Показано с 1 по 8 из 8
Тема: Stupid compo for ZX Spectrum graphic (53 colours, low-res)
    Guru Аватар для breeze
    【RB】
    30 сообщений
    Exclamation Stupid compo for ZX Spectrum graphic (53 colours, low-res)
    Новость от весьма известного человека, это YERZMYEY/H-PRG, на этот раз он приглашает принять участие в необычном компо - "Stupid compo for ZX Spectrum graphic (53 colours, low-res)". Не менее известная личность Gasman/H-PRG написал для этого целый редактор можно проявить своё творчество в рисовании атрибутами и выслать работу на конкурс, если интересно как это сделать, читаем ниже:
    Hello. There will be a small stupid gfx-compo for ZX Spectrum with a graphic mode: 32*24 resolution and 53 colours.
    If You would be interested in making a small picture and send us, You should use this on-line editor: "CHUNKYPAINT" http://chunkypaint.zxdemo.org/ made kindly by Gasman/H-PRG.
    Probably You should use Mozilla Firefox rather than Internet Explorer, to draw Your picture, because we noticed the editor doesn't like IE somehow. It hasn't been tested on other browsers but should work OK.
    It's rather kind of joke compo because low-res is radical but on the other hand - You have many colours to use, so low resolution shound't be SUCH a problem.
    Among work sessions You can use "SAVE" and "LOAD" buttons and copy/paste the digits' lines (raw data for the editor).
    But when You finish Your picture then You must use "Export to TAP" and "Export to BMP" (change extentions into TAP and BMP!!) and send Your picture in these TWO formats to me ( yerzmyey AT interia.pl ).
    And let me repeat: if the picture could enter the compo it *MUST* be sent to me in *TWO* versions exported from the Chunkypaint - TAP and BMP.
    One pic for one author.
    The deadline would be in 15 August 2009.
    Any questions? Write to me: yerzmyey AT interia.pl
    Best wishes,
    YERZMYEY/H-PRG
    (๑•̀ㅂ•́)و✧ Doors UI → https://t.me/doorsui | https://t.me/atari_xl_xe ← Atari XL/XE (●´ω`●)ゞ
    Guru Аватар для diver
    Пермь
    прикольно
    【RB】
    30 сообщений
    Talking
    Цитата Сообщение от diver Посмотреть сообщение
    прикольно
    я уже свой "шедевр" отослал так что дерзайте...
    Striker
    А ты шедевр на Хакерз Топ приготовил ??
    Master Аватар для КАСик
    Воронеж
    Что-нибудь слышно о результатах? Может, хотя-бы есть ссылка где уже можно картинки посмотреть?
    【RB】
    30 сообщений
    Thumbs up
    конкурс будет проводиться в рамках V.I.P.(Vodka International Party) тогда и результаты будут
    Воронеж
    А на какое число намечено мероприятие "Vodka International Party" ?!
    【RB】
    30 сообщений
    International Vodka Party 2009 ZX Spectrum meeting.
    Time of the party: weekend (28th-30th) of August 2009.
  1. RR Compo 2008
    от rg_software в разделе Игры
    Последнее: 17.12.2008, 00:01
  2. RetroEuskal | 8Bits Graphic Compo
    от riskej в разделе Графика
    Ответов: 38
    Последнее: 05.08.2008, 19:26
  3. Haiku by Gasman and a beautiful Graphic show
    от Wlodek в разделе Софт
    Последнее: 05.01.2006, 12:35
