Показано с 1 по 10 из 11
Тема: Cyrilic coding
    Member Аватар для hood
    Czech Republic
    32
    8 сообщений
    По умолчанию Cyrilic coding
    Hi all,
    on ZX Spectrum, what is the most used Cyrilic 8 bit coding (charset) of texts from ex-CCCP region? I mean W-1251, CP-866, etc.??
    Maybe, I would like to add some support of cyrilic texts to my programme.
    Thanks
    Hood
    Guru Аватар для Shiny
    г. Арзамас
    38
    25 сообщений
    mostly "qwerty/яверты" encoding. It used in russian version "The Last Word". ZX-Word support cp866
    Czech Republic
    32
    8 сообщений
    Ok, thanks. I would need 4 bit font, coded like one 4 bit character in 8 bytes (so basically two 4 bit characters in 8x8 matrix). Is it possible to download it somewhere? It must exist, so that I do not have to draw it. Many thanks. Hood.
    Сибирский антропоморфн Аватар для Black Cat / Era CG
    Бердск, НСО
    871
    635 сообщений
    For example:
    Ernesto Che Guevara
    http://era-cg.su
    г. Арзамас
    38
    25 сообщений
    here is cp866 files - 8x8 and 6x8.
    • Тип файла: rar __fnt.rar (5.4 Кб, Просмотров: 57)
    Veteran
    249
    155 сообщений
    This text editor uses 4bit font: http://vtrdos.ru/system/TLW&D_J_.ZIP , but, as I understood, this font is result of dynamic cutting of some columns from 8bit font by printing procedure (each symbol has its own columns for cutting).
    Этот текстовый редактор использует 4хбитовый фонт: http://vtrdos.ru/system/TLW&D_J_.ZIP, но, как я понял, этот фонт получен динамическим вырезанием некоторых столбцов из 8битного фонта процедурой печати (у каждого символа свои вырезаемые столбцы).
    I found 4bit font in Tasword: 4BFONT.zip
    Czech Republic
    32
    8 сообщений
    For example:
    Hello once more, I decided to create font with cyrilic and implement it in our prgramme (MB-Commander 2.7) so that we can also read texts in cyrilic.
    I understand that CP866 has 32-127 codes same as ASCII standart (means western letters) and 128-255 has cyrilic letters.
    But I do not understand "qwerty/яверты" encoding. Does it mean, it is some special coding, which has codes 32-127 also in cyrilic? If yes, than you cannot read western texts in "qwerty/яверты" encoding I guess. And if yes, which codes are reserved for 128-255?
    Many thanks for answers
    Hood
    Бердск, НСО
    871
    635 сообщений
    This encoding was used for games in the main. Only Cyrillic font or two fonts were used. Characters 128-255 were not used. This way was used for BASIC-games or for translation. In other cases, the cp866 encoding was used.
    Ernesto Che Guevara
    http://era-cg.su
    Czech Republic
    32
    8 сообщений
    Ok, so you think I can leave out "qwerty/яверты" encoding and make only CP866? Will this be enough for most texts in cyrilic?
    --- Аватар для Shadow Maker
    Саранск
    239
    101 сообщений
    Depends what texts you plan to read and where they were originated from. Basically CP866 is enough, as most cyrillic textes were made in something like ZX Word/Modern Word/ZX Asm/etc.
    Не уверен - не напрягай!
    Не сдавайся. Дыши?
    Virtual TR-DOS
  1. Coding vs Zapilyating
    от Rindex в разделе Демо
    Ответов: 41
    Последнее: 10.03.2015, 20:20
  2. нужен RSA coding/decoding на zx-basic-e
    от bigral в разделе Софт
    Последнее: 22.03.2013, 19:36
