34
    15 сообщений
    If you press cursor key during keyboard test routine in zx rom then basic can show only NUMBER without SHIFT. I have small documentation about it from Czech HW guru, but in czech language :-(
    For example if you will after press BREAK active CAPS SHIFT + SPACE parallel (in same time) then at 0.57 % basic return only SPACE without SHIFT.
    If any software will often call keyboard reading then problem with ignore CAPS SHIFT will very very high and SHIFT combined keys will total unstable.
    LOOP:
    CALL #28E
    ... your routine
    JR LOOP
    Result:
    CAPS SHIFT must be active minimum 400T (400T cpu at 3.5MHz) before active KEY. But 400T is not 100% methode, because some software (games) use own keyboard routines. Then longer time of SHIFT activity is best.
    May be 3500T CPU or similar value.
    Example of press cursor key LEFT:
    1) user press cursor key LEFT on PC keyboard
    2) ZXHID interface active only CAPS SHIFT (3500T CPU is active)
    3) ZXHID interface active key "5" (now is key 5 and SHIFT both active)
    4) after release cursor key LEFT must ZXHID deactive both keys.
    info about basic:
    keyboard routine in basic is called each interrupt (each 70000 T cpu) and routine for testing keyboard takes 400 T cpu. If user press cursor key out of interrupt routine then all is ok and zx rom detect SHIFT+KEY. Keyboard routine at begin test CAPS SHIFT and here is problem. You can press cursor key in this routine but after SHIFT test. Then routine not see SHIFT and read only KEY. Brobability of error is 0% if you press keys before call keyboard routine and very high during running keyboard routine.
    I test it in zx emulators on PC (emulators active shift in same time as keys) and also here is problem. During first 100 clicks I see bugs.
    1 PRINT INKEY$; : GOTO 1
    This program very often read keyboard and show code of key. Please press and release repeatedly(500x) cursor key RIGHT. If you see number "8" then zx rom detect only key "8" without shift = error.
    Последний раз редактировалось VELESOFT; 03.02.2015 в 03:32.
  2. #31
  3. #32
    Чайковский
    26
    9 сообщений
    Обновил архив. Изменен загрузчик и ZXHIDKeyboardLayout,
    поправлена прошивка PICa т.к. нашел клавиатуру, которая
    вместо 6 байт отправляет 10 байт репорта.
    В ZXHIDKeyboardLayout было найдено несколько неправильных кодов клавиш
    в расширеных кнопках, а так же начал делать более универсальный загрузчик
    для PIC24 с разным обьемом памяти, поэтому и обновил.
    В архиве ZXHIDKEYBOARD ext файлы для расширенного варианта клавиатуры,
    но проект не законченный, прошивку проверял через терминал.В железе в связке с альтерой не проверял, схема примерная, чтобы показать как связаны ALTERа и PIC.
    Далее развивать не буду, если только ошибки исправлять.
    Profi v3.2 (SIMM 1024kB, Color CP/M, Turbo VG)
    Profi v3.2 256kB + PAL coder
    Плата ZXM Phoenix 1024kB + VGA converter
    ZX Evolution 4096kB + SSD-1Gb
    Плата Speccy 2010
    Плата Sprinter Sp2000s
    Плата Reverse U9 EP3C
    Плата Reverse U10 EP3C
    Плата Reverse U16 EP4CE22
    Плата Mist v1.31
    Terasic DE1
    Terasic DE1-SoC
    Terasic DE10-nano
    iCore 3
    г. Одесса, Украина
    64
    33 сообщений
    Платки никто не делал под это? Ткните.. а то поиском не нашел.
    С Уважением, Андрей!
  5. #34
    г.Киров
    Данный контроллер установлен на плате Scorpion 1024 rev.2015
    Какой алгоритм прошивки МК ?
    http://zx-pk.ru/showthread.php?t=162...961#post840961
  6. #35
    Чайковский
    26
    9 сообщений
    А где посмотреть схему Scorpiona?
    Плата Speccy 2010
    Плата Mist v1.31
    Terasic DE1
    Terasic DE1-SoC
    Terasic DE10-nano
    iCore 3
    г.Киров
    https://yadi.sk/d/y2emq2GokPUAW вот тут схема + монтажка.
    Просьба прямо по пунктам ,как правильно прошить МК.
  8. #37
    Чайковский
    26
    9 сообщений
    Порядок прошивки встроенного в Скорпион контроллера
    перенес в тему:http://zx-pk.ru/showthread.php?t=162...l=1#post842970
    Последний раз редактировалось Anykey; 22.11.2015 в 19:29.
    Плата Speccy 2010
    Плата Mist v1.31
    Terasic DE1
    Terasic DE1-SoC
    Terasic DE10-nano
    iCore 3
    г.Киров
    Такой программатор подойдёт?
    http://ru.aliexpress.com/w/wholesale...t2&needQuery=n меня смущает,что там 6 пиновый коннектор,на разъёме Х19 5 выводов....AUX отсутствует.
    Последний раз редактировалось Felix_73; 11.11.2015 в 21:20.
  10. #39
    Чайковский
    26
    9 сообщений
    Я думаю подойдет, если аналог.
    Есть куча других программаторов под PIC,
    но надо смотреть поддерживает ли конкретно PIC24.
    У PicKit 6ой вывод используется для других целей,
    в программировании он не участвует.
    Последний раз редактировалось Anykey; 11.11.2015 в 21:27.
    Плата Speccy 2010
    Плата Mist v1.31
    Terasic DE1
    Terasic DE1-SoC
    Terasic DE10-nano
    iCore 3
    г.Киров
    Да,PIC24 есть в списке поддерживаемых устройств.
    А какие и где посмотреть другие программаторы под PIC?
    Последний раз редактировалось Felix_73; 11.11.2015 в 21:51.
  1. Test your PC keyboard
    от VELESOFT в разделе Устройства ввода
    Последнее: 22.03.2014, 23:34
  2. Enchanced A1200 Keyboard Controller
    от Titus в разделе Amiga
    Последнее: 24.05.2011, 20:26
  3. HD-Controller
    от BYTEMAN в разделе Amiga
    Ответов: 16
    Последнее: 09.04.2009, 20:37
  4. AT KEYBOARD INTERFACE
    Последнее: 28.11.2007, 17:51
  5. Amiga Keyboard
    от breeze в разделе Устройства ввода
    Последнее: 14.09.2007, 16:54
