Показано с 1 по 10 из 15
Тема: RAMDISC in TRDOS
    Master Аватар для VELESOFT
    Praha
    33
    14 сообщений
    По умолчанию RAMDISC in TRDOS
    I have only three TRDOS rom's with ramdisc support.
    1) for Pentagon 1024 (use only 512kB ramdisc)
    2) for ZX PROFI 1024 (use full ramdisc size 80+1 tracks)
    3) for SPRINTER 2000 (use also full ramdisc size)
    On ZX PROFI is possible from memory page 8 import complette TRD file(image), but software using extended memory can rewrite data in ramdisc.
    SPRINTER 2000 can connect more ramdisc's to all 4 virtual FDD drives.
    Only ramdisc for Pentagon 1024 is limited with 512kB. It's impossible import complette 640kB TRD file/image to ramdisc. First 512kB in memory is always free for possibility load any software for Pentagon 512 ?
    Exist any other TRDOS with ramdisc ?
    Exist software for load TRD file from HDD to extended memory ?
    Рязань
    TR-DOS 6.05E and its successors are supporting ramdisks for any machine, you only need to edit the source. Since 6.09E the ramdisk goes downwards in memory, that means you can specify any size you want (Mr Gluk Reset Service uses this).
    Praha
    33
    14 сообщений
    Can you create this TRDOS version for all ZX clones ?
    (Actually must each user recompile sources for different ZX clones)
    - ZX PROFI 1024
    - PENTAGON 1024
    - ATM TURBO
    - ZS SCORPION 1024
    - SPRINTER 2000 (can be added also SPRINTER's paging port)
    For all this machines create this TRDOS versions:
    - ramdisk 512kB only at end of extended memory
    - ramdisk 648kB(81 tracks) at end of memory (PROFI use ramdisc begin from ram page 8 = software using more than 128kB memory will rewrite ramdisc )
    Better way is use last memory page as start of ramdisc and all lower pages as next. (add only XOR for invert memory pages for ramdisc)
    Any pages of extended memory is reserved for other software ?
    Is possible in TRDOS 6.09E before FORMAT command set also size of ramdisc ? (81 or 80 tracks)
    Рязань
    - ZX PROFI 1024
    - PENTAGON 1024
    - ATM TURBO
    - ZS SCORPION 1024
    Each user is supposed to make a version for his/her own computer.
    None.
    At least KAY-1024 version that I have not seen.
    DNA OS.
    Последний раз редактировалось alone; 08.11.2009 в 00:26.
    Praha
    33
    14 сообщений
    Why ? Better is compile this trdos for all computer types and release it on web. Actually must 100 users of ZX PROFI recompile same trdos version for same computers , 20 users of QUORUM compile 20x same trdos, 15 users of ATM TURBO compile 15x same trdos, etc....
    My idea:
    create official WEB for TRDOS roms and documentation and release all possible trdos versions.
    Praha
    33
    14 сообщений
    My idea:
    This page contain different trdos rom versions, but without any documentation
    http://www.zxspectrum.it/_TR.htm
    Последний раз редактировалось VELESOFT; 01.12.2009 в 22:59.
    76
    51 сообщений
    - ZS SCORPION 1024
    No, "Scorpion TR-DOS" have the changes in code.
    Guru Аватар для sv
    Саратов
    DNA OS
    а как же WDC?
    ATM 7.10 | hdd | cd-rom
    Commodore 64 | fdd
    БК 0010-01
    Veteran Аватар для AlexBel
    Волгоград, Россия
    126
    76 сообщений
    По умолчанию Исходники TR-DOS 6.0х
    Может, вопрос и не в тему, извиняюсь заранее. Можно где-нибудь взять исходники TR-DOS 6.0х, умеющих работать с RAM-диском? Или, на крайний случай, описание, как организована работа с RAM-диском.
    Рязань
    Она с исходником и релизилась. http://alonecoder.nedopc.com/zx/GLUK66SRC.rar - там файл DOSINST.H, к нему модуль DOSprogs.H - там всё в комментариях расписано.
  1. Speccy2007 v1.06 (128 + AY + TRDOS)
    от syd в разделе Speccy-2007/2010
    Ответов: 474
    Последнее: 15.01.2020, 21:54
  2. TRDOS VERSIONS
    от VELESOFT в разделе Оси
    Последнее: 03.05.2008, 23:42
  3. TRDOS для Neo
    от ILoveSpeccy в разделе Внешние накопители
    Ответов: 20
    Последнее: 08.03.2008, 15:04
  4. TRDOS rom with monitor
    Последнее: 12.08.2007, 17:53
  5. Объединение файлов в TRDOS
    от moroz1999 в разделе Софт
    Последнее: 21.01.2007, 21:58
