Показано с 1 по 10 из 118
Тема: ZEsarUX Emulator
    Member
    Madrid, Spain
    36
    14 сообщений
    По умолчанию ZEsarUX Emulator
    This first post is the result of merging and old thread about ZEsarUX new version and the last ZEsarUX RC 9.2 version news. So this initial post was talking probably about a beta version of ZEsarUX 7.0. The changelog was :
    Version 7.0 BETA. - Xeno edition
    Added ZX-Evolution BaseConf emulation
    Added BetaDisk and TR-DOS emulation
    Added Spectrum +3 emulation
    Added Spectrum keyboard ghosting error feature
    Added ZX Spectrum Recreated keyboard support
    Added improved Spectrum 16/48/+ colour palette
    Added a fast spectrum core (with some features disabled) just for slow devices, like Raspberry Pi 1/Zero. Now ZEsarUX is playable on RPi1/Zero again
    Added setting to write protect IDE, MMC, ZX-Uno Flash
    Added setting to show changelog when updating emulator version
    Added actions to file utilities menu: Copy, Move, Rename
    Added setting to disable persistent writes on IDE and MMC
    Added setting to add a watermark on the display
    Added setting to reduce display to a factor of 0.75. Used on RunZX event
    Added setting to save spectrum screen to pbm file (black&white)
    Added a setting to dump ram contents to file when exiting ZEsarUX, ideal to run automatic tests
    Added setting to exit emulator after a number of seconds (--exit-after)
    Added experimental simulation of the SAA1099 audio chip from the Sam Coupe
    Added second Easter Egg
    Added third Easter Egg
    Improved debugging:
    * new enhanced debug cpu menu: view TV electron position on screen, new default view, cursor, toggle breakpoints, run to cursor, change registers, a
    nd a lot more...
    * added cpu-step-over function on debug menu (was already available from ZRCP)
    * added function to write byte to file on ZEsarUX hardware debug ports
    Improved ZRCP:
    * run command is stopped by default when pressing a key (or sending data to the socket)
    * when a breakpoint is fired on cpu-step-mode, the breakpoint condition is shown on ZRCP
    Improved joystick support:
    * added joystick test menu
    * buttons to events and buttons to joystick configuration are saved on configuration file
    Improved OSD keyboard:
    * now you can press up to all 40 keys (on Spectrum/ZX80/ZX81) at the same time
    * now it can be opened from any place (needs multitask on)
    Improved QL emulation:
    * experimental support of LOAD, LRUN command
    * can now open qlay mdv microdrive image files
    Improved file viewer from file utilities:
    * specific file viewers for these kind of files: .tap, .zx, .zsf, .sp, .z80, .sna, .spg, .p, .o, .mmc/.ide (fat browser, plus3dos browser), .dsk, .t
    rd, .tzx, .cdt, .flash (zxuno flash, z88 flash, superupgrade flash), .epr, .eprom
    * default hexadecimal file viewer for unknown files
    * conversion utility
    Improved TSConf emulation:
    * added TSConf DMA, line interrupt, sprites layers
    * TSConf rendering: now tiles and sprites are drawn per scanline. Border drawing. Handling of scroll registers
    * TSConf debugging: debug for DMA, Video registers, Video layers, Sprites, Tiles
    * added TR-DOS emulation support
    Improved menu interface:
    * emulated machine display is no longer faded or switched to black & white when opening menu. There were different visual glitches due to this featu
    re
    * a new "tabbed" menus to improve usability and interaction with mouse, joystick and stdout driver: waveform, visualmem, ay player
    * Character width can be reduced to 7,6 or 5 pixels width
    * added a setting to limit menu event: enabling it you should press the menu key 3 times in a second to open the menu
    * added a setting to hide directories from file selector menus, useful when you don't want the user to be able to navigate the filesystem
    * Smartload: now the cursor remembers last file loaded
    * added two more GUI styles: Clean and CleanInverse
    Improved sprite viewer:
    * now can see sprites with speccy screen format
    * you can view sprites up to 512x192
    * you can see tsconf sprites
    * you can see pseudo hires zx81 screens
    Improved TBBlue emulation:
    * Added clip window registers
    * Added Copper
    * Added almost all next extended opcodes
    * Added a setting to start TBBlue directly to a 48 rom but with all the Next features enabled, useful for fast snapshot loading
    Improved AY Player: now shows waveform volume meter
    Improved VU meters with decay effect on AY Player, AY Registers and Waveform
    Improved text mode drivers (aalib, stdout, simpletext, curses): text settings are in different submenu, setting to set stdout/simpletext fps
    Improved messages windows. You can now have an internal clipboard, press key c to copy to it. Press P on file utils to paste contents to a file
    Improved frameskip: better performance, because realvideo buffer is not updated when frameskip
    Improved sound: Silence detector activated by default but can be disabled
    Improved top speed: loading sound is distorted when setting top speed
    Improved autoload: new setting to run at top speed the reset+load"" process
    Improved real tape loading: now it shows a percentage of tape loaded
    Improved default configuration: when the configuration file doesn't exist, the new one has the autosave configuration setting enabled
    Improved configuration parsing: if unknown setting found on configuration file, ZEsarUX will open but warns about the error, and the autosave featur
    e is not enabled
    Improved rendering on text mode drivers: now realvideo mode can render directly to black&white text. Try TSConf with --vo stdout --realvideo --autor
    edrawstdout
    Improved Linux library dependencies: libssl is not enabled by default on compilation
    Fixed ZX-Uno emulation:
    * 128kb timings are the same as a Spectrum 128k. When port 1ffd enabled, port FF return FF
    * Kempston port returns 0 when no kempston selected. New BIOS can be used now
    Fixed TBBlue MMU when using segment 0000-3FFFH
    Fixed Raster interrupts on ZX-Uno and TBBlue. Horizontal raster position was wrong
    Fixed window footer when running Pentagon
    Fixed panic screen: now it is shown on all machines. New design. I hope you never see it
    Fixed some crashes with speech enabled and opening some menus: AY Registers, AY Player, etc...
    Fixed annoying sound on Dandanator rom menu
    Fixed bug on Z80 cpu core, iff2 was not being reset to 0 when firing an interrupt, so reading it by using LD A,R and LD A,I affected many demos
    Enjoy!
    Cheers
    César
    Последний раз редактировалось chernandezba; 16.03.2021 в 02:02.
  1. Speccy emulator
    от Rindex в разделе Эмуляторы
    Ответов: 53
    Последнее: 13.07.2022, 22:50
  2. CHIP8 Emulator
    от NEO SPECTRUMAN в разделе Софт
    Ответов: 37
    Последнее: 05.11.2020, 22:24
  3. Agat Emulator v1.26.1
    от Rindex в разделе Apple
    Последнее: 15.02.2014, 22:02
