Показано с 1 по 5 из 5
Тема: TRDOS VERSIONS
    Master Аватар для VELESOFT
    Praha
    Благодарностей: 380
    По умолчанию TRDOS VERSIONS
    What TRDOS version is complette bug-fixed ?
    What TRDOS version is best for using with russian software ? Exist detailed info about differences midst original trdos 5.03 and russian versions ? Source codes is available ?
    http://www.zxspectrum.it/_TR.htm
    Activist Аватар для Adramelek
    USA
    Благодарностей: 19
    Probably it's 6.10E.
    Write to Alone Coder (dmitry.alonecoder@gmail.com). He's an author of 6.10E... and he's still around.
    Veteran Аватар для bigral
    Kiev/Ukraine
    Благодарностей: 295
    I guess from the very begining we had ver 5.01 along with 5.03 and later someone changed disk timings and released 5.04T (kinda TURBO version with read/write operations aprox. 3 times faster than original 5.03).
    Anyway the main article about TRDOS in exUSSR the book of Nicolas Rodionov "ZX spectrum for users and programmers" was released around 1991. Before this book out many believed there is no way to program FDC controller directly and used only well defined TRDOS interface calls which is the same for TRDOS 5.01 and 5.03/5.04T; but in the book Rodionov described method how to perform ordinary in/out operation to FDC on both 5.01 and 5.03 calling some parts of routines in TRDOS roms. Essentially that was good initiative to show programmers way of read/write protected disks and make special read/write procedures like those playing AY music during loading, but initial intention wasn't completely reached because many programmers go further and start use this way to call specific procedures for 5.04T that was not available in 5.01 or located on other address. So, in later period many programs appeared that worked with 5.03/5.04T only but not with 5.01, that lead to almost complete replacement of 5.01 ROMs with 5.04T (around 1992 and later).
    Member Аватар для cr0acker
    Благодарностей: 1
    5.13H forevah
    Формат конференции позволяет сказать то что я действительно думаю о проблемах....и если мои рассуждения покажутся нашим коллегам излишне полемически заостренными, либо не точными, прошу на меня не сердится это ведь только конференция (с) Путин
    Guru Аватар для rasmer
    Саранск
    Благодарностей: 140
    Цитата Сообщение от cr0acker Посмотреть сообщение
    5.13H forevah
    Чем корявым англиЦким, лучше бы на великом и могучем ответил - VELESOFT его неплохо понимает...
    Мои интры: [Kukarachess][Super boot rmx][tRUSHE MOSAIc][BLAZE]
    Мои игры: [Overload][Removal]
    Список игр для ZX-Spectrum: [2015] [2014]
  1. Приобрел ZX Spectrum 128 trdos
    от harushima в разделе Unsorted
    Ответов: 38
    Последнее: 18.12.2014, 20:43
  2. TRDOS rom with monitor
    от VELESOFT в разделе Оси
    Последнее: 12.08.2007, 16:53
  3. Объединение файлов в TRDOS
    от moroz1999 в разделе Софт
    Последнее: 21.01.2007, 22:58
  4. Ответов: 2
    Последнее: 17.08.2006, 09:42
