Testing in progress - Please wait
Memory Size is 4088 K Bytes
9 Step memory test
Step 1 2 3 4 5 6 7 8 9
Message 04 Entering Dialog mode
Commands are Help, Boot, List, Setup, Map and Test.
Type a command then press the RETURN key: B AZ
Trying AZ0
Starting system from AZ0
RSX-11M-PLUS V4.6 BL87 2044.KW System:"BIGSYS"
>RED AZ:=SY:
>RED AZ:=LB:
>RED AZ:=SP:
>MOU AZ0:"RSX11MPBL87"/ACP=UNIQUE
>@AZ:[1,2]STARTUP
>* Please enter time and date (HH:MM DD-MMM-YYYY) [S]: 13-APR-2021 19:50
>TIM 13-APR-2021 19:50
>SET /NOLOGON
>SET /CACHE=LB:(CRE=::1200:TOP,LOG=10,VIR=10,DIR=10,OVE=10,REA=10,DEF)
>SET /COLOG=ON
>CON ONL ALL
>ACS SY:/BLKS=2048.
>ELI /LOG/LIM
>CLI /INI=DCL/CTRLC/DPR="<15><12>/$ /"
>INS LB:[1,1]RMSRESAB.TSK/RON=YES/PAR=GEN
>INS LB:[1,1]RMSLBL.TSK/RON=YES/PAR=GEN
>INS LB:[1,1]RMSLBM.TSK/RON=YES/PAR=GEN
>INS LB:[1,1]DAPRES.TSK/RON=YES/PAR=GEN
>INS LB:[3,54]RMSDES.TSK
>INS LB:[3,54]RMSDEF.TSK
>INS LB:[3,54]RMSBCK.TSK
>INS LB:[3,54]RMSRST.TSK
>INS LB:[3,54]RMSCNV.TSK
>INS LB:[3,54]RMSIFL.TSK
>INS LB:[3,54]RMSDSP.TSK
>VCP CRE /UNI=14/ALT
>INS $QMGCLI
>INS $QMGCLI/TASK=...PRI
>INS $QMGCLI/TASK=...SUB
>QUE /START:QMG
>INS $QMGPRT/TASK=PRT.../SLV=NO
>QUE LP0:/CR/NM
>START/ACCOUNTING
>CON ESTAT LP0:
>QUE LP0:/SP/FL:2/LOWER/FO:0
>QUE BAP0:/BATCH
>QUE LP0:/AS:PRINT
>QUE BAP0:/AS:BATCH
>SET /PUB=AZ1:
>MOU AZ1:RSXUSERDISK/ACP=UNIQUE/CAC=(LOG=10,VIR=10,DIR=10,OVE=10,REA=10,DEF)
>ASN AZ1:=US:/GBL
>SET /PUB=AZ2:
>MOU AZ2:RSXSOFTWARE/ACP=UNIQUE/CAC=(LOG=10,VIR=10,DIR=10,OVE=10,REA=10,DEF)
>ASN AZ2:=SW:/GBL
>SET /NETUIC=[5,54]
>RUN $PIP/UIC=[5,54]/CMD="PIP LB:[5,54]NNS.TMP;*/DE/NM"
>SET /UTLUIC=[4,54]
>SET /LOGON
>INS LB:[ACD]EXP
>ACD INS LB:[ACD]EDTACD AS NUM 127 TOP ASS CLE$EDT
>ACD INS LB:[ACD]EMAACD AS NUM 220 TOP ASS CLE$EMACS
>ACD INS LB:[ACD]CM7209 AS NUM 200 TOP ASS CM$7209
>SET /UTLUIC=[4,54]
>DFL LB:[1,5]=CCL$SYSTEM/GBL
>DFL NL:=CCL$GROUP/GBL
>DFL SYS$LOGIN=CCL$USER/GBL
>INS $CCL/TASK=...CCL/PRI=160./CLI=YES
>CLI /INI=CCL/DPR="<15><12>/# /"
>REM ...CA.
>INS $TDXF
>INS $TDX/TASK=...CVT/PRV=NO
>DFL LB:[TED]=TED$TYPE/GBL
>INS $TED
>INS $BRD
>INS $CAL/TASK=...CAL
>INS $COD
>INS $DOB
>INS $EMACS
>INS $HEY
>INS $HANGUP
>INS $K11IDD
>INS $K52
>INS $MKE
>INS $PUT
>INS $RNO
>INS $RTEM
>INS $SRD
>INS $TNC
>INS $TRANSFER
>INS $UPTIME
>INS $USH
>INS $WRITE
>INS $BASIC/INC=34000
>INS $STOP
>INS $BP2IC2
>INS $BP2OPT
>INS $B2RESQ
>INS LB:[1,1]BP2RES/PAR=GEN/RON=YES
>INS LB:[1,1]BP2SML/PAR=GEN/RON=YES
>DFL LB:[DECUSC]=C/GBL
>INS LB:[DECUSC]AS
>INS LB:[DECUSC]CC
>INS LB:[DECUSC]MP
>INS LB:[DECUSC]GREP
>INS $PDP11C
>INS LB:[1,1]CCSMRX/PAR=GEN/RON=YES
>INS $C81
>INS $C81ODL
>INS $C81RFM/TASK=...RFM
>INS LB:[1,1]C81LIB/PAR=GEN/RON=YES
>INS LB:[1,1]DBLRSX/PAR=GEN/RON=YES
>INS $DIBOL83
>INS $DBLMSGMGR
>INS $DBLSORT1
>INS $DBLSORT2
>INS $DBLMNUGEN/TASK=...MNU
>RUN MSGMGR 1T
>INS $FOR
>INS $F77
>INS LB:[1,1]F7FCLS/PAR=GEN/RON=YES
>INS LB:[1,1]F7RCLS/PAR=GEN/RON=YES
>INS $PDPPAS
>INS LB:[1,1]FDVFCS/PAR=GEN/RON=YES
>INS LB:[1,1]FDVRES/PAR=GEN/RON=YES
>INS LB:[1,1]FDVRMS/PAR=GEN/RON=YES
>INS LB:[30,10]FED
>INS LB:[30,10]FUT
>INS $DTR
>INS $LCDDMF
19:52:07 COT -- Date is 13-APR-21
19:52:07 Logout user [200,200] TT0:
>HEL 1,127
Password:
RSX-11M-PLUS V4.6 BL87 [1,54] System BIGSYS
13-APR-21 19:52 Logged on Terminal TT0: as OIS1
Good Evening
19:52:26 Login user SAFIULLIN [1,127] TT0:
O(o o)O
+---ooO-----------Ooo----------------------------------------------+
| # # BIGSYS:: RSX-11M-PLUS V4.6 |
Last interactive login on Tuesday, April 13, 2021 19:34:21 (TT0:)
>@LB:[1,2]SYSLOGIN.CMD
>@ <EOF>
