Speccy - наш выбор!
ZXPRESS
ZXTUNES
Virtual TR-DOS
World of Spectrum
ZX Spectrum Old Demos •
Go Back   Speccy - наш выбор! > ZX Spectrum Hardware > Внешние накопители
Reply
Thread Tools Display Modes
Old 1st April 2009, 22:44   #1
Activist
XobbiMan's Avatar
XobbiMan will become famous soon enough
Default FDD 5.25" 360KB Chinon FZ-502 Jumpers Описание
Ищу описание (значения) jumper'ов данного дисковода, если у кого есть информации - поделитесь (гугль не помог )
__________________
ХОББИ ПК8000: http://pk8000.narod.ru, http://pk8000.8bit.lt
XobbiMan is offline   Reply With Quote
Old 1st April 2009, 23:11   #2
Guru
Rindex's Avatar
Rindex has a reputation beyond reputeRindex has a reputation beyond reputeRindex has a reputation beyond reputeRindex has a reputation beyond reputeRindex has a reputation beyond reputeRindex has a reputation beyond reputeRindex has a reputation beyond reputeRindex has a reputation beyond reputeRindex has a reputation beyond reputeRindex has a reputation beyond reputeRindex has a reputation beyond repute
Default
Чёрт его знает, этот carlsson что-то пытается там сделать. Полистай страницы дальше, может поможет.
__________________
Сбросив пару лишних мегатонн,
Rindex is offline   Reply With Quote
Old 1st April 2009, 23:37   #3
Guru
AAA's Avatar
AAA has a reputation beyond reputeAAA has a reputation beyond reputeAAA has a reputation beyond reputeAAA has a reputation beyond reputeAAA has a reputation beyond reputeAAA has a reputation beyond reputeAAA has a reputation beyond reputeAAA has a reputation beyond reputeAAA has a reputation beyond reputeAAA has a reputation beyond reputeAAA has a reputation beyond repute
Default
Я его пытался подключить в версии 720 у мня не получилось найти джампера. вбей название в поиск.
__________________
Новая мегадема написана на 35 %.
AAA is offline   Reply With Quote
Old 2nd April 2009, 10:33   #4
Activist
XobbiMan's Avatar
Default
Читал ранее, тот тоже не в понятках
(гугль не помог )
Посему тут и спрашиваю, все-таки у кого-то да и есть такой агрегат.
__________________
Old 2nd April 2009, 17:23   #5
Master
Zhizh's Avatar
Zhizh is a jewel in the roughZhizh is a jewel in the roughZhizh is a jewel in the rough
Default
У меня есть Chinon FZ-506, вечером сфотаю как у меня джампера стоят. Он к Пентагону подключен и прекрасно работает. Инструкции по джамперам у меня не было - я устанавливал их методом проб и ошибок.
Zhizh is offline   Reply With Quote
Old 2nd April 2009, 21:46   #6
Guru
sv's Avatar
sv has a spectacular aura aboutsv has a spectacular aura aboutsv has a spectacular aura about
Default
сфотай плз!
у мну правдо не FZ,а FR (Chinon FR-506 два штуки лежат)...
__________________
Pentagon1024sl2.2 +ZXMC2+neoGS+TSFM+nemoIDE+hdd+cdrom
ATM7.10 +hdd+cdrom
Palcoder+AverBox9+17" LCD
http://lib.ru/KASTANEDA/
sv is offline   Reply With Quote
Old 2nd April 2009, 18:49   #7
Guru
Клон is a jewel in the roughКлон is a jewel in the roughКлон is a jewel in the rough
Default
Вот посмотри здесь, может быть эта информация тебя на что-то натолкнет.
Клон is offline   Reply With Quote
Old 2nd April 2009, 19:44   #8
Activist
XobbiMan's Avatar
Default
Он вроде как 1.2МБ?
__________________
Old 3rd April 2009, 10:42   #9
Master
Zhizh's Avatar
Default
Дисковод Chinon FZ-506 действительно на 1,2 Мб. Больше никаких Chinon'ов я никогда не видел. Вот общий вид дисковода с заду
У моего дисковода джамперы находятся сбоку.
Сняв верхнюю крышку, закрывающую плату, можно увидеть следующее:
Джамперы подписаны буквами, некоторые из них имеют смысл для нас
Итак, слева направо:
FG - как легко видеть, там вообще ничего не впаяно
MS2 - при замыкании этих контактов выставляется скорость вращения диска 300 об/мин
DC-RY - не знаю, что такое, видимо связано с сигналом готовности, изначально была замкнута, я так и оставил
MS1 - при замыкании выставляется скорость вращения диска 360 об/мин. Так было изначально, когда дисковод работал на PC
IU - не знаю, был разомкнут
DS0 - DS3 - выбор дисковода как A, B, C или D - это всем известно, я думаю
TM - не знаю зачем он, изначально был замкнут, я его не трогал.
У меня замкнуты контакты MS2, DC-RY, DS0 и TM. И всё работает.
Если надо еще что-то сфотать, обращайтесь, сделаем.
The Following 4 Users Say Thank You to Zhizh For This Useful Post:
nikor4 (1st May 2011), razer (11th November 2009), solegstar (7th October 2011), Богдан (7th March 2011)
Old 30th September 2009, 11:56   #10
Guru
sv's Avatar
Default
что характерно,на Chinon FR-506,перемычку DC-RY,надо разомкнуть.
иначе,мой пентагон говорил мне "нихт диск"...
__________________
ATM7.10 +hdd+cdrom
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Map Яндекс.Метрика
