Показано с 1 по 10 из 10
Тема: В чем фишка ?
    По умолчанию В чем фишка ?
    http://www.crashonline.org.uk/73/cd.htm
    вот такой вот сидиром.
    Но самое интересное - читаем описание
    The cable connects from the headphone socket of your CD player (the cable has a 2.5mm jack attached, but a quarter inch jack adapter is included) to the joystick port on your Speccy. The 'box of tricks' which was originally going to stick out half way along the cable has now been condensed and sits inside the joystick plug.
    At the heart of all this technology is a good old cassette: the system requires an initializing program to be loaded from the supplied cassette to prepare the Speccy, though it is a very quick load. Additionally, it helps you set the volume on the CD player correctly - you first turn the volume down to zero, then as track one plays, slowly increase it until the screen turns from green to red. It should all work fine now...
    To actually load in a game select a track, say track 8 for Dizzy, just select 'load' on the screen and press track 8 and then Play on the CD player. When it's loaded, disconnect the cable from the joystick port, plug in your joystick and play. Should you leave the cable in the port, the game could welt play itself, getting directional information from the CD player!! Games load in roughly 30-40 seconds, not the ever-so-quick 20 as originally thought.
    Не понимаю... Как они через порт джойстика загружают это все ? То есть явно написано - грузится - коротенький загрузчик, потом ОЧЕНЬ быстро с плеера через порт джойстика грузится игра. В чем фишка ?
    Брр...
  1. [FWD] Фишка
    от Alexey Ivanov (500:95/100) в разделе Зарубежные компьютеры
    Последнее: 04.05.2006, 19:12
