Показано с 1 по 10 из 21
Тема: Leningrad+
    Junior
    Chojnice, Poland
    По умолчанию Leningrad+
    Hello
    I've got Leningrad+(personal computer composite) and have a problem with correct display.
    I seems like something is with synchronisation signal. Last time(before the forum failure) someone wrote to check:
    But this is older version - leningrad48. In my case it looks like:
    What should I concretely measure/check. Can I manage without oscilloscope?
    Regards
    Maciej
    Guru Аватар для rasmer
    Саранск
    Интересно, как в польшу попал ленинград?
    Мои игры: [Overload][Removal]
    Veteran Аватар для skyther
    Лысьва
    вот тема про исправление видеовыхода ленинграда http://zx.pk.ru/showthread.php?t=1621
    Moderator
    Симферополь
    Цитата Сообщение от Maciej Посмотреть сообщение
    Hello
    Regards
    Maciej
    have you a logic probe? any simply thing which can show you logic level (TTL) and if possible - show what signals changed ( for example change from lo to high logic level or impulse sequence) ?
    even usual LED with 470 ohm res can help - long pin of it - put via res 470ohm to +5v ( usually 14 pin of TTL chips- but not in all cases) shortt pin connect via short wire to needle and use this needle as probe to check levels at pins of D11 and D42.
    ZX Evo 4Mb- в строю.
    Speccy2010 v1
    Это все мое!
    Родное!
    Junior
    Chojnice, Poland
    I was also surprised. Have bought this from some drunkard on flea market.
    thanks, I'll check this out.
    Да там дело не в этом, судя по скрину синхроимпульс просто отсутствует. Бланк есть а синхры нет. Я и посоветовал ему не мучить кошку, а просто заменить ТМ2 (74LS74) на новую.
    Will do men.
    I'll check this with logic probe.
    Can someone tell me what frequency and voltage level should be on pads "S" and "V".
    Regards
    Последний раз редактировалось Maciej; 20.06.2009 в 22:49.
    76
    51 сообщений
    Moderator
    Симферополь
    usually must be +5v but some pcb makers leave some pins in air. connect them to +5.
    is+5 present at 13 pin of d11.4? try to take sync directly from 9pin D42.2 via capasitor 22mFx16v and res 1k to ground after cap. and check 2 transistors on the way from 9pin D42.2 to TV, also - try use just cap - between scart and current video out from computer.
    i got idea - tell which same model of TV you use and how you connect Leningrad. looks like you havnt right ground btw. both devices - put gnd ( or - from 5v source) to antena shield pin.
    Speccy2010 v1
    Это все мое!
    Родное!
    Junior
    Chojnice, Poland
    is+5 present at 13 pin of d11.4? , also - try use just cap - between scart and current video out from computer.
    At 13 pin of d11 are +5V
    it doesn't help
    I've took 2 transitors and build this section "on wire". Also didn't help.
    TV is CRT Nokia 37 A1(but i've tried on others). Connecton via SCART (RGB-15,11,7); at 16 pin +5V via 220R; 20 pin - sync.; 21(CASE) - GND.
    Everything was connected
    Was replaced 2 times. No solution.
    It seems that the reason is somewhere deeper
    Последний раз редактировалось Maciej; 21.06.2009 в 20:26.
    Activist
    Moscow
    48
    32 сообщений
    Хочу обратить внимание на пару моментов.
    На вход VideoIn телевизора подан Sync, на фото же видим черно-белое изображение с градациями. Я бы проверил следующие вещи:
    Уменьшил бы резистор, подтягивающий 16й контакт scart с 220 до 75..150 Ом, или вообще бы убрал его, закоротив 16 и 20 контакты на скарте;
    С 9го выхода D42 сигнал идет на базы двух транзисторов через _один_ резистор - вообще-то это не очень корректно (возможно "недооткрытие" одного из транзисторов из-за разброса параметров). Я разделил бы базовые цепи введением второго резистора.
    it doesn't help
    Вообще-то и не должно было - снимать следовало с 8го вывода, а не с 9го (после девятого выхода два каскада на транзисторах - один инвертирующий, второй повторяющий), да и насчет резистора 1к - толку с него, если входное сопротивление по видеовходу 75 Ом, что там от этой синхры останется..
    Можно исключить первый (инвертирующий) каскад, подключив 8й вывод D42 непосредственно к второму каскаду (повторителю).
    Moderator
    Симферополь
    Хм. действительно - промухал я схему включения транзисторов. сорри.
    боюсь что без осцила - не осилить . сам встретился при восстановлении( собственно сборке заново) платы пентагона48 - сигналы выполненые по схемам монтажное ИЛИ либо с RC цепочками - очень зависимы от номиналов резисторов подтяжки - либо в цепи. с осцилографом сразу видно где что-то не то происходит.
    Speccy2010 v1
    Это все мое!
    Родное!
