Показано с 1 по 2 из 2
Тема: PS/2 scancode decoder
    Master Аватар для VELESOFT
    Praha
    Благодарностей: 380
    По умолчанию PS/2 scancode decoder
    Can anyone help me ? I need connect PS/2 keyboard to PIC/ATMEL/xxx and this cpu must convert scan code(s) to single byte for each key(can be ascii). For example if I press cursor key then PIC convert original group of scan codes to one byte (key number). This can be 7 bit value (0-127).
    After press key send PIC 7bit key code to 7 pins + set one pin of PIC to log.0 (hold key).
    After release key send PIC 7bit key code to 7 pins + set next pin of PIC to log.0 (sign release key).
    PIC must contain also input pin reset (in log.0 = reset/init keyboard) and must support multiple keys pressing (for example Q+P+SPACE).
    Master
    Благодарностей: 554
