Показано с 1 по 8 из 8
Тема: MEMORY PAGING IN LOW 16kB
    Master Аватар для VELESOFT
    Praha
    33
    14 сообщений
    По умолчанию MEMORY PAGING IN LOW 16kB
    On modern FPGA/CPLD based russian ZX clones is possible without hardware modification
    implement ram memory paging also in low 16kB as rom replacement. This memory extensions
    is often used on some interfaces for ZX Spectrum computers.
    For example:
    MB02+ interface
    Can replace low 16kB rom with battery backup sram 512kB used as 32 memory pages.
    On paging port is possible enable or disable writing to low 16kB (software write protect for
    best protection/rom emulation)
    paging port MB02+ (#17)
    D0-D4 = memory page number 0-31 (sram or eprom)
    D5 = write enable (1=write enable / 0=write protect)
    D6 = sram enable (1=disable ZX rom and connect MB02 sram)
    D7 = eprom enable (1=disable ZX rom and connect MB02 eprom)
    (if D6=0 and D7=0 then MB02 memory is disabled)
    (if D6=1 of D7=1 then MB02 sram or eprom is connect)
    (if D6=1 + D7=1 then paging port is set to %10000000 (erom page 0+write disable)
    After press NMI must CPU jump always to adress #66 in low 16kB (if MB02 memory is connect
    then NMI jump to MB02 memory)
    Some siminar ZX interfaces use also low 16kB memory paging with selectable writeprotect.
    You need only external sram (eprom contain olny boot rom for loading DOS from hdd/fdd)
    Also DIVIDE PLUS interface use MB02+ compatible memory. Or my MB02 memory interface for ZX:
    http://velesoft.speccy.cz/prodej/prodej4/mb02-mem.htm
    If this (or any similar) memory paging will possible on russian ZX clone, then will possible use
    system RESIDOS with full FAT16 support, BS-DOS system from MB02+ and more other software
    (theoretically also FATWARE and DEMFIR systems form DIVIDE interface). Actually is ram in low
    16kB used in ZX clones as CACHE sram in size 16 or 32kB. This is very small for implement any
    big system and absent software writeprotect feature.
    Is possible on russian ZX clones (Pentagon 1024/ATM turbo) ignore trdos paging and connect
    external memory to low 16kB ?
    - external interface connected to ZX-BUS disable internal roms in ZX clones
    - low 16kB is replaced with external sram memory
    Is it possible ? If on port 7FFD is set 48rom + is connect external sram in low 16kB + cpu jump
    to adress #3Dxx ...... Will TRDOS connect ??
    Последний раз редактировалось VELESOFT; 05.09.2009 в 15:11.
    Veteran
    Dnepropetrovsk
    47
    31 сообщений
    Of course it is possible, and it was done in many ZX clones since 1990! For example, such ZX clones as "Robic" (made at Selto-Rotor factory, Cherkassy, Ukraine), or "Orel BK-08" (made at DMZ factory, Dnepropetrovsk) all had a possibility to activate RAM in lower 16K of memory. All later popular russian ZX clones, including "Profi", "ATM-Turbo", possibly "KAY-256" and "Scorpion ZS-256" also have a possibility to activate RAM in lower 16K. Such ZX clones were therefore also able to run CP/M.
    Unfortunately, there is no common standard for such "shadow RAM" system. The best way to design modern software is to make some hardware abstraction layer and let the people develop driver plugins with entry points to activate or deactivate lower 16K RAM. Some systems also had multiple RAM pages which could be paged into the lower 16K of Z80 address space. Or, in the simpler case, one could have just 4 values to type in the program configuration, such as:
    Out(port1),val1 activates shadow RAM
    Out(port2),val2 deactivates shadow RAM
    One good example of system with hardware abstraction layer is IS-DOS which, under certain circumstances, uses shadow RAM and lets the user configure the above mentioned 4 values.
    When the shadow RAM is activated, TR-DOS is usually disabled and does not activate its ROM or ports when code at location 3D00-3DFF is executed. This arrangement allows for proper functioning of CP/M.
    Praha
    33
    14 сообщений
    This is ROMCS connection on real ZX Spectrum/Timex/Didaktik computers:
    This connection enable connect external memory.
    And this is russian connection on Pentagon 1024SL:
    Is impossible connect to this ZX-BUS connector any old ZX interface with external memory. This interfaces must be modified for work on russian clones. (can connect external memory only if in low 16kB is set rom - external interface set signal /RDROM to log.1).
    ---------- Post added at 12:07 ---------- Previous post was at 12:05 ----------
    Exist any russian interface with external memory mapped on rom area ?
    Последний раз редактировалось VELESOFT; 05.09.2009 в 22:13.
    Banned Аватар для Black_Cat
    S.Pb
    Цитата Сообщение от VELESOFT Посмотреть сообщение
    MB02+ interface
    MB02 + controller is not needed for exUSSR computers. For exUSSR computers easier to use a management system based on the basis of their own standards.
    ---------- Post added at 20:57 ---------- Previous post was at 20:21 ----------
    Here's an example of a promising management system for exUSSR computers:
    r/wCPU0 MANAGETMENT:
    |D0#1FFD|D3#EFF7
    |_0 _____|_0 - rdROM
    |_0 _____|_1 - rdROM & wrRAM
    |_1 _____|_0 - r/wRAM
    |_1 _____|_1 - rdRAM
    Adressing ROM in CPU0:
    A14"ROM - D4 #7FFD
    A15"ROM - D3 #1FFD
    A16"ROM - D2 #1FFD
    A17"ROM - D6 #1FFD
    A18"ROM - D5 #1FFD
    Adressing RAM in CPU0:
    #9FFD CPU0(#0000-#3FFF) WINDOW PORT
    D0 - A14'RAM
    D7 - A21'RAM
    Последний раз редактировалось Black_Cat; 05.09.2009 в 21:19.
    Praha
    33
    14 сообщений
    Yes I know. I russia is supported only trdos. But implementation memory paging (big cache sram) in low 16kB will open way to ported some systems from ZX Spectrum to russian machines. Modern ZX clones use 1-2MB memory. FPGA based clones with faster CPU use also ram in low 16kB for rom emulation. FLASH EPROM is after start copied to extended memory and writeprotected ram is connect to low 16kB (EPROM is too slow for fast CPU modes). If 128kB memory is extended to 1-4MB why can't be extended also russian cache sram to more than 16 or 32kB ? This don't need any hardware modification on FPGA clones and Garry Lancasted can ported RESIDOS to any ZX clone with low 16kB ram paging (but need also selectable writeprotect) and IDE ports. System in low 16kB can access to full ZX memory. For example is possible use modified ZX48 rom with TAP traps - tape emulation.
    |D0#1FFD|D3#EFF7
    |_0 _____|_0 - rdROM
    |_1 _____|_1 - rdRAM
    Only one 16kB ram page ?
    A14"ROM - D4 #7FFD
    A15"ROM - D3 #1FFD
    A16"ROM - D2 #1FFD
    A17"ROM - D6 #1FFD
    A18"ROM - D5 #1FFD
    Also on new ZX clones ?
    D0 - A14'RAM
    D7 - A21'RAM
    What ZX clones use this mode ?
    Последний раз редактировалось VELESOFT; 05.09.2009 в 22:15.
    S.Pb
    Only all ROM & RAM page in CPU0(#0000-#3FFF) window
    This is an example of control in the window CPU0 for promising clones.
    Let Garry Lancasted porting RESIDOS for exUSSR standards. It's easier.
    ---------- Post added at 22:45 ---------- Previous post was at 22:38 ----------
    Yes, ZXBUS it is not NemoBus
    Последний раз редактировалось Black_Cat; 05.09.2009 в 23:06.
    Praha
    33
    14 сообщений
    TRDOS emulation in RESIDOS will in developlent. Actually can Residos access to FA16 partitions, open/create TAP files, work with sequential files, run SNA,Z80 snapshots, support save/load tasks (task manager in NMI menu), direct save/load files from ZX basic to FAT16. You can open one TAP file for loading and next TAP for saving. Big ram in low16kB enable switching between systems via one OUT xx,xx command (also in ZX basic). On Pentagon will theoretically possible acive RESIDOS via one OUT, open XXX.TRD file on fat 16 for sequential read and write this image file to real FDD. Or write sector copy of FDD to fat16 file. Transfer data between TRDOS and FAT16 is possible.
    http://www.worldofspectrum.org/residos/
    It's way as can work with TAP files and SNApshots on russian machines.
    On PENTAGON documantation is text " ZX-BUS (NEMO BUS) "
    Pentagon 1024 use very compatible bus with original ZX Spectrum machines, only /ROMSC signal is on other pin (15).
    Последний раз редактировалось VELESOFT; 12.09.2009 в 00:07.
    Master Аватар для Djoni
    52
    33 сообщений
    А схему этого контролера где можно посмотреть ?
    Profi v5.03/1024k/палитра/FDD3,5""/FDD5,25"/HDD/XT-Keyb/Covox
    Pentagon-1024 sl v 1.4 upgrade #EFF7 Gluk RTC
    ZXM-Phoenix 1024k
    ATM Turbo 2+ v7.10 512k
    HIMAC HR42.04 48K
    HIMAC 128
    Ленинград 1
  1. Extended memory and SNApshots in emulators
    от VELESOFT в разделе Эмуляторы
    Последнее: 01.09.2009, 22:41
  2. External memory upgrade for ZX16/48
    от VELESOFT в разделе Несортированное железо
    Последнее: 26.01.2009, 19:30
  3. BASIC + Paged memory
    от valker в разделе Программирование
    Последнее: 15.05.2007, 14:17
  4. Contended memory /Медленная память/ на Original Speccy
    от MadCat! в разделе Программирование
    Ответов: 15
    Последнее: 05.03.2005, 11:18
