Показано с 1 по 10 из 34
Тема: можно/нужно ли Video9000 подрубить к ZX?
    Guru Аватар для bigral
    г. Киев, Украина
    95
    82 сообщений
    По умолчанию можно/нужно ли Video9000 подрубить к ZX?
    Вот уже прошло 3 года с тех пор как v9990 обсуждается на форуме в качестве add-on видеопроцессора для спектрума "...а воз и ныне там!" (c) Крылов. Между тем сделанная для MSX плата вроде как еще до сих пор продается и в описании к ней написанно:
    Video9000 a high quality digitizer and superimposer for the MSX-2/2+/turboR computer. You can grab pictures from a videofilm/videocamera/TV or gamesconsole in 32768 colours, superimpose parts of it with animations and titles upon video images, mix your own creations with these video images, etc. Furthermore you can switch from MSX 2/2+/turboR screen to GFX9000 screen and vice versea just by one simple command.
    You should now see the normal MSX boot-up screen, as was the case when not having a Video9000 and GFX9000 at all. Because the Video9000 has an integrated RGB switch, such a device is not necessary anymore.
    With the aid for the digitize function of the Video9000 you can `freeze` (moving) images of the every standard PAL video source, like a VCR, camera, camcorder or TV receiver(tuner). This digitizing is performed real time (50 pictures per second) and 32768 colours are used.
    Digitization is only possible in the full colour bitmap screen modes, i.e. the B1,B2 and B3 modes.
    Superimpose is the effect that a moving or non-moving video images is covered by (parts of) a second image. In the case of the Video9000, this second images is the graphical screen produced by the GFX9000. At those places the graphical screen is made trasparent, the moving video scene is visible. The subtitling of foreign TV films, teh overlaid scores of a football game in sport programs on TV, but also the weather broadcasting programs (the maps with clouds and suns are superimposed upon the background) are examples of superimposing.
    Of course any graphical image and/or animation can be superimposed upon the external video source.
    по описанию просто бомба! можно ли как-нибудь это все получить на том же Ленинград-1/2 ?
    Guru Аватар для Sayman
    91
    54 сообщений
    ИМХО, никто и никогда не прикорытит никаких карточек к спекку..в россии во всяком случае...можно просто забыть об этом и юзать то, что даёт твой клон...
    0A заповедей:
    I. Не удаляй каталог свой.
    III. Не кради файлы.
    Sprinter resurrect:
    Telegram
    Discord
    Repo
    Forum
    Activist
    Planet Earth
    SunRise SlotExpander и Video9000 не производится уже как минимуи декаду. А вот партию новых GFX9000 и Moonsound сделали в 2006-м году, все желающие затарились :P
    А будет ли 9900 на спектруме или нет зависит целиком и полностью от CHRV. Если он произведёт партию собранных плат и конструкторов для сборки, как он сделал с PAL-coder и TurboSound/TurboSound FM, то будет
    Последний раз редактировалось dhau; 02.06.2008 в 22:06.
    Guru Аватар для Lethargeek
    Воронеж
    238
    187 сообщений
    Video9000 нельзя подрубить даже напрямую к MSX, это несамостоятельный довесок для GFX9000 Которую видимо можно для любого компа на z80 адаптировать - однако наверняка проще тридевятый с нуля прикрутить, к тому же он и так емнип генлоком работает.
    А в чем собс-но кайф ваяния субтитров на Спеке?
    Последний раз редактировалось Lethargeek; 03.06.2008 в 01:59.
    г. Киев, Украина
    95
    82 сообщений
    В смысле у v9990 есть входы для кадровой и строчной???!!! Идея все та же снабдить speccy экран пачкой цветных спрайтов при минимальной нагрузке на z80.
    Guru Аватар для fan
    Вот только нужны ли пачке спрайтов спековый экран Тем более что экран у разных спеков "гуляет как хочет" и имеет достаточно разнообразную ширину
    И опять без VGA выхода остаёмся . С матрицами (за те же деньги) то и другое достаточно просто решается .
    г. Киев, Украина
    95
    82 сообщений
    тут 2 варинта ответа:
    - если "да" то увидим старую игрушку и по мере доработок к ней куски новой графики которые можно добавить к уже имеющимся или некрасивые имеющиеся заменить новыми;
    - если "нет" то это по сути будет комп с двумя видеокартами (например как C128) потенциально работающий на 2 монитора (или поочередно врубающий то один то другой выход);
    вариант 2 уже проходили - видеопроцессор Веремеева (dendy);
    эта техническая проблема не имеет решения совсем?
    По-моему тут всетаки NEMO был прав vga - dead end. Много кто продолжает спикулировать на эту тему что мол спек возможен на VGA на самом деле результатом будет такая же картинка как spectaculator показывает со всеми вытекающими. Это всеравно что VECTREX подрубать к телику.
    решения в студию!
    Воронеж
    238
    187 сообщений
    Сильно красиво делать одни только спрайты - глаз будет резать
    (придется спектрумовский спартанский стиль сохранять)
    Настройка ручками после загрузки, а-ля мультиколоры
    Guru Аватар для fan
    Боюсь что совсем (покрайней мере для клонов имеющих слишком узкий или слишком широкий экран) .
    Вслучии юзанья матрицы можно просто излавливать то что пихается в видео мозги и показывать адекватно (как на тв так и на мониторе).
    Если монитор не супортит 50гц то да .
    решения в студию!
    Гы Решения и так давно в студии пролетали .
    Определиться бы с начинкой платки .
    Activist Аватар для Romanich
    Владивосток
    Сразу предупрежу,что ориентируюсь только на спрайтовые режимы
    EMU Apparatchik Romanich
    http://emu-apparatchik.narod.ru
  1. Подрубить SEGA к ТВ
    от Surfin_Bird в разделе SEGA
    Последнее: 27.12.2008, 14:50
  2. Как подрубить метр ОЗУ в Alasm
    от Retrograd в разделе Программирование
    Последнее: 26.02.2007, 20:47
  3. ПОМОГИТЕ подрубить монитор
    от D-M в разделе Изображение
    Ответов: 22
    Последнее: 26.02.2007, 12:22
  4. Хелп! Надо подрубить моник..
    от sp0t в разделе Изображение
    Последнее: 12.03.2005, 06:37
