Показано с 1 по 9 из 9
Тема: ISO ROM 128 with TR-DOS 5.05(cz)
    Master Аватар для VELESOFT
    Praha
    33
    14 сообщений
    По умолчанию ISO ROM 128 with TR-DOS 5.05(cz)
    This is new correct version of ISO ROM for ZX + BETADISK. Some extra basic command is designed specially for use in conmination with TR-DOS 5.05(cz). Is possible use also any othen TR-DOS versions, but basic syntax will different(I can add next video)
    ISO ROM 128(version 2010) + TR-DOS 5.05(cz)
    http://velesoft.speccy.cz/other/iso-...ll-patched.zip
    new basic syntax:
    !! (call monitor/debugger "Devastace" from tr-dos rom)
    ! (start DOS and show command line)
    !CAT (show catalog)
    !LIST (show detailed catalog)
    !RUN (load and start basic file boot.B)
    !LOAD "filename" (load basic file "filename")
    !GOTO "snapshot" CODE (load snapshot = memory snap, CPU registers ...)
    = (show basic info - ramtop, used memory, etc...)
    * (start utility "KCOPY+")
    /|\(ss+h) (start utility "BETA DISC EDITOR")
    RANDOMIZE USR 15610 (start packer "TOMPACK")
    GOTO (without parameter use GOTO 0)
    PAUSE (without parameter use PAUSE 0)
    £31(SS+X) (print value 31 in BINary format "BIN 000011111" - max range 0-255)
    "hallo" (print text "hallo" on screen - PRINT command is ignored)
    10+2 (print value 12 on screen - PRINT command is ignored)
    /257 (show 16bit value as low byte + high byte - "2,1" )
    %253 (convert 16bit value to HEX format)
    $FF (convertHEX value FF to decimal value)
    All trdos commands can be writed in basic line after char "!". This char replace "RANDOMIZE USR 15619: REM:" and enable short syntax and faster work with trdos.
    ISO ROM after reset no erase memory , show only menu:
    AUTO RESET - return to basic (if basic variables is bad then use reset)
    HARD RESET - erase all 128kB of memory
    BETADISK - jump to tr-dos + autoboot (if file boot.B absent then use CAT)
    DEVAST+ - if tr-dos 5.05(cz) is used then start monitor/debugger "devastace+"
    SPECTRUM 128 - this function is unused
    Последний раз редактировалось VELESOFT; 18.04.2010 в 21:31.
    Master Аватар для IlyaMIV
    Курск
    Наверное что то интересное написано?
    Pentagon-128/AY/FDD; Leningrad-48/128; Гамма-48 ред1; Искра- 1080; Искра-1085;
    Member Аватар для ZXSlaver
    Нефтекамск
    Хммм. Выглядит интересно.
    Это, я так понимаю, версия для оригинально ZX Spectrum ?
    ZXM-Phoenix 2048 / IDE-CF 8Gb / TSFM / RGB-VGA ZXKit1
    ZX Evo
    Radoitehnika У101 + S90
    Junior
    Praha
    Да, ISOROM 128 для нормального ZX Spectrum 128к, потому што это 2x16кБ как в оригинальном ZX Spectrum 128k+, +2. Конечно роботает и в Пентагонах.
    У меня ISOROM 128 уже от года 1994. Первые версии ISOROM были, когда был и TRDOS 4.x (1987, 1988?)
    ISORОМ конечно и для 48к машин, в других 16кБ только меню и программы KCOPY, B.D.E., TOMPACK, в первых интересно улучшенный BASIC.
    Praha
    33
    14 сообщений
    Цитата Сообщение от VELESOFT Посмотреть сообщение
    Is possible use also any other TR-DOS versions, but basic syntax will different(I can add next video)
    ISO ROM 128(version 2010) + TR-DOS 6.10e
    short command ! must be replaced with !REM:
    Only ! without parametter work
    Command !! is ignored
    Master
    Днепропетровск
    14
    14 сообщений
    what about compatibility with old speccy soft (1982 basic was modified, so changed enter points...) and what with free #ff space? i tell about ld i,#3f ; im 2
    Последний раз редактировалось doorsfan; 21.04.2010 в 18:38.
    DimkaM
    блин, ну ты то русский, пиши по русски.
    Velesoft прекрасно русский понимает.
    Praha
    33
    14 сообщений
    Compatibility is perfect. Only 128 editor is replaced with new ISO ROM features. So software using direct access to 128 rom (rom 0) will work incorrect. #FF space is replaced with new code, but second 2 bytes of IM2 tables from adress #3xFF contain #FFFF value = compatible.
    Guru Аватар для Vadim
    г. Курган
    17 сообщений
    Игр, которые использовали FF в ПЗУ, для указания вектора для режима прерываний 2 не так и много. Impact, Atari Pole - те которые мне встретились. Правятся элементарно, для работы на том же +3.
    ZX Evolution Rev B.
    Орель-08БК
    Pentagon-128 (полуубитый)
    Кворум-128 (в ремонте)
    Магик-05 (в ремонте)
    Robotron 1715
    Корвет ПК8020 и ПК8010
    Amstrad CPC 464
    Amstrad CPC 6128
