Страница 1 из 9 12345 ... ПоследняяПоследняя
Показано с 1 по 10 из 85
Тема: Zx Windows :-)
    Junior
    Italy
    Благодарностей: 3
    Post Zx Windows :-)
    Hi! I'm new here. My name is Stefano and I am from Italy :-)
    SymbOS (www.symbos.de) is a "Windows like" operating system for Z80 computers (Cpc and Msx for now) and it is possible to port it in Zx +3. I think is possible also to run it in Pentagon, Scorpion, Atm Turbo and Sprinter.
    Features: REAL MULTITASKING * 576KB DYNAMIC MEMORY *
    * 128GB FILESYSTEM * 100% WINDOWS GUI. I have written to author and he wrote to me is possible to port it on Zx +3 (only +3 'cause limitation with ram pages). It is necessary to modify code you can find here: http://www.symbos.de/download.htm. It is incredible! See the amazing video here: http://www.symbos.de/videos/trexsymbos1.zip
    This is reply to the email to the author of the project:
    Hi Stefano,
    Sorry for this very late answer, somehow your email got lost first. Thanx for your interest in SymbOS. I think a Spectrum port would only be possible for the Spectrum +3 because of the memory bank switching requirements. Even the Sam Coupe wont be able to handle it completely because of its 32k block limitation.
    On the other hand I wonder if a new memory expansion would be possible for all Spectrums, which is able to provide the required bank switching possibilities.
    The memory is always the most important thing for a port (beside the Cpu of course ;-).
    But Doors is already a very great Windows OS and it is perfectly designed for the Spectrum graphic. So I am not sure, if SymbOS would make sense?
    Cu,
    Prodatron
    dig out your soul Аватар для scl^mc
    Russia, Ulianovsk
    Благодарностей: 1197
    i'm really shocked by that! and i really want this on my computer. and i'm ready to buy spectrum version
    speccy merchandise
    Master Аватар для Surfin_Bird
    Беларусь, Минск
    Благодарностей: 38
    Oh my god! I want it on my ZX!
    Activist Аватар для acidrain
    Russia, Krasnodar
    Благодарностей: 1
    Symbos is quite interesting, but if it will handle all russian clones and ofcoz TRDos. If there is a way to make it compatible with all russian hardware then it is the best OS for ZX atm!!! *
    Keeping my fingers crossed for it 8)
    * - at the moment, not the ATM Turbo
    Последний раз редактировалось acidrain; 05.11.2006 в 13:46.
    http://amigasc.nm.ru
    Free coder and hardwareman
    Amiga addicted
    Junior
    Italy
    Благодарностей: 3
    yes is possible to run SymbOS on clones: has clones memory mapping as a +3? I think yes.
    Anyway..... go to download section and change machine code (addresses) to memory location and the SymbOS could run also on clones
    Russia, Ulianovsk
    i saw demovideo file, and all that i can say is... fuckin' amazing!!! you can play the music, video and see some pictrures at the same time. and also working in command line. absolutely perfect
    speccy merchandise
    Member Аватар для cyrax inc
    Саратов
    Благодарностей: 0
    i don't imagine how the multitasking is possible on ZX. or it's so-called cooperative multitasking (windows3.11-like)? the software interrupts are so slow and can be disabled, so i think it isn't a way to go.
    Последний раз редактировалось cyrax inc; 05.11.2006 в 19:52.
    この悲しみは何時かきっと優しさに成る
    貴方に逢えた丘の上星が降る
    Критик - человек, рассуждающий о том, как бы правильно сделал он сам... если бы умел.
    Sony PS2 SCPH-70008 et Sony PS3 Eur 2.10
    Banned Аватар для Black_Cat
    S.Pb
    Благодарностей: 231
    Z80 CPU with 24MHz...
    Russia, Krasnodar
    Благодарностей: 1
    Wor you meant?
    S.Pb
    Благодарностей: 231
    Цитата Сообщение от acidrain
    Wor you meant?
    Video of the CPC TREX running SymbOS in Turbo Mode. The CPC TREX Turbo Mode=24MHz.
  1. Утилиты для работы с дисками TR DOS из Windows NT
    от Alexandr Medvedev в разделе Утилиты
    Ответов: 47
    Последнее: 16.06.2014, 10:16
  2. Утилиты для работы с дисками iS DOS из Windows NT
    Последнее: 07.09.2006, 12:17
  3. Mined Out. Аналоги под Windows?
    от Vitalik в разделе Игры
    Последнее: 29.06.2005, 23:23
