Показано с 1 по 10 из 75
Тема: RUSSIAN SOFTWARE and real ZX
    Praha
    35
    15 сообщений
    По умолчанию RUSSIAN SOFTWARE and real ZX
    Russian ZX games is writed on russian ZX clones and support hardware feature TURBO OFF ( for ZX clone ZS SCORPION ). Russian ZX clone ZS SCORPION use software switching of TURBO cpu mode 3.5MHz and 7.0 MHz:
    Read port #7FFD = CPU turbo 7MHz (turbo on)
    Read port #1FFD = CPU run at 3.5MHz (turbo off)
    Write only ports #7FFD and #1FFD is used on ZS SCORPION for memory paging and reading this ports is used for CPU TURBO mode switching.
    On ZX Spectrum +2A and +3 is port #7FFD and #1FFD(with different functions) used too for memory paging. Read of this ports is not supported and CPU read data from floating bus ( value #FF ). Software TURBO switching routines for ZS SCORPION is on ZX+2A/+3 models ignored (without effect) and software run always at original ZX speed (3.5 MHz)
    Problem with this russian software is on original ZX Spectrum 128 / +2 (grey) models. This computers contain hardware bug - after read port #7FFD will ZX crash (data from floating bus is writed to paging port).
    Read port #7FFD = on ZX128/+2 write to paging port data from floating bus (can't be use)
    Read port #1FFD = on ZX128/+2 write to paging port data from floating bus (can't be use)
    ZX128/+2 use paging port #7FFD only. Hardware use incomplette port adressation (accept only A15=0 + A1=0 and port adress #1FFD is same as port #7FFD). If any russian software use read of port #7FFD of #1FFD, then real ZX128/+2 will crash. For fixed this problem you must remove instruction IN ?,(C) if BC=#1FFD or #7FFD.
    This is critical routines ("?" = any register A,B,C,D,E,H,L):
    LD BC,#1FFD
    IN ?,(C)
    LD BC,#7FFD
    IN ?,(C)
    LD A,#1F
    IN A,(#FD)
    LD A,#7F
    IN A,(#FD)
    If you remove this IN instructions from russian games/demos/utilities then will possible use this software also on ZX128/+2 and all other ZX models (+2A/+3 and russian ZX clones)
    This is my fixed TAP version of Dizzy 'B' Treasure Island game with removed instruction IN A,(C). Version for all ZX128 models(ZX128/+2/+2A/+3/russian clones):
    http://velesoft.speccy.cz/other/dizzy-b_fixed.zip
    This is original release(crash on ZX128/+2):
    http://www.worldofspectrum.org/infos...cgi?id=0015211
    And this is my fixed TAP ( ! ! ! ) version of WALKER game:
    http://velesoft.speccy.cz/kmouse/kmg...emo-km.tap.zip
    http://www.worldofspectrum.org/infos...cgi?id=0013118
    Последний раз редактировалось VELESOFT; 12.08.2009 в 11:00.
  1. Russian Bear Group
    от Serdjuk в разделе Люди
    Ответов: 54
    Последнее: 06.04.2010, 12:35
  2. NEW SOFTWARE FOR KEMPSTON MOUSE
    от VELESOFT в разделе Игры
    Последнее: 12.10.2008, 01:17
  3. X-TRACKER by CBM Software 1994
    от newart в разделе Музыка
    Последнее: 04.10.2008, 20:48
  4. Looking for Russian Games
    от CityAceE в разделе RST#38
    Последнее: 19.02.2008, 16:24
  5. SINCLAIR ZX SPECTRUM 48k RUSSIAN model MASTER NIB!
    от dhau в разделе Барахолка (архив)
    Последнее: 24.01.2006, 19:36
