Показано с 1 по 10 из 38
Тема: ROM files structure
    Master Аватар для VELESOFT
    Praha
    33
    14 сообщений
    По умолчанию ROM files structure
    What is structure of rom files bigger than 32kB ?
    Exist 64kB/128kB and 256kB roms for ZX emulators.
    32kB roms contain 128ROM + 48ROM.
    64kB roms contain also this roms + trdos + ???. Layout of this bigger roms is same for all emulators ? Different ZX clones use same rom layout ?
    Any info about bigger roms than 64kB ?
    Banned Аватар для Black_Cat
    S.Pb
    + Service ROM:
    - Gluk Reset Service - for Pentagon;
    - Kramis - for KAY;
    - MOA Shadow Monitor - for Scorpion.
    Yes.
    No.
    KAY, Pentagon:
    0 - Service
    1 - TR_DOS
    2 - SOS128
    3 - SOS48
    Scorpion:
    0 - SOS128
    1 - SOS48
    2 - Service
    3 - TR_DOS
    Praha
    33
    14 сообщений
    Цитата Сообщение от БК-0010 Посмотреть сообщение
    + Service ROM:
    - Kramis - for KAY;
    And any info about way to connect this rom to low 16kB ?
    After press NMI only ?
    After reset only ?
    Via OUT command ?
    KAY, Pentagon:
    0 - Service
    1 - TR_DOS
    2 - SOS128
    3 - SOS48
    After reset is set service rom ?
    After NMI jump CPU to service rom or to NMI code in TRDOS rom ?
    Scorpion:
    0 - SOS128
    1 - SOS48
    2 - Service
    3 - TR_DOS
    After reset is set SOS128 rom ?
    What abou NMI function ?
    S.Pb
    ROM, over 64K in the ZX Spectrum clone produced in the ex USSR did not apply. ATM and Sprinter are not clones of ZX Spectrum. This is a ZX Spectrum compatible computers such as SamCoupe.
    ---------- Post added at 00:15 ---------- Previous post was at 00:08 ----------
    After reset only ?
    Via OUT command ?
    - Gluk Reset Service - RESET - for Pentagon only
    - MOA Shadow Monitor - NMI or software - for Scorpion, ZXM-Phoenix
    - Kramis - software - for KAY, ZXM-Phoenix
    ---------- Post added at 00:18 ---------- Previous post was at 00:15 ----------
    Yes, for only Pentagon
    ---------- Post added at 00:21 ---------- Previous post was at 00:18 ----------
    Yes, for all clones except the Pentagon.
    ---------- Post added at 00:24 ---------- Previous post was at 00:21 ----------
    In Scorpion uses a modified ROM.
    Praha
    33
    14 сообщений
    Scorpion:
    0 - SOS128
    1 - SOS48
    2 - Service
    3 - TR_DOS
    Scorpion support also PROF-ROM 256kB
    First 64kB contain:
    0 – BASIC-128
    1 – BASIC-48
    2 – SHADOW MONITOR
    3 – TR-DOS
    4-31 - ??? ( All this pages is used ? )
    PROF-ROM is used only on Scorpion computers ?
    S.Pb
    Kramis - this ROM has the technological purpose and is only used when setting up your computer.
    ---------- Post added at 00:34 ---------- Previous post was at 00:33 ----------
    Scorpion, ZXM-Phoenix or any other available relevant management.
    Последний раз редактировалось Black_Cat; 15.11.2009 в 00:36.
    Praha
    33
    14 сообщений
    Prof rom need scorpion's paging ports. Phoenix is compatible with Scorpion ?
    S.Pb
    Scorpion PROF-ROM - this is not normal ROM, this ROM has an integrated memory manager.
    ---------- Post added at 00:44 ---------- Previous post was at 00:41 ----------
    Yes, except for printer and serial port.
    Praha
    33
    14 сообщений
    It's my new project in development:
    PROFI INTERFACE for ZX128+2:
    - contain CPU Z80, FLASH EPROM 512kB , 1MB SRAM(+battery) , CPLD, extra NMI button
    This interface can emulate memory paging of russian ZX clones (ZX PROFI, PENTAGON, SCORPION, etc...). TRDOS rom mapping will supported (work only with ramdisc in 1MB memory). All paging ports will readable, all features will changeable. For example - part of extended ram memory can emulate rom (will set to low 16kB as zx rom replacement with write protect). This enable modify zx roms, trdos , nmi menu, etc.....
    Actually I must create content for this 512kB FLASH EPROM. My idea is join 4x 64kB rom (first 256kB) + one PROF-ROM (second 256kB).
ID:	14272   Нажмите на изображение для увеличения.
ID:	14273   Нажмите на изображение для увеличения.
    Praha
    33
    14 сообщений
    I know, see my page:
    http://velesoft.speccy.cz/profirom.htm
  1. Spessy EXE files
    от Splinter в разделе Эмуляторы
    Последнее: 25.08.2005, 13:50
