Показано с 1 по 10 из 12
Тема: Help emulating baseconf
    Member
    Madrid, Spain
    36
    14 сообщений
    По умолчанию Help emulating baseconf
    Hi
    I'm planning to add BaseConf emulation to ZEsarUX. I tested adding basic I/O memory paging ports but I'm not sure what is the default rom page at boot. One should suppose it's page 0, but page 0 on zxevo.rom has nothing but garbage... Seems roms start at 20000H offset, but I don't know which is the default at boot (range from 0...31)
    Anyone can help me?
    I have read some documentation , even the translated tech info to english
    http://svn.zxevo.ru/filedetails.php?...ration_eng.odt
    But I don't find that info
    Thanks a log
    Cesar
    Guru Аватар для SAM style
    Великий Новгород
    220
    93 сообщений
    On reset baseconf sets last ROM page in every window (#0000, #4000, #8000, #c000)
    Все любят гипножабу
    Member
    Madrid, Spain
    36
    14 сообщений
    Thanks. Booting the last rom and it first do the following out:
    port BC77H value 02H
    That means:
    A8: if 0, then disable the memory manager. In each window processor is installed the last page of ROM. 0 after reset. -> memory manager disabled. Put last rom page on all segments
    A9: A9: If 0 then "force" the inclusion of TR-DOS and the shadow ports. 0 after reset. -> No tr-dos
    After that , the following out:
    port 7FFDH value 10H
    So, how I suppose to react to this? According to this port, like a 128k, I should map ram 0 on segment c000h-ffffh, and map rom 1. What is rom 1 in this memory schema? I have rom 31 mapped...
    And... what will be the segments after that out?
    0000h : rom1?
    4000h: rom31? (untouched). or ram 5 (as default 128k)
    8000h: rom31? (untouched). or ram 2 (as default 128k)
    c000h: ram 0?
    Thanks
    Великий Новгород
    220
    93 сообщений
    If memory manager disabled, there is allways last rom page in all banks (exception is ram page 0 to #0000)
    All values writed to memory ports (#xxF7, #7FFD) is working only if memory manager is enabled
    Все любят гипножабу
    Member
    Madrid, Spain
    36
    14 сообщений
    Sorry, what is this exception? Thanks
    Великий Новгород
    220
    93 сообщений
    bit 3 of value writed to port #EFF7: 1 - set ram page 0 to #0000;
    Все любят гипножабу
    Member
    Madrid, Spain
    36
    14 сообщений
    Thanks! Added. I still haven't suceeded booting baseconf but.... I think I will get it soon
    You seem to know a lot about baseconf
    There are some technical details on the documentation which are not clear to me. For example:
    Port #xx77
    Enable shadow mode ports of the memory manager's permission.
    How is tr-dos "forced"? I suppose it changes the current rom page in some kind... how?
    Thanks
    Великий Новгород
    220
    93 сообщений
    Thanks
    It doesn't switch page at #0000, it just says "shadow ports is available even when trdos is off"
    If you know C/C++, you can examine sources of my emulator Xpeccy - http://github.com/samstyle/Xpeccy Baseconf ports and memory maping is in ./src/libxpeccy/hardware/pentevo.c
    Последний раз редактировалось SAM style; 10.04.2018 в 19:51.
    Все любят гипножабу
    Member
    Madrid, Spain
    36
    14 сообщений
    Oh that explains everything I will take a look, thanks! ZEsarUX is written on C, so I won't have problems reading your sources
    Member
    Madrid, Spain
    36
    14 сообщений
    Maybe there's some documentation I don't understand well. According to the docs, ports xFF7H should be handled, exactly the following:
    #3FF7 – Window #0000..#3FFF,
    #7FF7 – Window #4000..#7FFF,
    #BFF7 – Window #8000..#BFFF,
    #FFF7 – Window #C000..#FFFF.
    But in your Xpeccy code, you seem to handle the following xFF7H ports:
    0xbff7
    0xdff7
    0xeff7
    Why this difference?
    Thanks
  1. Экран и память у ZX-Evo BaseConf
    от Sayman в разделе Программирование
    Последнее: 10.01.2017, 21:26
  2. Пошил baseconf. и черный экран.
    от malmstream в разделе ZXEvo
    Последнее: 25.12.2016, 22:17
  3. DiHalt, baseconf & tsconf
    от Hacker VBI в разделе ZXEvo
    Ответов: 124
    Последнее: 22.10.2013, 13:21
  4. [PentEvo] TSConf+BaseConf одновременно!
    от breeze в разделе ZXEvo
    Ответов: 96
    Последнее: 07.06.2013, 21:24
  5. Игры для ZXEvo (baseconf) из СР/М
    от DimkaM в разделе Игры
    Ответов: 71
    Последнее: 09.08.2012, 21:24
