Показано с 1 по 4 из 4
Тема: Binary
    R.I.P. Аватар для Rindex
    Khimki
    Благодарностей: 5966
    По умолчанию Binary
    Ещё одна новая игра - Binary. Музыки, увы, нет, но есть AY-звуки.
    Что надо сделать:
    You play a space station employee who is the last to leave during an evacuation from the space station. You get your gear, go to the landing deck and realise you've lost the launch code for your mini-shuttle. You need to hunt down and collect the 5 parts of the binary code. Watch out for the space stations cargo droids which have malfunctioned and caused the evacuation, they can kill you if touched. Normally, they just collect incoming supplies to the station and put it into storage, but they have started to flail around wildly and unpredictably causing a lot of danger to the crew. They occasionally drop some supply crates if shot, which can be collected for extra points. Some of the security systems employed in the space station can also be hazardous, such as the spikes which you must jump over and the acid baths which have been known to leak and cause a lot of damage. These security systems would normally only be employed if an intruder was found to be wandering the space station, but they have been put into action to protect the station from space pirates whilst the crew are evacuated. Once all the parts are found, return to your shuttle to win the game.
    http://dl.dropbox.com/u/2668371/Binary-ByMulder.zip
    http://www.worldofspectrum.org/infos...cgi?id=0025039
    P.S. И опять не стоит торопится с переводом в trd.
    Последний раз редактировалось Rindex; 11.07.2010 в 19:39.
    Сбросив пару лишних мегатонн,
  2. Эти 4 пользователя(ей) поблагодарили Rindex за это полезное сообщение:
    ace210 (09.07.2010), Aprisobal (09.07.2010), moroz1999 (11.07.2010), скандалист и другозавр (09.07.2010)
  3. #1
  4. #2
    Khimki
    Немного пофиксили версию игры. Ссылка чуть выше.
  5. Этот пользователь поблагодарил Rindex за это полезное сообщение:
    Slider (09.07.2010)
  6. #3
    Junior
    Северодвинск
    Благодарностей: 2
    Что-то мне до боли напоминает Судью Дреда...
    Z-Zero Systems\OversunFriendship
    LodeRunner3_AHTP, 56Kletok, Wolf, Wolf2&3, Supaplex, MLEd
    (см. архив на моём сайте)
  7. #4
    Khimki
    Изменения:
    Fixed - Sticky crates
    Added - Joysticks and redefineable keys
    Added - Beeper Music from Mister Beep
    Added - Easy, Normal and Hard settings which adjust the lives given at the start of the game
    Ссылка в первом посту (верхняя).
  1. Binary Counter Defense
    от kyv в разделе Демо
    Последнее: 16.07.2008, 10:14
  2. Binary Dimension Party
    от daniel в разделе События
    Последнее: 25.03.2006, 04:48
