Показано с 1 по 10 из 53
Тема: Revision 2012
    Activist Аватар для random
    ссср
    По умолчанию Revision 2012
    признавайтесь, кто что делает для сабжа?
    OLDSKOOL COMPETITIONS
    GENERAL INFORMATION
    Supported platforms are anything with a CPU that has a 16 bit or smaller data bus (C64, Amiga ECS, ZX Spectrum, VIC20, Atari XL, Atari ST, NES, SNES, Master System, Mega Drive, ...)
    Please contact us beforehand for any platform that does not produce a VGA or PAL signal so we can plan to record your production properly. Ideally bring a recording yourself in this case - providing your own recording does not mean we don't need to see the real hardware.
    For C64 : Please state which SID chip to use (6581/8580). This information will be displayed on the info slides for your production.
    Please state if your entry requires any user interaction (pressing space at the end of parts, etc)
    The entry has to be delivered as a disk- or cartridge file (strongly preferred). Don't have an image ? Physical media are still allowed, don't worry.
    You must deliver proof that your entry works on real hardware (i.e. bring the hardware with you and show the organizers).
    OLDSKOOL DEMO
    Maximum size is 1 standard medium for your platform. For example
    1 disk (both sides on single-side media) on VIC20, C64, Atari ST
    1 cartridge image for NES
    1 roll of Paper Tape for your Data General NOVA System.
    Maximum running time: 8 minutes (including loading/precalc, which won't be shown on the big screen).
    No autostart or assembler jumps/SYS on systems with a BASIC interpreter.
    OLDSKOOL 4K INTRO
    Maximum size is 4096 bytes (16 blocks and 32 bytes on C64). The production must be a single file. (Noters are OK). If the minimum cartridge image for your platform is larger than 4096 bytes, only the first 4096 bytes of the cart may be used - bring a cartridge image as proof.
    GRAPHICS
    See oldskool graphics
    MUSIC
    See Executable music (oldskool)
    http://www.youtube.com/watch?v=eFtmqCjU6Wo
    Кто еще едет? Кому нужны представители?
    Последний раз редактировалось random; 22.03.2012 в 18:27.
    Дзержинск (DustCity)
    мы на Ассембли... оно как то ближе территориальнее)
    Pentagon1024sl2.2/TSFM/Z-Controller/GS128Kb/HDD/CDROM/Palcoder
    Guru Аватар для newart
    161
    66 сообщений
    revision 2012 - байкот!!
    Thank you for your submission... Unfortunately, the competition rules at Revision don't allow remote entries (the person submitting/presenting it at the party must be one of the creators of the work), so it won't be possible for me to act as the representative for these entries, sorry.
    ---------- Post added at 12:47 ---------- Previous post was at 12:38 ----------
    Красивые такие правила:
    Only submit your own work. In a cooperative effort any of the people involved may submit the final result.
    If you submit something, you have to be present at the party. No Exceptions.
    Entries which we cannot be run on the compo machines will be disqualified. To prevent this you can ask us to test your production on the compo machines. Do this timely and you will even have time to fix any problems that might pop up.
    Moderator Аватар для BYTEMAN
    Брест/Минск
    115
    57 сообщений
    надо на хацкерзтоп такое же правило вводить. Хай народ приезжае к нам
    С уважением, Александр.
    SID-Blaster/ZX
    161
    66 сообщений
    Вы не в том положении. Да и Revision так долго не протянет.
    Брест/Минск
    115
    57 сообщений
    похоже, что он уже так очень долго тянет.
    SID-Blaster/ZX
    161
    66 сообщений
    Раньше был обязателен представитель для выставления работы.
    Теперь автор или соавтор обязательно должен присутствовать на пати.
    Veteran Аватар для valeron
    г.Слоним Гродненской области
    Да поклади ты на этот ревижн, или ты сценер?
    161
    66 сообщений
    Не могу! AER сделал две мощных демки. А орги вместо того что с радостью принять 8 битный стафф, дали ему х-ем по лицу!
    Брест/Минск
    115
    57 сообщений
    newart, дык пускай едет на ревижн
    SID-Blaster/ZX
  1. Revision 2012 invitation
    от Rindex в разделе Демо
    Ответов: 17
    Последнее: 05.03.2012, 19:16
  2. REVISION 2011 (ex-Breakpoint)
    от breeze в разделе События
    Ответов: 33
    Последнее: 03.05.2011, 00:59
  3. Pentevo/ZX Evolution revision A - тестинг
    от AAA в разделе ZXEvo
    Ответов: 354
    Последнее: 25.03.2010, 23:45
  4. PAL Coder revision B
    от CHRV в разделе Изображение
    Ответов: 20
    Последнее: 18.11.2007, 13:42
  5. Turbo Sound (revision С)
    от CHRV в разделе Звук
    Последнее: 07.07.2006, 22:24
Метки этой темы
