Показано с 1 по 10 из 61
Тема: Агат и HxC Floppy Emulator
    Activist
    Vancouver, Canada
    По умолчанию Агат и HxC Floppy Emulator
    Работает!
    Подробности и софт тут.
    Aghat 840k
    MFM, 300rpm, 250000 bps
    5"25 80 Tracks, 21 Sectors per track, Sector 256 bytes, 2 sides, 860160 bytes formatted
    un-Formatted track capacity 6250 bytes.
    DOS Track format
    1. GAP1 24x 0xAA bytes
    2. 21 sectors of the following format:
    2.1 Desync 0xA1
    2.2 0xFF may be any byte, not available sor software
    2.2 Address field:
    0x95, 0x6A (2 byte address field mark),
    volume number (1 byte, default 0xFE),
    Track number (1 byte 0x00 - 0x14),
    Sector number (1 byte),
    0x5A (1 byte End of address field mark)
    2.3 GAP 3x 0xAA bytes
    2.4 Desync 0xA1
    2.5 0xFF may be any byte, not available sor software
    2.6 Data field:
    0x6A, 0x95 (2 byte data field mark),
    256 Data Bytes,
    CRC(1 byte),
    0x5A (1 byte End of data field mark)
    2.7 GAP3 24x 0xAA bytes
    3. After last sector intead of GAP4 there is GAP4 13x 0xAA bytes
    Agath is using Apple 2 Disk checksum algorithm.
    Despite of being called "simple arithmetic sum" is is more complicated:
    function CalcCRC(const d: tSec): Byte;
    var c: Word; n: Byte;
    begin
    c:=0;
    for n:=0 to 255 do begin
    if c>255 then begin inc(c); c:=c and 255 end;
    inc(c,d[n]);
    end;
    CalcCRC:=c and 255;
    end;
    Sector numbering is 0..20, Sector order and interleave is not important. Usual sector order is 0..20
    Address field has no disk side information. Tracks are numbered 0..159 and present on disk in following order:
    Track 0, Side 0: Track 0
    Track 0, Side 1: Track 1
    Track 1, Side 0: Track 2
    Track 1, Side 1: Track 3
    And so on.
    This is done for simple Apple DOS usage with 840k disks.
    It has one interesting side effect: 140k disk images may be transferred to 840k disks
    By copying sectors 0..16 of each track and leaving sectors 17..20 empty.
    VTOC and Catalog structures of 140k disk will be pointing only to valid
    Track/Sector pairs and disk will be fully functional in 840k drive.
    DSK Image file information
    Files contain payload for DOS formatted disks.
    840k DSK files
    - 256 bytes header
    - 128 byte epilogue
    - 4 byte epilogue
    - clean 860160 files with NO header or epilogue
    140k DSK files
    - 128 byte epilogue
    - 4 byte epilogue
    - clean 143360 files with NO header or epilogue
    in of above payload stored on following order:
    840K
    Track 0, Sector 0,.... Track 0, Sector 20,
    Track 1, Sector 0,.... Track 1, Sector 20,
    and so on.
    140K
    Track 0, Sector 0,.... Track 0, Sector 15,
    Track 1, Sector 0,.... Track 1, Sector 15,
    and so on.
    Agath FCD is 100% software driven, so software is capable to:
    - write any data on FDD track, with one exception.
    In order Desync sequence to be correct and detectable by FDC during the read cycle
    software must put 0xA4 to FDC data register before issuing Desync command
    and write one extra byte after Desync. This extra byte is usually 0xFF, but may be of any value.
    - read any data from FDD track, with one exception.
    Byte following after Desync is invisible for software
    Also, Index signal is may be or may be not used by software.
    Due to FDC design, timing is very important (issue is similar to Apple 2 FDC).
    Many Agath programs exploit FDC capabilities for copy protection purposes.
    AIM file encode each track with 6464 16 bit words.
    Track/Side order: bottom side, top side, next track.
    LSB - data, MSB - A attribute
    A=0x01 - desync
    A=0x80 - desync
    A=0x03 - index mark start
    A=0x13 - index mark end
    A=0x02 - end of the track
    If index mark is missing then index pulse assumed to start at 0 byte and end at 30 byte.
    AIM file example:
    Track start
    0xAA 0x00 x48 bytes GAP
    0x00 0x01 desync
    0x95 0x00 address field marker byte 1
    0x6A 0x00 address field marker byte 2
    0xFE 0x00 Volume
    0x00 0x00 Track
    0x00 0x00 Sector
    0x5A 0x00 address field end
    0xAA 0x00 x3 bytes GAP
    0xFF 0x01 desync
    0x6A 0x00 data field marker byte 1
    0x95 0x00 data field marker byte 2
    0xXX 0x00 x256 data bytes
    0xXX 0x00 CRC ( 1 byte simple sum of 256 data bytes )
    0x5A x000 data field end
    0xAA 0x00 x24 bytes GAP
    next sector address marker
    AIM files are crafted to work with software Agath simulators.
    6464 is way more than 6250 bytes of MFM track.
    My speculation is, that software simulators are lacking correct CPU-FCD-FDD timing
    and AIM file manually crafted. There is other problems from file to file.
    For instance, Desync is encoded at list in 3 different ways:
    (0x00 0x01), (0xA4 0x00, 0x00, 0x01), (0xA4 0x00 0xFF 0x00 0x00 0x01)
    Before MFM encoding for HxC the following tasks must be accomplished:
    - All Desync sequences
    must be replaced with
    (0xA4, 0x01, 0xFF, 0x00)
    - All gap's bigger than 5 (adjustable option) bytes must be found and total gap length calculated.
    Intelligent state machine for that purpose must execute correct processing of
    invalid Desynk+Mark sequences, data blocks at index pulse position, and data hidden in gap's
    - AIM track truncated according to track end command and real track length determined,
    it will be still way over 6250 bytes
    - Index pulse position determined according AIM Index start command
    - Track rotated in order Index pulse to be at beginning of the track always
    - If track rotation split the gap, then redistribute GAP1/GAP4 and calculate new length for each gap
    - As adjustable option another track rotation is implemented to avoid data blocks to be at index pulse position
    - Find the last gap bigger than 5 bytes
    - Calculate gap deflation rate in order to shrink the track to 6250 bytes
    - Shrink the track to 6250 bytes by decreasing big gaps, redistributing rounding error over many and
    doing final rounding error correction on the last gap
    HxC Information
    http://hxc2001.free.fr/floppy_drive_emulator/
    http://www.lotharek.pl/
    Emulator is using pre-encoded data MFM stored in hfe container files.
    Due to complicated nature of AIM file processing, implementing Agath support in HxC PC software is not feasible.
    A suite of Perl utilities has been developed:
    hfe-agath-decode.pl - for HFE decoding and verification
    agath-dsk-to-hfe.pl - for DSK to HFE conversion
    agath-aim-to-hfe.pl - for AIM to HFE conversion
    agath-dsk-to-hfe.pl
    # Encoding data from Agat DSK file to HxC hfe
    # 840k DSK files supported:
    # - 256 bytes header
    # - 128 byte epilogue
    # - 4 byte epilogue
    # - clean 860160 files with NO header or epilogue
    # 140k DSK files supported
    # - 4 byte epilogue
    # - clean 143360 files with NO header or epilogue
    # Usage:
    # agath-dsk-to-hfe.pl <dsk file> <hfe file>
    agath-aim-to-hfe.pl
    # Encoding data from Agat AIM file to HxC hfe
    # Supported AIM commands
    # 0x00 Payload
    # 0x01 DESYNC
    # 0x80 DESYNC
    # 0x03 Index Pulse Start
    # 0x02 End of Track
    # 0x13 Index Pulse End
    # Usage:
    # agath-aim-to-hfe.pl <aim file> <hfe file> [<debug mode>] [<debug track>]
    # Debug modes:
    # 'AIM' Initial analysis after AIM read
    # 'GAP' After DESYNC expansion and GAP count
    # 'DEF' After GAP deflation
    # 'MFM' MFM Encoding
    # Debug track is assuming Agath / Apple 2 track numbering
    hfe-agath-decode.pl
    # Decoding MFM stream from HxC hfe files one track at a time.
    # Only Agath MFM encoding supported
    # On Agath track 17 ( track 8 side 1 ) VTOC and CATALOG is decoded
    # Usage:
    # Assuming Track 0 Side 0
    # hfe-agath-decode.pl <hfe file>
    # Assuming Agath / Apple 2 Track number
    # hfe-agath-decode.pl <hfe file> <Agath track number>
    # Physical disk track number and side number
    # hfe-agath-decode.pl <hfe file> <track number> <side number>
    Sample output of
    hfe-agath-decode.pl ikp7.hfe 17 > ikp7-T17.txt
    is provided.
    Activist
    Vancouver, Canada
    Выкладываю финальную версию с поддержкой записи.
    Прилагаю firmware для HxC с поддержкой записи для Агата (thanks to Jean-Fran&#231;ois DEL NERO !)
    После тестирования поддержки записи, стандартный формат был уточнен.
    DOS Track format
    1. GAP1 13x 0xAA bytes
    2.1 Desync 0xA1
    2.2 Address field:
    2.3 GAP 5x 0xAA bytes
    2.4 Desync 0xA1
    2.6 Data field:
    256 Data Bytes,
    CRC(1 byte),
    2.7 GAP3 22x 0xAA bytes
    3. There is NO GAP4, after last sector track is exactly 6250 bytes
    Ограничения: на HxC не будет работать форматирование, но оно там и не нужно.
    Известные проблемы: копировщик ИКП глючный, особенно в случае двух приводов. Проблемы есть даже для обычных флопи. Для копирования дискет рекомендую пользоваться утилитой diskcopy.
    --- Аватар для Shadow Maker
    Саранск
    239
    101 сообщений
    Есть некие дискеты. С прорезями с двух сторон. Подозреваю Агат. Кроме PC с дисководом 5,25" ничего не умею. Научите, как проверить / считать.
    Не уверен - не напрягай!
    Не сдавайся. Дыши?
    Virtual TR-DOS
    Activist
    Vancouver, Canada
    только на живом Агате и больше никак.
    можно отправить диски вот этим очень хорошим людям
    http://deka.ssmu.ru/er/agat/Common/search.shtml
    и они снимут данные.
    Саранск
    239
    101 сообщений
    А как-то убедиться в том, что это вообще Агатовские диски без пересылки можно? А то я только по косвенным признакам типа надписей SHAMUS догадываюсь
    Последний раз редактировалось Shadow Maker; 06.06.2014 в 01:26.
    Не сдавайся. Дыши?
    Virtual TR-DOS
    Activist
    Vancouver, Canada
    никак
    Саранск
    239
    101 сообщений
    Вообще печаль. А где хоть эти очень хорошие люди находятся территориально? В том разделе, куда ты ссылку дал, не видать никакой инфы.
    Не сдавайся. Дыши?
    Virtual TR-DOS
    Activist
    Vancouver, Canada
    Питер и Сергиев Посад (Москва)
    Саранск
    239
    101 сообщений
    Понятно. Я в принципе через месяц-два в Питер думал поехать, надо попробовать пересечься чтоли. Мне-то диски явно не понадобятся, за отсутствием Агата Надо еще поискать, вроде коробки 3 было их. И это наверное тут уже оффтоп, надо куда-то еще перенести в отдельную тему.
    Не сдавайся. Дыши?
    Virtual TR-DOS
    Activist Аватар для GARNIZON
    S-Posad
    47
    34 сообщений
    Я один из "тех". Поправка - Томск (Новосибирск) и Сергиев Посад (Москва).
    Почтовые расходы мы оплачиваем сами, так что если надумаете прислать диски это вам будет бесплатно. Кроме того, если часть или все окажутся не агатовскими то тоже образы получить возможно нашей аппаратурой, вобчем практически с любых (и спектрум и коммодоре и ДВК и другие в т.ч. экзотические).
    тут я попытался подробней все описать:
    http://deka.ssmu.ru/er/agat/Common/disk-faq.shtml
    Последний раз редактировалось GARNIZON; 06.06.2014 в 09:52.
  1. SDCard HxC Floppy Emulator(Флоппиэмуль француза)
    от Alex_NEMO в разделе Внешние накопители
    Ответов: 349
    Последнее: 20.04.2024, 08:11
  2. Ответов: 44
    Последнее: 23.06.2014, 14:22
  3. Образ TRD на USB floppy
    от Wicked в разделе Софт
    Последнее: 03.03.2014, 14:01
  4. 5.25 Floppy
    от Aktomarie2012 в разделе Внешние накопители
    Последнее: 18.10.2011, 12:44
  5. Версии Floppy Disc Emulator на PIC32.
    от ZXFanat в разделе Внешние накопители
    Ответов: 20
    Последнее: 01.04.2011, 09:09
