Показано с 1 по 10 из 19
Тема: Pentagon 128k debugging
    Activist Аватар для Shockwav3
    Berlin, Germany
    28
    18 сообщений
    По умолчанию Pentagon 128k debugging
    Hi there,
    I'm currently in the progress of building a Pentagon 128 (Revision 2011 produced by zorel). Good things first, it already boots, accepts keyboard input and even lists betadisk directories. Now comes the bad part, after a few seconds I get junk characters on the screen, but the machine remains operational for a few more seconds til it crashes (mostly after 30-45 seconds). Sometimes it reboots, but most of the time it just hangs requiring a hard reset. Any ideas what could be wrong?
    Further info:
    - IC type is all 74lsxxx except for dd02, dd11 & dd12 (used 74hct93 there). I used the translation table from here: http://sblive.narod.ru/ZX-Spectrum/P...ntagon128k.htm (except for dd100 which is wrong there and should be cd4069).
    - RAM chips are 41256 and have decoupling capacitors
    - random decoupling capacitors have been placed on the board
    - resistor and capacitor values have been used according to pentagon.pdf from here http://zxspectrum.it.omegahg.com/doc/Pentagon.pdf
    Here's also a picture:
    http://img855.imageshack_.us/img855/...ntagon128k.jpg
    So any ideas what to try next?
    Pentagon 1024SL 2.2 + ZXM-GS + Z-Controller + TSFM + Tape-In
    Compact 256 Turbo 1.1 (ZS Scorpion 256 INT, Port #FF, Port #FB) + Covox + ProfROM + NemoBus + Z-Controller
    ZS Scorpion 256 Turbo+ + GMX + SMUC + ZXM-GS
    Pentagon 48 + MIKAY128 + VG93 Turbo + NemoIDE + Stereo Covox + KJoy
    Sprinter 2016S
    ARGUS (x86) Project leader
    Sorry, I don't speak Russian / К сожалению, я не говорю по-русски
    Guru Аватар для null_device
    г. Красноярск
    68 сообщений
    Are all the errors of the board have been eliminated?
    http://zx.pk.ru/showpost.php?p=535392&postcount=371
    Is the board AY \ YM, it also is an error.
    Последний раз редактировалось null_device; 10.02.2013 в 02:42.
    Berlin, Germany
    28
    18 сообщений
    Thanks for letting me know about that one - didn't know about that one before, fixed that, didn't help much
    I've also fixed the missing track on dd31 and added R50 (56kohm)
    Sprinter 2016S
    г. Красноярск
    68 сообщений
    Sorry if this mу advice does not help.
    In the next branch, discussed the assembly and adjustment of the board, try to ask a question there.
    http://zx.pk.ru/showpost.php?p=574471&postcount=983
    Berlin, Germany
    28
    18 сообщений
    Just to let you guys know: both of my Pentagons are up and running
    Appears the first one was suffering from a flakey PSU (I was using my PC's) and C7 being soldered in the wrong place and the second one must have had a cold solderjoint, as it magically started working once I re-soldered every chip.
    So ... what are good measures for testing that everything is working alright?
    I've tried loading and running a demo from disk (Alienate by Hooy-Program), loading and saving a program from/to tape, testing the INT and RAM using Test 4.30 (which also confirms the tact at 171680 cycles).
    One more thing that comes to my mind would be testing a demo that uses covox sound and that would be pretty much all.
    Sprinter 2016S
    369
    238 сообщений
    How many INT cycles? "Too short", "Too long" or..?
    If you connect DAC (R-2R or 8bit chip) on "printer port"... only after that you can hear covox sound.
    Profi must live!
    Моё железо...
    Все укомплектованы:
    Berlin, Germany
    28
    18 сообщений
    Test 4.30 gives me 32-28
    TestInt reports 40-36
    Hidden part of the Insult Megademo shows just fine.
    Sprinter 2016S
    369
    238 сообщений
    there are no more questions) pentagon work properly. my congratulations!!!
    Profi must live!
    Моё железо...
    Все укомплектованы:
    Veteran Аватар для ZXMAK
    20
    14 сообщений
    он жаловался на то что все работает, выводит каталог диска, но через несколько секунд появляются случайные символы и затем через 30 сек крешится..
    369
    238 сообщений
    где? этот баг кажись устранен давно. он вроде отписался, что всё работает замечательно и он погонял разные тесты, демы и т.д....
    Profi must live!
    Моё железо...
    Все укомплектованы:
  1. Как быть с реалом - Pentagon 128k ?
    от dM_GBG в разделе Pentagon
    Ответов: 49
    Последнее: 14.01.2021, 18:05
  2. куплю pentagon 128k
    от ZX1997 в разделе Барахолка (архив)
    Последнее: 12.01.2012, 14:41
  3. Помогите с Pentagon-128k !
    от r0m в разделе Pentagon
    Ответов: 383
    Последнее: 15.05.2010, 02:51
  4. Ответов: 57
    Последнее: 03.04.2010, 07:42
  5. Ответов: 0
    Последнее: 24.01.2010, 21:46
