Показано с 1 по 10 из 54
Тема: Speccy emulator
    R.I.P. Аватар для Rindex
    Khimki
    14 сообщений
    По умолчанию Speccy emulator
    После долгого перерыва Марат Файзуллин обновил свой эмулятор для Windows - Speccy 3.0
    http://fms.komkon.org/Speccy/
    Список изменений:
    • Added Sam Coupe emulation, will improve it in future versions.
    • Majorly improved AY8910 PSG emulation.
    • Improved WD1793 disk controller emulation.
    • Added SAA1099 PSG emulation.
    • Automatically enabling TRDOS for .TRD, .SCL, or HOBETA files.
    • Fixed +3 mode selection to happen for .DSK files (was .SCL).
    • Fixed recognition of multiple file extensions.
    • Fixed tape auto-load feature for Sam Coupe.
    • Fixed loading color palettes.
    • Added vertical scanlines simulation to Speccy-Windows.
    • Added raster effect simulation to Speccy-Windows.
    • Added slope to rectangular waveforms.
    Сбросив пару лишних мегатонн,
    Khimki
    14 сообщений
    Обновился этот эмулятор для Windows Speccy-Windows 3.3 и Android Speccy-Android 3.3.1 - Скачать
    • Список изменений:
    • Improved audio quality, no more clicks and scratching.
    • Key clicks in Sinclair BASIC sound normal now.
    • Rendering beeper sound separately from melodic channels.
    • Made sure rendered sound does not fall behind the audio playback.
    • Now killing zombie processes left by some activities.
    • Now aligning backdrop to the screen bottom, if it is too small.
    • Removed unused and outdated code, resources and bitmaps.
    • Fixed default settings initialization.
    • Added missing string translations.
    Khimki
    14 сообщений
    Вышел новый Speccy-Android 3.3.2 - Скачать.
    • Список изменений:
    • Improved AY8910 and SAA1099 PSG noise generators.
    • Fixed crashes when sound disabled.
    • Made hardware BS and DEL keys work properly.
    • Added French translation, thanks to Sylvain St-Amand.
    • Added "Use PLAY/RECORD Media Keys" option.
    • When enabled, RECORD saves, PLAY restores gameplay.
    • Added "Use FFWD/REWIND Media Keys" option.
    • When enabled, FFWD fast-forwards, REWIND replays.
    • Added immersive mode support for KitKat and newer.
    • Made system UI translucent when immersive mode is on.
    • Autohiding title bar when "Hide Title Bar" enabled.
    • You must start or finish your fling at the top to toggle title bar.
    Последний раз редактировалось Rindex; 07.01.2015 в 23:03.
    Khimki
    14 сообщений
    Вышел новый Speccy-Android 3.3.3 - Скачать.
    • Список изменений:
    • Added multi-window and mini-window support on Samsung devices.
    • Added "Show Box Art First" option to the File Selector.
    • Added searching by name to the File Selector.
    • Added assembler routines for scaling screen to 1280x960+ pixels.
    • Fixed OpenGLES lockups on Mali GPUs.
    • Fixed auto frame skip when OpenGLES enabled.
    • Fixed flickering border on x86 devices.
    • Fixed reenabling UI with a fling on Kitkat+ phones.
    • Fixed premature hiding of the title bar.
    • You can now fling from the top or the bottom to toggle UI.
    • Hiding the title bar is now the default behavior.
    • Made screenshots and box art bigger on large screens.
    • Reenabled automatic frame skip by default.
    • Reenabled accelerated video and audio by default.
    • Removed deprecated code, settings, and resources.
    • Built package with the latest Android SDK.
    Последний раз редактировалось Rindex; 05.02.2015 в 03:30.
    Khimki
    14 сообщений
    Вышел новый Speccy-Android 3.3.4 - Скачать.
    • Список изменений:
    • Switched to the Material Design theme.
    • Added "up" buttons to all title bars.
    • Revised all menus, making them work uniformly.
    • Fixed "Show Virtual Keyboard" setting.
    • Fixed screenshots size in the World Of Spectrum Browser.
    • Fixed black banding in the Palette Editor.
    • Fixed text color in the Gallery.
    • Updated all icons to the newest Lollipop versions.
    • Retired some icons, replacing them with better fitting ones.
    • Removed application name from all title bars, to save space.
    • Now defaulting to the "light UI" mode.
    Veteran Аватар для abelenki
    Perm, Russia
    298
    102 сообщений
    Rindex, у тебя случаем нет прямой ссылки на APK версии 3.3.4? а то я не пользуюсь Google Play...
    Khimki
    14 сообщений
    Если что, вот адрес сайта Марата Файзуйллина.
    Perm, Russia
    298
    102 сообщений
    я в курсе. и?
    ---------- Post added at 13:07 ---------- Previous post was at 13:06 ----------
    поставил com.fms.speccy по ссылке с даунлодера - не работает.
    требует доступ в Google Play, при отказе вылетает.
    Khimki
    14 сообщений
    Ну может там есть. Но там похоже всё тоже ведёт на гуглплей.
    Perm, Russia
    298
    102 сообщений
    именно.
  1. УКНЦ + КМД УК + HxC Floppy Emulator (ДВК MY)
    от kapitan-u в разделе ДВК, УКНЦ
    Ответов: 24
    Последнее: 02.05.2019, 11:49
  2. Agat Emulator v1.26.1
    от Rindex в разделе Apple
    Последнее: 15.02.2014, 22:02
  3. Higgins Spectrum Emulator
    от Higgins в разделе Эмуляторы
    Ответов: 56
    Последнее: 16.01.2011, 19:17
  4. SpecEmu v2.8 emulator released
    от Woodster в разделе RST#38
    Последнее: 16.11.2008, 21:03
