Показано с 1 по 10 из 14
Тема: Question about Orel bk-08
    Junior Аватар для galine
    Flers, France
    По умолчанию Question about Orel bk-08
    Hello it's my first post here I hope I poste it in goos section.
    I have a Orel bk-08 since some week I like this computer and I would know if is it possible to connect a divide on it?
    I know the expansion bus is not in the same format but with a little chance with an adapter it will works.
    If it's doesn't I think I need found a beta disk interface cause tape loading is verry long and not verry stable.
    Thank you in advance for your help.
    Galine.
    Guru Аватар для zorel
    г. Днепропетровск
    8 сообщений
    Galine.
    Here it is sold to the assembled BETADISK OREL BC-08 http://zx-pk.ru/market/viewtopic.php?f=4&t=1013
    Wiring Diagram http://zx-pk.ru/showthread.php?t=158...EE%F0%E5%EB%FC
    ---------- Post added at 21:48 ---------- Previous post was at 21:45 ----------
    That's where I put the scheme eagle redraw itself, it is possible that there are errors in the diagram .. http://zx-pk.ru/showpost.php?p=362739&postcount=127
    Flers, France
    really thank you I will see that I forgot to ask if the Betadisk is compatible with the HXC?
    г. Днепропетровск
    8 сообщений
    And why would it not work with it) I can not check my emulator FDD not, but with floppy disk drives work fine ..
    Flers, France
    I think I can answer to this topic http://zx-pk.ru/market/viewtopic.php?f=4&t=1013 maybe I'm to young here for it?
    г. Днепропетровск
    8 сообщений
    You'd better register there and accomplish your goal that topic, something to the seller could sell you, if you decide to buy a controller.
    Последний раз редактировалось zorel; 24.06.2013 в 21:57.
    Flers, France
    Hummm... sometimes I'm not waken up thank you again ^^.
    Veteran Аватар для sergey2b
    13
    12 сообщений
    Yes it is
    Flers, France
    it's a verry good news for The HXC.
    In my research for have a "mass storage" solution for the Orel I fond this verry interesting pieces of hardware
    http://bk-evo.perestoroniny.ru/page/...eplika-smk-512
    but this last seems discontinued. -_-.
    13
    12 сообщений
    I think, this is for other copmuter bk-0010/11, it has not z80 CPU.
    You can check local clone of divide http://zx.pk.ru/market/viewtopic.php...719fa3a0f1f648, but Betadisk is better
  1. Question about "Lethargy:The Apathetic Dream"
    от skarpo в разделе Игры
    Последнее: 14.04.2007, 22:47
