Показано с 1 по 7 из 7
Тема: разница в компиляторах TASM и LZasm
    Одесса
    187
    90 сообщений
    По умолчанию разница в компиляторах TASM и LZasm
    хочу откомпилировать эту программу
    http://habrahabr.ru/blogs/asm/64254/
    Через LZasm, но компилятор выдаёт кучу аШыБАК:
    Lazy Assembler Version 0.56 2001-01-01 02:31:08 Page 1
    penix.asm
    1 cseg segment para 'code'
    **Error** penix.asm(1) Illegal instruction
    2 assume cs: cseg,ds: cseg
    **Error** penix.asm(2) Undefined symbol: cseg
    3 org 100H
    **Error** penix.asm(3) Code or data emission to undeclared segment
    4 begin:
    **Error** penix.asm(4) Code or data emission to undeclared segment
    5 68 00 B8 db 68H, 00H, 0b8H ; push 0b800H
    **Error** penix.asm(5) Code or data emission to undeclared segment
    6 1F db 1FH ; pop ds
    **Error** penix.asm(6) Code or data emission to undeclared segment
    7 CD 10 int 10H
    **Error** penix.asm(7) Code or data emission to undeclared segment
    8 B7 07 mov bh, 7H
    **Error** penix.asm(8) Code or data emission to undeclared segment
    9 main_loop:
    **Error** penix.asm(9) Code or data emission to undeclared segment
    10 91 xchg cx,ax
    **Error** penix.asm(10) Code or data emission to undeclared segment
    11 CD 1A int 1AH
    **Error** penix.asm(11) Code or data emission to undeclared segment
    12 88 17 mov [bx], dl
    **Error** penix.asm(12) Code or data emission to undeclared segment
    13 delay:
    **Error** penix.asm(13) Code or data emission to undeclared segment
    14 CD 1A int 1AH
    **Error** penix.asm(14) Code or data emission to undeclared segment
    15 38 17 cmp [bx], dl
    **Error** penix.asm(15) Code or data emission to undeclared segment
    16 74 FE je delay
    **Error** penix.asm(16) Near jump or call to different CS
    18 96 xchg ax, si
    **Error** penix.asm(18) Code or data emission to undeclared segment
    19 02 C2 add al, dl
    **Error** penix.asm(19) Code or data emission to undeclared segment
    20 96 xchg ax, si
    **Error** penix.asm(20) Code or data emission to undeclared segment
    21
    22 91 xchg ax, cx
    **Error** penix.asm(22) Code or data emission to undeclared segment
    23
    24 E4 60 in al, 60H
    **Error** penix.asm(24) Code or data emission to undeclared segment
    25 3C 4D cmp al, 77
    **Error** penix.asm(25) Code or data emission to undeclared segment
    26 75 FE jnz keytest1
    **Error** penix.asm(26) Near jump or call to different CS
    27 43 inc bx
    **Error** penix.asm(27) Code or data emission to undeclared segment
    28 43 inc bx
    **Error** penix.asm(28) Code or data emission to undeclared segment
    29 keytest1:
    **Error** penix.asm(29) Code or data emission to undeclared segment
    30 77 FE ja keytest2
    **Error** penix.asm(30) Near jump or call to different CS
    Lazy Assembler Version 0.56 2001-01-01 02:31:08 Page 2
    penix.asm
    31 4B dec bx
    **Error** penix.asm(31) Code or data emission to undeclared segment
    32 4B dec bx
    **Error** penix.asm(32) Code or data emission to undeclared segment
    33 keytest2:
    **Error** penix.asm(33) Code or data emission to undeclared segment
    34
    35 B4 0C mov ah,0CH
    **Error** penix.asm(35) Code or data emission to undeclared segment
    36 CD 21 int 21H
    **Error** penix.asm(36) Code or data emission to undeclared segment
    37
    38 B8 0701 mov ax, 0701H
    **Error** penix.asm(38) Code or data emission to undeclared segment
    39 BA 1827 mov dx, 1827H
    **Error** penix.asm(39) Code or data emission to undeclared segment
    40 CD 10 int 10H
    **Error** penix.asm(40) Code or data emission to undeclared segment
    41
    42 89 04 mov [si], ax
    **Error** penix.asm(42) Code or data emission to undeclared segment
    43 89 55 51 db 89H, 55H, 51H ; mov [di+51], dx
    **Error** penix.asm(43) Code or data emission to undeclared segment
    44 38 37 cmp [bx], dh
    **Error** penix.asm(44) Code or data emission to undeclared segment
    45 77 FE ja main_loop
    **Error** penix.asm(45) Near jump or call to different CS
    46 C3 ret
    **Error** penix.asm(46) Code or data emission to undeclared segment
    47 cseg ends
    **Error** penix.asm(47) Illegal instruction
    48 end begin
    Lazy Assembler Version 0.56 2001-01-01 02:31:08 Page 3
    Symbol Table
    Symbol Name Type Value
    ??filename Text "penix"
    @Cpu Text 5FDFh
    @FileName Text penix
    @date Text "2001-01-01"
    @line Number 0000
    @lzasm Number 0056
    @time Text "02:31:08"
    @unicode Text 0
    begin Near16 ----:0000
    delay Near16 ----:0000
    keytest1 Near16 ----:0000
    keytest2 Near16 ----:0000
    main_loop Near16 ----:0000
    Lazy Assembler Version 0.56 2001-01-01 02:31:08 Page 4
    Error Summary
    как адаптировать программу под этот компилятор?
    goblinish
    попробуй FASM
    Последний раз редактировалось goblinish; 26.12.2011 в 08:20.
    goblinish
    компилится, но идея не новая, автор у rec.game.programmer contest идею стырил?
    Одесса
    187
    90 сообщений
    goblinish, Я в этом полный нуб.
    подскажите, как запустить редактор на компиляцию или работать с файлами, там open\save и всё такое?
    г. Челябинск
    Хелпер великое дело!!!
    На хитрый код и Отладчик с мозгами.
    Одесса
    187
    90 сообщений
    Всё....С open/save file разобрался
    ---------- Post added at 19:34 ---------- Previous post was at 19:30 ----------
    Кстати, надо попробовать эту игрушку портировать под спекача.
    ---------- Post added at 19:34 ---------- Previous post was at 19:34 ----------
    Довольно таки играбельная получилась, не смотря на столь малый вес
    ---------- Post added at 19:35 ---------- Previous post was at 19:34 ----------
    К тому же в ПЗУшке вроде есть процедура сдвига на один символ вверх
    ---------- Post added at 19:36 ---------- Previous post was at 19:35 ----------
    хотя Сдвиг вниз всё же красивее смотрится
    goblinish
    ALKO, в командной строке fasmd.exe какойто исходник.asm,
    ctrl+s-сохранить изменения, ctrl+f9-компиляция.
    ---------- Post added at 20:19 ---------- Previous post was at 20:18 ----------
    портировать? ерунда, если я на адресацию понял, то с атрибутами можно сделать в красивом стиле.
  1. Конвертер из Tasm и Alasm в текст
    от Raider в разделе Программирование
    Последнее: 24.11.2024, 12:09
  2. Atari 2600 и Atari 7800. В чём разница?
    от Mifody в разделе Atari
    Последнее: 18.09.2011, 08:12
  3. Ответов: 3
    Последнее: 18.04.2009, 12:30
  4. Ответов: 22
    Последнее: 21.03.2007, 00:16
