Страница 2 из 12 ПерваяПервая 123456 ... ПоследняяПоследняя
Показано с 11 по 20 из 117
Тема: ZEsarUX Emulator
    Guru Аватар для Shiny
    г. Арзамас
    31
    18 сообщений
    Sorry, I cannot explain(
    trick was in changix X and Y coordinates, so snowflakes fly on screen(both bit 9)
    Member
    Madrid, Spain
    34
    13 сообщений
    Well I'm considering a 9-bit number for X coordinate, so values are from 0...511
    Because the pixel resolution is not as long as 511, I consider that X position 511 is at the right-end and not visible zone on the screen, so if you consider a video mode with 320 pixels width, you will only see sprites with pixel position between 0..319, and 320 to 511 are not visible.
    But If you think the 9-bit number can have sign, you have values from -256 to 255, a value of 511 for me it's -1 for you, and if you consider -1 position as at the left part on the screen (or at the right-end of the screen), it's the same position as I'm considering, so it doesn't matter if you consider always positive or a number with sign
    Looking at the demo, there are two snowflakes fixed at the top or at the bottom, the X coordinate is fixed, so I think the bug comes from another side... I will talk with g0blinish (the author of the demo) and ask about it
    Thanks
    Just fixed the snowflakes bug
    I had a bug which made it impossible to write on fmaps position 200h or 400h...that's why the Y position was always 0 or 256...
    Последний раз редактировалось chernandezba; 14.03.2018 в 17:23.
    г. Арзамас
    31
    18 сообщений
    lol.
    there are a lot of demos to test emulation: Raster, Fast, etc.
    Member
    Madrid, Spain
    34
    13 сообщений
    Yes, curiously, I haven't noticed any Y-coordinate bug on other demos/games, but I will have to test all of them
    For those who are curious, the bug is: (in diff format)
    diff --git a/src/tsconf.c b/src/tsconf.c
    index 1f762dc..48db19e 100644
    --- a/src/tsconf.c
    +++ b/src/tsconf.c
    @@ -69,12 +69,12 @@ void tsconf_write_fmaps(int tsconf_fmaps_offset,z80_byte valor) {
    tsconf_fmaps[tsconf_fmaps_offset]=valor;
    - if (tsconf_fmaps_offset>0x200 && tsconf_fmaps_offset<0x400) {
    + if (tsconf_fmaps_offset>=0x200 && tsconf_fmaps_offset<0x400) {
    //printf ("Zona tsconf sprites\n");
    - if (tsconf_fmaps_offset>0x400 && tsconf_fmaps_offset<0x500) {
    + if (tsconf_fmaps_offset>=0x400 && tsconf_fmaps_offset<0x500) {
    //printf ("Zona tsconf registers\n");
    //Solo escribe en regustro tsconf. no en ram fmaps
    tsconf_write_af_port(tsconf_fmaps_offset-0x400,valor);
    г. Арзамас
    31
    18 сообщений
    Rasters - there are no raster effect on background
    Fast - twister effect with lack of tile layer (with flipY flag)
    TSLbrains - no picture on screen
    and last one: Merhaba without scroller (letters is sprites too)
    Activist Аватар для Kalantaj
    г. Кривой Рог, Украина
    40
    20 сообщений
    chernandezba, can you make deb-package for 32 and 64bit Linux (Mint, 18.3)?
    I'm beginner in linux world and can't make deb, but want try your emultor.
    Member
    Madrid, Spain
    34
    13 сообщений
    Thanks. That twister effect is almost killing me :P My first tsconf render routine does show the entire twister, but that routine was clearly wrong (lots of features not emulated). Some day will run perfect (I hope!)
    Will I only make executable Linux versions for stable versions, not beta, and they are compatible with Linux debian 9 (the one I have) , but I don't know if they run on Mint
    It's very easy to compile it... take a look at the INSTALL file
    Just go to https://github.com/chernandezba/zesa.../v6.1-13032018
    I have added a debian 9 binary version
    Just uncompress it, enter to directory ZEsarUX-6.1 and run ./zesarux
    г. Арзамас
    31
    18 сообщений
    well, maybe it helps debugging(
    40
    20 сообщений
    Thanks, but i'm installing on my Mint, using INSTALL file instrution.
    And now time to tests
    Member
    Madrid, Spain
    34
    13 сообщений
    Oh great. If you have problems compiling it, please tell me or try the debian 9 version
    Thanks, I will test it
  1. Speccy emulator
    от Rindex в разделе Эмуляторы
    Ответов: 53
    Последнее: 13.07.2022, 22:50
  2. CHIP8 Emulator
    от NEO SPECTRUMAN в разделе Софт
    Ответов: 37
    Последнее: 05.11.2020, 22:24
  3. Agat Emulator v1.26.1
    от Rindex в разделе Apple
    Последнее: 15.02.2014, 22:02
