Показано с 1 по 10 из 42
Тема: ZX Spectrum Evolution Graphic Compo 2014
    Guru
    Рязань
    Благодарностей: 1071
    По умолчанию ZX Spectrum Evolution Graphic Compo 2014
    Это объявление от Yerzmyey утонуло во время Forever, поэтому стоит напомнить:
    While this year edition of International Vodka Party we would like to organize a graphic compo especially for ZX Spectrum Evolution (320x200 in 16 colours out of 64-colours palette, each pixel can have its own colour).
    You don't have to be an owner of the machine (nor the compatible - ATM Spectrum model), the format is simple: ***BMP*** file, 320x200 resolution, 16 colours on the screen (out of the 64-colours palette of ZX Spectrum Evolution).
    You can recognize easily that the final file format is OK: the BMP file will be exactly 32118 bytes long.
    This gfx-mode is available for Spectrum world since 1991, but it wasn't used very often. Which now changes 'cause Eva is the only reasonable choice if one wanna get a new ZX model.
    2 pictures per author allowed.
    Unlike the converts – converted pictures are NOT allowed at all.
    We provide You a "zx_eva_palette.pal" file that You can load into Your favourite PC (and Mac possibly) gfx-editor and draw the compo picture(s).
    Example of loading the palette file into PaintShop:
    COLORS / LOAD PALETTE and... yes, "OPEN" file. Still, You can use only 16 colours out of those 64 ones.
    Check out the example BMP files, too.
    DOWNLOAD the palette FILE and example-pictures!
    Send Your works to yerzmyey AT poczta.onet.pl
    Sending 2 versions - signed and unsigned - might be a reasonable choice.
    ********Deadline - 16 August 2014********
    Note: if You didn't get any confirmation from me, that means I DIDN'T GET YOUR FILE!!!
    Note 2: We consider also making an on-line voting for everybody, after the party.
    Note 3: You can send as well the TRD/SCL 256x192 RGB format pictures (called also "8color" or 3"color" sometimes) but remember You can use there only 8 colours of standard ZX Spectrum palette, and such pictures will compete with Eva's pictures, so it might not be a "fair fight" (although the RGB gfx-mode is stable on ZX Evolution - it doesn't blink).
    Guru
    Рязань
    Помимо того, что bmp определённого формата можно смотреть прямо в Evo Reset Service, наш португальский товарищ Paulo Silva написал для ATM Turbo 2 специальный вьювер на бейсике (исходники прилагаются).
    Последний раз редактировалось alone; 04.04.2014 в 19:03.
    Banned
    г. Арзамас
    Благодарностей: 1075
    и что ждать от компо? ворох дизеринга?
  5. Этот пользователь поблагодарил denpopov за это полезное сообщение:
    scl^mc (03.04.2014)
  6. #4
    R.I.P. Аватар для Rindex
    Khimki
    Благодарностей: 5966
    Эта новость ещё с февраля висит - http://speccy-live.untergrund.net/20...ic-compo-2014/
    Ерз, кстати предлагает сам участвовать лично людям. Только что толку от конкурса? Конверченные картинки что-ли выставлять?
    Сбросив пару лишних мегатонн,
  7. Этот пользователь поблагодарил Rindex за это полезное сообщение:
    scl^mc (03.04.2014)
  8. #5
    Guru
    Рязань
    Читай внимательно. Конверченные картинки запрещены.
  9. #6
    Khimki
    А это вот с Фиатом, само нарисовано? Лучше бы под картинки демку сделали, на радость AAA.
  10. #7
    Guru
    Рязань
    Показанные картинки - НЕ С КОМПО. Это просто примеры.
  11. #8
    Khimki
    А где они задействованы будут потом, которые с компо? Специальная дема для них написана будет, или опять что-то вроде эффектов 1к, которые никому не нужны, кроме конкурсантов, только для Пентевы?
    ---------- Post added at 20:25 ---------- Previous post was at 20:14 ----------
    Просто вон, человек попросил, что-то никто не откликнулся. А это не для компо, а для игры, которая уже сделана. Палитра почти таже.
    http://zx.pk.ru/showthread.php?p=691035#post691035
    Последний раз редактировалось Rindex; 03.04.2014 в 19:19.
  12. #9
    Guru
    Рязань
    Это компо как раз для того, чтобы появились такие художники.
  13. #10
    Khimki
    Вообще-то они, художники, есть давно. Далее что будет с этими картинками? Иностранцы их в демо вставлять не будут, поскольку там только обычная палитра scr приветствуется.
  1. DiHalt 2014 Lite : Realtime Compo
    от TmK в разделе События
    Последнее: 05.01.2014, 19:23
  2. BEEPER music compo (ZX Spectrum 48K chiptune)
    от breeze в разделе События
    Ответов: 15
    Последнее: 16.08.2011, 18:00
  3. Battle Of The Bits ZX Spectrum Beeper Speaker Compo 2010
    от GibbS в разделе События
    Последнее: 16.11.2010, 04:58
  4. Stupid compo for ZX Spectrum graphic (53 colours, low-res)
    Последнее: 23.08.2009, 21:24
  5. RetroEuskal | 8Bits Graphic Compo
    от riskej в разделе Графика
    Ответов: 38
    Последнее: 05.08.2008, 17:26
