Oleg N. Cher (11.03.2021)
Кто подключен ко мне по IPNET/MultiNet, новый IP адрес 178.205.143.174.
Имя pdp-11.online тоже годится.
PMI: KDJ11-BF, MSV11-JE
VT220, CM7209
hobot (31.03.2021)
Всем править CTAKAH.cfg для эмулятора VT52 Patron'а
Код:Welcome to PDP-11.ONLINE :: CTAKAH >HEL Account or name: GUEST Password: RSX-11M-PLUS V4.6 BL87 [1,54] System CTAKAH 31-MAR-21 04:14 Logged on Terminal TT52: as GST6 Good Morning ,;, O(o o)O +---ooO-----------Ooo----------------------------------------------+ | # # # ## # | | # ## ## # | | #### #### #### # # ### # ### # ### # ### ### | | # # # # # # ### # # # # # # # # # # # # | | # # # # # # # # # # # # # # # # ##### | | #### #### #### ### ### # ### # # ### ### # # # | | # # ### | | # # CTAKAH:: RSX-11M-PLUS V4.6 | +------------------------------------------------------------------+ Last interactive login on Tuesday, March 30, 2021 23:45:19 (TT53:) Last batch login on Tuesday, March 12, 2019 22:10:00 See http://pdp-11.org.ru/~form/ctakah.html for more information. $ HELP For HELP on logging in, type HELP LOGIN. Help is available for DCL commands, utilities, and system features. You can receive help by typing either HELP or ? after the DCL prompt ($) followed by the desired topic. For example, for help on the COPY command, type either HELP COPY or ? COPY. (The examples in the HELP files indicate only the first of these two formats in order to save space.) Also note that you can type help requests in either upper case or lower case. Help is available for the following DCL commands: ABORT COBOL DELETE INSTALL PRINT START ALLOCATE CONTINUE DIFFERENCES LIBRARY PURGE STOP ANALYZE CONVERT DIRECTORY LINK RELEASE SUBMIT APPEND COPY DISMOUNT LOGIN REMOVE TYPE ASSIGN CORAL EDIT LOGOUT RENAME UNFIX BACKUP CREATE FIX MACRO REQUEST UNLOCK BASIC DEALLOCATE FORTRAN MCR RUN BROADCAST DEASSIGN HELP MERGE SET Dates CANCEL DEBUG HOLD MOUNT SHOW CCC DEFINE INITIALIZE PASCAL SORT For information on a command, type: HELP commandname. Additional help on a command qualifier is often available by typing: HELP commandname qualifier. For the short forms of some commands, type: HELP BRIEF. For information on utilities and system features, type: HELP MORE. $ RUN GANG В МРАЧНЫХ ПОДЗЕМЕЛЬЯХ СТАРОГО ГАПА ЗАСЕЛИ 20 ГАНГСТЕРОВ. ХЕР ИХ ЗНАЕТ ЧЕГО ИМ ТАМ ПОНАДОБИЛОСЬ. МОЖЕТ БЫТЬ ХОТЯТ ОНИ ЗАХВАТИТЬ НАШИ СОЦИАЛИСТИЧЕСКИЕ CM-1420 ДАБЫ ПОДОРВАТЬ МОГУЩЕСТВО НАШЕЙ РОДИНЫ И УСИЛИТЬ МИРОВОЙ ИМПЕРИАЛИЗМ. БЫТЬ МОЖЕТ ХОТЯТ ОНИ РАЗОБРАТЬ КОРЗИНЫ И ПРОДАТЬ ИХ НА ДРАГ-МЕТАЛЫ... А МОЖЕТ БЫТЬ ХОТЯТ ОНИ СОВЕРШИТЬ СТРАШНОЕ ЗЛОДЕЙСТВО И ЗАПУСТИТЬ ЗЛОЙ SHUTUP, ЧТОБЫ ПОМЕШАТЬ СОВЕТСКИМ ПРОГРАММИСТАМ В ИХ ВЕЛИКИХ НАЧИНАНИЯХ. И НИКТО НЕ МОЖЕТ НИЧЕГО ПОДЕЛАТЬ - СЕРГЕЙ ФЕДОРОВИЧ УЕХАЛ НА АЛТАЙ, А ИГОРЕК ВООБЩЕ НЕИЗВЕСТНО ГДЕ... СЛОВОМ ВСЯ НАДЕЖДА НА ВАС! ВЫ ГОТОВЫ ВСТУПИТЬ В СМЕРТЕЛЬНУЮ СХВАТКУ С ВРАГОМ? НЕТ ВОТ ИЗ-ЗА ТАКИХ ТРУСЛИВЫХ И ПОНАСТАВИЛИ ВЕЗДЕ ВИНДОВСОВ... $ LOGOUT $ @LB:[1,2]SYSLOGOUT.CMD $ @ <EOF> $ Connect time: 0 hrs 5 mins 9 secs CPU time used: 0 hrs 0 mins 4 secs Task total: 28 Have a nice day 31-MAR-21 04:19 TT52: logged off CTAKAH $ Welcome to PDP-11.ONLINE :: CTAKAH >
Последний раз редактировалось hobot; 31.03.2021 в 00:20.
Некоторые особенности P/OS в том виде в каком он устанавливается
VT220, CM7209
После запуска test.tsk пользователь стал привилегированным?
Скорее всего это делалось для доступа к графике, а полновесной защиты не предполагалось - комп-то по сути персональный
Код:.TITLE BE .MCALL ATRG$S,CRAW$S,DIR$ ;SYSTEM MACRO CALLS .MCALL EXIT$S,RDBBK$,WDBBK$ ; .MCALL TCBDF$,UCBDF$ ;EXEC MACRO CALLS TCBDF$ ;DEFINE TCB OFFSETS UCBDF$ ,,TTDEF ;DEFINE UCB OFFSETS PSW = 177776 ;PROCESSOR STATUS REGISTER KPAR0 = 172340 ;KERNEL PAR'S KPAR1 = 172342 ; KPAR2 = 172344 ; KPAR3 = 172346 ; KPAR4 = 172350 ; KPDR0 = 172300 ;KERNEL PDR'S KPDR1 = 172302 ; KPDR2 = 172304 ; KPDR3 = 172306 ; KPDR4 = 172310 ; UPAR0 = 177640 ;USER PAR'S UPAR1 = 177642 ; UPAR2 = 177644 ; UPAR3 = 177646 ; UPAR4 = 177650 ; UPDR0 = 177600 ;USER PDR'S UPDR1 = 177602 ; UPDR2 = 177604 ; UPDR3 = 177606 ; UPDR4 = 177610 ; RDB:: RDBBK$ ,CTPAGE,,RS.RED!RS.WRT ;RDB WDB:: WDBBK$ 7,200,,,,WS.MAP!WS.WRT ;WDB START:: ATRG$S #RDB ;ATTACH REGION BCC 20$ ;BRANCH IF OK MOV #"AT,R0 ;ERROR CODE 10$: MOV $DSW,R1 ;GET $DSW BPT ;ABORT 20$: MOV RDB+R.GID,WDB+W.NRID ;COPY REGION ID CRAW$S #WDB ;CREATE ADDRESS WINDOW BCC 30$ ;BRANCH IF OK MOV #"CR,R0 ;ERROR CODE BR 10$ ;ABORT 30$: BIS #340,@#PSW ;RAISE CPU PRIORITY MOV @#UPAR0,-(SP) ;SAVE USER PARS MOV @#UPAR1,-(SP) ; MOV @#UPAR2,-(SP) ; MOV @#UPAR3,-(SP) ; MOV @#UPAR4,-(SP) ; MOV @#UPDR0,-(SP) ;SAVE USER PDRS MOV @#UPDR1,-(SP) ; MOV @#UPDR2,-(SP) ; MOV @#UPDR3,-(SP) ; MOV @#UPDR4,-(SP) ; MOV @#KPAR0,@#UPAR0 ;MAP SYSTEM DATABASE MOV @#KPAR1,@#UPAR1 ; MOV @#KPAR2,@#UPAR2 ; MOV @#KPAR3,@#UPAR3 ; MOV @#KPAR4,@#UPAR4 ; MOV @#KPDR0,@#UPDR0 ; MOV @#KPDR1,@#UPDR1 ; MOV @#KPDR2,@#UPDR2 ; MOV @#KPDR3,@#UPDR3 ; MOV @#KPDR4,@#UPDR4 ; MOV $TKTCB,R0 ;GET OUR TCB MOV T.UCB(R0),R0 ;GET TI: UCB BIS #U2.PRV,U.CW2(R0) ;MAKE TERMINAL PRIVILEGED MOV (SP)+,@#UPDR4 ;RESTORE MAPPING MOV (SP)+,@#UPDR3 ; MOV (SP)+,@#UPDR2 ; MOV (SP)+,@#UPDR1 ; MOV (SP)+,@#UPDR0 ; MOV (SP)+,@#UPAR4 ; MOV (SP)+,@#UPAR3 ; MOV (SP)+,@#UPAR2 ; MOV (SP)+,@#UPAR1 ; MOV (SP)+,@#UPAR0 ; BIC #340,@#PSW ;LOWER CPU PRIORITY EXIT$S ;EXIT .END STARTКод:PMA TEST=LB:[1,5]EXEMC/ML,RSXMC/PA:1,SY:[]TEST .IF <EXSTAT> <> <SUCCES> .EXIT .OPEN TESTBLD.CMD .DATA TEST=TEST,LB:[1,5]POS.STB/SS .DATA / .DATA STACK=20736 .DATA WNDWS=1 .DATA // .CLOSE PAB @TESTBLD .IF <EXSTAT> <> <SUCCES> .EXIT PIP TEST.OBJ;*,TESTBLD.CMD;*/DE/NM
VT220, CM7209
AlexCherny (01.02.2024)
Забегу на минутку написать об изменениях...
Теперь системы pdp-11.online недоступны через telnet.
Вместо этого нужно использовать ssh.
Код:System Machine Emul HECnet SSH Guest account --------------------------------------------------------------------------- RSX-11M+ V4.6 PDP-11/94 SimH CTAKAH [email protected] GUEST RSX-11M+ V4.6 PDP-11/83 - BIGSYS - GUEST RSTS/E V10.1 PDP-11/94 SimH CCCP [email protected] 254,254 OpenVMS V7.3 MV3900 SimH XPEH [email protected] GUEST TSX+ V6.50 PDP-11/94 SimH - [email protected] GUEST
VT220, CM7209
AlexCherny (03.05.2024), vva (05.05.2024)
