Speccy - наш выбор!
ZXPRESS
ZXTUNES
Virtual TR-DOS
World of Spectrum
ZX Spectrum Old Demos •
Go Back   Speccy - наш выбор! > ZX Spectrum Software > Оси
Reply
Thread Tools Display Modes
Old 7th March 2010, 03:03   #1
Master
VELESOFT's Avatar
VELESOFT is just really niceVELESOFT is just really niceVELESOFT is just really niceVELESOFT is just really niceVELESOFT is just really nice
Default Dangerous software for Pentagon 1024SL
http://velesoft.speccy.cz/other/zx12...OUT_(FD),A.zip (67 MB)
This is ZX software using memory paging on port 7FFD via this code:
LD A,#5x
OUT #(FD),A
Value #5x is in range #50-#5F and D0-D2=page 0-7,D3=vram,D6=1 for compatibility with ZX128+2A/+3.
This code write value #5x to port adress #5xFD (ZX128+2A/+3 and russian clones use also on port 7FFD adressation with A15=0,A14=1...)
On Pentagon 256/512/1024 this software access to extra memory pages 8-15 instead 0-7 !!! Some games work, but can be unstable, crash, rewrite extra memory or trdos ramdisc on Pentagon 1024.
My idea:
add software switch 128/1024 kB mode in TRDOS 6.xx with ramdisc support. Before use ramdisk must trdos enable 1MB memory and before return from trdos to ZX ram must set 128kB mode if switch is active. Switch can be in extra memory or in CMOS. Also if user manualy set pentagon 1024SL to 128kB mode, then after use trdos and return to ZX ram must be Pentagon switch to same mode 128kB (trdos must detect if 1MB is enable or disable). This trdos add best compatibility with ZX128/Pentagon 128 and this dangerous software will work correct without access to extra memory !
Next idea:
after start set pentagon always to 128kB mode via OUT #EFF7,4. This is hardware protection before dangerous access to extra memory with ramdisc data. And to basic loaders in all software for Pentagon 256/512/1024 add one OUT #EFF7,0 (enable 1MB). This is better than enable 1MB as default.
Or is better way patch all this software for possibility use on Pentagon with enabled 1MB mode ?
Or add to basic loaders in this software one OUT #EFF7,4 ?
VELESOFT is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Map Яндекс.Метрика
