Показано с 1 по 8 из 8
Тема: maximal size of TRD image
    Master Аватар для VELESOFT
    Praha
    Благодарностей: 380
    По умолчанию maximal size of TRD image
    Maximal size of TRD image - calculation:
    - max. 16 sectors per track
    - max. 256 tracks (0-255) per one disk side
    - max. 2 disk sides
    complette size:
    16(sectors) x 256(tracks) x 2(sides) = 8192 sectors x 256 bytes(sector size) = 2048 kB = 2 MB.
    Exist TRD creator(utility) with support this max. size limit ?
    Can ZX emulators on PC work correct with bigger TRD images than 640kB ?
    I find on my HDD any TRD images with different length than 640kB (720kB and more < 640kB)
    VELESOFT
    Veteran Аватар для GriV
    Набережные Челны
    Благодарностей: 104
    Usually no.
    Unreal ZX emulator can't use large (more than 83 tracks) trdos disk images - internal checking disable all tracks after 83 (even if it presents). And size of .TRD files can't be greater than 640K.
    SCL files can contain more than 80-84 tracks, but you cant' is it because of track checking.
    Supported both 640K images and cutted of .TRD files.
    Cutted images does not contain zero-filled tracks at end of disk, at all.
    I never (maybe I forgive it?) see .TRD images more than 640K.
    Current utilities (AMD01, SpectrumNavigator, plugins for FAR) does not support larger than 640K size of .TRD files.
    Последний раз редактировалось GriV; 19.10.2008 в 16:35. Причина: Добавлено сообщение
    Биты рулят лучше байтов, байты рулят шустрее!
    View, Звук, Цвет
    Master Аватар для boo_boo
    Благодарностей: 14
    are you speaking about maximum capacity that TRD file format can provide?
    yes, it may hold that much data, but this is incompatible with any ZX/TR-DOS emulators, since most capacious media supported by TR-DOS hardware/software is DS/DD floppies (standard capacity: 80tracks x 2sides x 16sectors x 256bytes = 640kB, max capacity: 86tracks x 2sides x 16sectors x 256bytes = 688kB)
    Последний раз редактировалось boo_boo; 19.10.2008 в 16:51.
    Praha
    Благодарностей: 380
    This is TRD image created on SPECTRUM NAVIGATOR on PC (size 1MB = 128 tracks):
    http://velesoft.speccy.cz/other/1mb_trd.zip
    And this is bigger TRD images finded on my HDD:
    http://velesoft.speccy.cz/other/big_trd_images.zip
    VELESOFT
    Благодарностей: 14
    it seems that these files (except for 240ds.trd which is simply broken) were made with PC software that doesn't care whether TRD images are valid.
    none of ZX/TRDOS emulators can deal with extra space at the end of these images, though some of them may be able to handle first 640/688kB.
    Последний раз редактировалось boo_boo; 20.10.2008 в 01:52.
    Moderator Аватар для elf/2
    N.Novgorod
    Благодарностей: 117
    after looking on xTRD 1.0 sources I see that it should support big .trd images. the plugin checks for tr-dos signature (0x10 at 0x08e7) and that file size is divisible by 16*256
    at the same time it does not allow creation of images bigger that 640K
    Member Аватар для Antipod
    Украина, Львов
    Благодарностей: 10
    - max. 2 disk sides
    complette size:
    VELESOFT
    в принципе возможно - пчему нет?
    только, вроде, существующий спековский софт не поддержит дисков на 256 дорожек, максимум - 128, птому как, если склероз не подводит, под сторону и номер дорожки обычно отводится один байт.
    могу и ошибаться.
    вроде, даже при записи дальше 128 дорожки косяк будет, просто потому, что в каталоге под дорожку/сторону тож один байт...
    Последний раз редактировалось Antipod; 23.10.2008 в 14:47.
    Praha
    Благодарностей: 380
    могу и ошибаться.
    Yes, thank. One byte = 256 x 16sectors(4kB) = 1024kB=1MB.
    Only FDC controller(VG93) can use 256(tracks) x 2(sides) x16sectors(track size for trdos) = 256x2x4kB = 2MB disk image(but only first 1MB is usable in TRDOS).
    VELESOFT
  1. TRD image -> floppy disk
    от Error404 в разделе Утилиты
    Ответов: 13
    Последнее: 28.01.2007, 21:15
