Показано с 1 по 7 из 7
Тема: Extended memory and SNApshots in emulators
    Master Аватар для VELESOFT
    Praha
    Благодарностей: 380
    По умолчанию Extended memory and SNApshots in emulators
    Exist any snapshot fileformat that support extended memory for russian ZX clones ? I see only Z80 fileformat with 48/128 and 256kB(ZS Scorpion 256) support. Why isn't supported other snapshots for Pentagon 512/1024/ATM turbo, etc.. ? SNA 128 is easy format, but support only 128kB memory and not contain some other info (ay registers, tacts counter, computer type ...). My idea is add new computer types to Z80 fileformat.
    http://www.zxmodules.de/fileformats/z80format.html
    Z80 contain one byte for set HARDWARE MODE (computer type) and actually contain only 17 supported values:
    0-8 = zx models (16/48/128/+2/+2A/+3...)
    9 Pentagon 128k
    10 Scorpion 256k
    11 Didaktik+Kompakt
    12 Spectrum +2
    13 Spectrum +2A
    14 Timex TC 2048
    15 Timex TC 2068
    16-127 = unused / reserved for next zx clones
    128 Timex TS 2068
    Master Аватар для [bETA]mEN
    Moscow
    Благодарностей: 119
    http://z80stealth.emuunlim.com/
    Z80 snapshot format enhanced so it now stores all info about Russian clones (Pentagon,Scorpion,KAY,Profi), General Sound cpu&memory info, hi-res video modes.
    Praha
    Благодарностей: 380
    Цитата Сообщение от [bETA]mEN Посмотреть сообщение
    This emulator not work under my WIN XP
    Documentation for new Z80 fileformat absent
    Moscow
    Благодарностей: 119
    http://trd.speccy.cz/emulz.htm#Z80Stealth
    Z80Stealth v0.600 private(!) beta (WIN)
    Praha
    Благодарностей: 380
    EmuZWin also support new snapshot format *.EZX with documentation.
    http://kolmck.net/zx/EmuZWin_Addons.zip
    But this format is supported only in EmuZWin emulator
    Actually I need use any snapshot format for SAVE/LOAD on real ZX Spectrum with IDE. I developpe for DivIDE interface new BIOS rom with NMI menu + task manager. Each task is loaded or saved to CF card in 48kB SNA format. I need on ZX128/256/512/1024 models use complette memory for correct work. BIOS can detect ZX type+memory size(ZX48/128, Pentagon 256/512/1024, Scorpion 256/1024, ZX Profi....) and save each task to one file with length = zx memory size(uncompressed raw) + additional info(registers). Ideally as fileformat compatible with ZX emulators.
    Praha
    Благодарностей: 380
    Цитата Сообщение от Vitamin Посмотреть сообщение
    I need create uncompressed SZX files under WIN XP and test it on real ZX Spectrum. Exist utility "SnapConv" for convert to uncompressed SZX file, but I can't find DOS version (source is free).
  1. gfx extended :)
    от riskej в разделе Графика
    Последнее: 06.08.2008, 16:58
  2. BASIC + Paged memory
    от valker в разделе Программирование
    Последнее: 15.05.2007, 13:17
  3. Ответов: 8
    Последнее: 04.11.2006, 14:14
  4. Emulators Machine
    от CityAceE в разделе Зарубежные компьютеры
    Последнее: 24.08.2005, 13:04
