Страница 34 из 84 ПерваяПервая ... 303132333435363738 ... ПоследняяПоследняя
Показано с 331 по 340 из 840
Тема: ОБСУЖДАЕМ ИГРЫ (УК-НЦ, ДВК, БК, НЕМИГА и др.)
  1. #331
    R.I.P. Аватар для hobot
    Зеленоград
    370
    309 сообщений
    Под SJ монитором забегала )
    .RU DUNGEO
    Welcome to Dungeon.                     This version created 10-AUG-78.
    You are in an open field west of a big white house with a boarded
    front door.
    There is a small mailbox here.
    >HELP
    Useful commands:
       The 'BRIEF' command suppresses printing of long room descriptions
    for rooms which have been visited.  The 'SUPERBRIEF' command suppresses
    printing of long room descriptions for all rooms.  The 'VERBOSE'
    command restores long descriptions.
       The 'INFO' command prints information which might give some idea
    of what the game is bout.
       The 'QUIT' command prints your score and asks whether you wish
    to continue playing.
       The 'SAVE' command saves the state of the game for later continuation.
       The 'RESTORE' command restores a saved game.
       The 'INVENTORY' command lists the objects in your possession.
       The 'LOOK' command prints a description of your surroundings.
       The 'SCORE' command prints your current score and ranking.
       The 'TIME' command tells you how long you have been playing.
       The 'DIAGNOSE' command reports on your injuries, if any.
    Containment:
       Some objects can contain other objects.  Many such containers can
    be opened and closed.  The rest are always open.   They may or may
    not be transparent.  For you to access (e.g., take) an object
    which is in a container, the container must be open.  For you
    to see such an object, the container must be either open or
    transparent.  Containers have a capacity, and objects have sizes;
    the number of objects which will fit therefore depends on their
    sizes.  You may PUT any object you have access to (it need not be
    in your hands) into any other object.  At some point, the program
    will attempt to pick it up if you don't already have it, which
    process may fail if you're carrying too much.  Although containers
    can contain other containers, the program doesn't access more than
    one level down.
    Fighting:
       Occupants of the dungeon will, as a rule, fight back when
    attacked.  In some cases, they may attack even if unprovoked.
    Useful verbs here are 'ATTACK <villain> WITH <weapon>', 'KILL',
    etc.  Knife-throwing may or may not be useful.  You have a
    fighting strength which varies with time.  Being in a fight,
    getting killed, and being injured all lower this strength.
    Your carrying capacity may also be reduced after a fight.
    Strength is regained with time.  Thus, it is not a good idea to
    fight someone immediately after being killed.  Other details
    should become apparent after a few melees or deaths.
    Command parser:
       A command is one line of text terminated by a carriage return.
    For reasons of simplicity, all words are distinguished by their
    first six letters.  All others are ignored.  For example, typing
    'DISASSEMBLE THE ENCYCLOPEDIA' is not only meaningless, it also
    creates excess effort for your fingers.  Note that this trunca-
    tion may produce ambiguities in the intepretation of longer words.
       You are dealing with a fairly stupid parser, which understands
    the following types of things--
       Actions:
            Among the more obvious of these, such as TAKE, PUT, DROP, etc.
            Fairly general forms of these may be used, such as PICK UP,
            PUT DOWN, etc.
       Directions:
            NORTH, SOUTH, UP, DOWN, etc. and their various abbreviations.
            Other more obscure directions (LAND, CROSS) are appropriate in
            only certain situations.
       Objects:
            Most objects have names and can be referenced by them.
       Adjectives:
            Some adjectives are understood and required when there are
            two objects which can be referenced with the same 'name' (e.g.,
            DOORs, BUTTONs).
       Prepositions:
            It may be necessary in some cases to include prepositions, but
            the parser attempts to handle cases which aren't ambiguous
            without.  Thus 'GIVE CAR TO DEMON' will work, as will 'GIVE DEMON
            CAR'.  'GIVE CAR DEMON' probably won't do anything interesting.
            When a preposition is used, it should be appropriate;  'GIVE CAR
            WITH DEMON' won't parse.
       Sentences:
            The parser understands a reasonable number of syntactic construc-
            tions.  In particular, multiple commands (separated by commas)
            can be placed on the same line.
       Ambiguity:
            The parser tries to be clever about what do do in the case of
            actions which require objects that are not explicitly specified.
            If there is only one possible object, the parser will assume
            that is should be used.  Otherwise, the parser will ask.
            Most questions asked by the parser can be answered.
    Последний раз редактировалось hobot; 20.03.2015 в 15:08. Причина: заменил информацию
  2. #331
  3. #332
    Зеленоград
    370
    309 сообщений
    Smile ZORK (1978-1980 гг.) для УК-НЦ
    Поскольку у меня возникли некоторые трудности с запуском игры в эмуляторе ДВК,
    после подсказки автора эмулятора по запуску я решил собрать две дискеты для
    живой УК-НЦ или эмулятора.
    http://www.old-games.ru/forum/showth...83#post1182883
  4. #333
    Зеленоград
    370
    309 сообщений
    Smile STALK.SAV
    Не повезло - игра STALK )
    скриншот - "замуровали" ;-)
    всего то на 2-м этаже. Джина звать не стал. Просто выключил эмулятор.
    Последний раз редактировалось hobot; 20.03.2015 в 15:10.
  5. #334
    Зеленоград
    370
    309 сообщений
    Red face
    Добавил отдельной позицией "редкие", "особенные"
    или недавно обнаруженные символьные игры для ДВК.
    Все игрушки проверены в эмуляторе Patrona.
    Добавлены краткие описания. Не так уж много нового,
    (да и откуда бы?), но кое что есть.
    описание и ссылка.
    Сборник редких (и не очень) вариантов символьных игр для ДВК.
    ADVENT.SAV 	- "Колоссальная пещера" текстовый
    AINDX .DAT	квест, полностью на Русском.
    ASAVE .DAT
    ATEXT .DAT
    BARMEN.SAV	- "БАРМЕН"
    CHESS1.SAV	- вариант DECовских шахмат
    COPTER.SAV	- сложнейшая дуэль наводчика и лётчика
    GDNX  .SAV	- GDN - XONIX (fixed by [form] )
    GOROD .SAV	- Городки.
    HANOY .SAV	- Ханойская башня.
    KALAH .SAV	- "КАЛАХ" сложнейшая, лог. игра
    KING  .SAV	- "Королевство Эйфория"
    KIY   .SAV	- редкая вещь - символьный БИЛЬЯРД
    KOSMOS.SAV	- вариант "Звёздного Патруля"
    KOSTI .SAV	- "ПОКЕР на костях", таб. клуба сохраняет строго на SY:
    KWADR .SAV	- "КВАДРАТОБОЯЗНЬ" - логика.
    LAT   .SAV	- переключение терминала в реж. "ЛАТ".
    LIVE  .SAV	- моделируем и наблюдаем эволюцию колонии клеток
    LOTOS .SAV	- он же "КАКТУС" - надо уберечь от атаки гусениц.
    MARS13.SAV	- вариант игры "МАРС"
    MARS15.SAV	- вариант игра "МАРС"
    MAXIT .SAV	- логическая игра для 2-х игроков
    PENMSM.SAV	- вариант "ПЕНТИКСА"
    PENTA2.SAV	- вариант "ПЕНТИКСА"
    PIKNIK.SAV	- вариант игры "Сталкер", приключения + юмор.
    PITONS.SAV	- соревнования с компьютерным питоном
    REVERS.SAV	- игра "РЕВЕРСИ" против компьютера.
    RUBIK .SAV	- "РУБИК" редкий вариант "ПЕНТИКСА"
    RUS   .SAV	- переключение терминала в реж. "РУС".
    SNAKE .SAV	- тот же "Питон" или "Змейка" (классика).
    SPACEM.SAV	- мод."Звёздный Патруль" - почти бесконечные импульсы.
    SPCINV.SAV	- "Вторженцы из Пространства" - аркада.
    SP12  .SAV	- вариант игры "ПАКМАН"
    SP16  .SAV	- PACMAN v5.2
    SP6   .SAV	- PACMAN v05.06 (Климов Д., Сторожевых С.)
    STADO .SAV	- редкая логическая игра про черепашел от Пажитнова
    STALK .SAV	- "СТАЛКЕР" ещё один вариант.
    TET3Z .SAV	- "ТЕТРИС" с увеличенной задержкой (fixed by Patron)
    TET8  .SAV	- очень играбельный "ТЕТРИС" и весит всего 8 блоков.
    TIR   .SAV	- Тир на двух игроков.
    TRK   .SAV	- убиваем тараканов, скрываемся за минами, атакуем по площади.
    TROPA .SAV	- "ОРЕГОНСКАЯ ТРОПА" - приключения + юмор.
    WALL  .SAV	- управляя площадкой рушим стенку мячиком.
    XHALL .SAV	- "XONIX" с таблицей рекордов.
    XONIXM.SAV	- "XONIX" (fixed by Patron)
    http://archive.pdp-11.org.ru/ukdwk_a...t/REDKIE_IGRY/
    2 form -- кое что можно попробовать в RTEM наверное?
    Последний раз редактировалось hobot; 20.03.2015 в 15:11.
  6. #335
    Зеленоград
    370
    309 сообщений
    Smile M3.SAV ещё один стакан для УК-НЦ.
    Обновил образ в архиве
    http://archive.pdp-11.org.ru/ukdwk_a...bas_and_games/
    Добавив на него M3.SAV ещё один вариант стакана,
    игрушка программирует шрифт, управление стрелками,
    СУ+Ц или "СТОП" - пауза, а вот выход я не нащупал )
    Плавный и вполне играбельный.
    КАРТИНКИ
    бонус скрин ;-)
    Последний раз редактировалось hobot; 05.03.2015 в 16:45.
  7. #336
    Зеленоград
    370
    309 сообщений
    Smile LAND под RT-11 5.7 для ЭЛЕКТРОНИКА-85
    Вот скинул в образ .rd который на днях выкладывал form,
    игра запустилась и работает
    - это потому что я забыл файл с уровнями добавить.
    Если такой файл удалить или переименовать стартовый сам
    запускает редактор и создаёт "заделочный" пустой файл для
    уровней пользователя ) В этом кстати главное отличие
    прошкиного Лэнда от первоисточника.
    ещё картинки из эмулятора
    на этой дискете http://zx-pk.ru/attachment.php?attac...5&d=1382237185
    Image  :   E2E4.dsk
    Format :   DSK
    Volume ID: RT11A
    Owner    :
    File       Blocks    Date       Bytes
    ELAN  .SAV    29P 16-Mar-2013     14'848  - стартовый файл
    LAND  .PID    23  08-Nov-1988     11'776   - уровни
  8. #337
    1,762
    684 сообщений
    67 Post(s)
    Вообще-то был уже, и запускался в EmuStudio)
  9. #338
    г. Караганда, Казахстан
    225
    177 сообщений
    17 Post(s)
    Не только. Главное - это перс может подпрыгнуть. Это открывает кучку дополнительных возможностей по прохождению, но есть и такие места, которые без прыжков не пройдешь - тот же 5-й уровень, справа внизу. На 85-й прыжок вызывался кнопкой ПФ2. То есть прыгал он и еще по каким-то кнопкам, не помню, но прыгать кнопкой ПФ2 было очень удобно. В EmuStudio я нашел прыжок только по стрелочкам, что гораздо менее удобно.
    А редактор лабиринтов вызывался и как-то отдельно, не только с отсутствующим LAND.PID
    ---------- Post added at 13:01 ---------- Previous post was at 12:32 ----------
    hobot, кстати, где-то в моих архивах, в файл-образе DISK1.RT есть смвольный вариант Тетриса, называется KOMP8.SAV, там сыплются фигурки из переменного числа кубиков - от 1 до 5, если в архиве его нет, можно добавить. Довольно забавно.
    Последний раз редактировалось AFZ; 20.03.2015 в 10:03.
  10. #339
    Зеленоград
    370
    309 сообщений
    Пожалуйста выкладывайте ссылки на любые уже оцифрованные материалы или
    оцифровывайте если что то ещё на дискетах, старых ЖД или перфокартах )))
    Для архива интересно всё !
    KOMP8.SAV
    Что то я не отыскал, может быть выдернете его отдельно )
    По поводу LAND для Э-85 я не знаком с этой машинкой и практически не знаю
    нюансов - в частности и с этой игрой связанных, то что я знаю, выяснялось на
    этапах написания поддержки этой игры в эмуляторе Титуса.
    Ещё раз касательно ЭМУЛЯТОРА XHomer - я сразу же вместе с Лэндом подпихнул ему RT-11 V5.7 hard disk image от form'a - очень качественно работает, игра играется и система (насколько я вижу) полная (!) с поддержкой современной даты ) Можно в теме эмуляторов отечественных ПК - создать отдельную тему по XHomer и там все связанные с образами для него и технические вопросы обсуждать.
    В том числе и игры под эмулятором )
    bonus
    Последний раз редактировалось hobot; 20.03.2015 в 18:30.
  11. #340
    225
    177 сообщений
    17 Post(s)
    Нашел я свой диск с LAND'ом https://yadi.sk/d/n4GyDI-efPmrP
    Да, заодно нашел кучу игрушек, но сортировать пока некогда. Еще, вроде-бы, нашел вильнюсский бейсик для КГД. А еще я нашел QUASIC, он, вообще-то перфоленточный, на "голом" железе, но я при помощи лома, кувалды и какой-то матери прикрутил его к RT-11, чтобы можно было сохранять программы на диск. Строго не-ПРО. QUASIC, как только найду доку, сразу выложу, остальные материалы - даже и не знаю, когда будет время отсортировать.
    Последний раз редактировалось AFZ; 20.03.2015 в 21:25.
  1. Учебный комплекс НЕМИГА.
    от felix в разделе ДВК, УКНЦ
    Ответов: 401
    Последнее: 21.06.2023, 16:17
  2. Эмулятор НЕМИГА
    Ответов: 310
    Последнее: 04.05.2019, 18:27
  3. Игры в sna
    от DRILL в разделе Игры
    Ответов: 17
    Последнее: 30.03.2010, 22:43
  4. Твоя игра-4. Обсуждаем правила
    от axor в разделе Игры
    Ответов: 50
    Последнее: 10.09.2009, 18:09
  5. игры про ВОВ
    от White_Hunter в разделе Игры
    Ответов: 27
    Последнее: 26.12.2008, 13:18
