Показано с 1 по 10 из 11
Тема: DMA interface for ZX Spectrum
    Master Аватар для VELESOFT
    Praha
    33
    14 сообщений
    По умолчанию DMA interface for ZX Spectrum
    This is DMA interface for ZX Spectrum. On board is used Z80-DMA and one GAL as port decoder. Schematic is compatible with DMA in MB02 interface.
    http://velesoft.speccy.cz/data-gear.htm
    Master Аватар для KingOfEvil
    Москва, Ногинск
    Can you describe this device in English? It's very difficult for me to understand Czech text.
    KOE ** Pentagon-1024SL 2.2+1024k RAM+384x304+16 colour+HDD+CD-ROM+PS2 Keyboard+Turbo Sound FM + GS 512 bugFixed
    Veteran Аватар для skyther
    Лысьва
    Вот еще бы этот Z80-DMA где-то взять...
    Member Аватар для do_se
    Perm
    Мона старые роботроны покорежить.... тама был полный набор Z80 вроде
    Лучше переспать, чем недоесть
    Praha
    33
    14 сообщений
    O.K. This is standard Z80-DMA and is possible buy old versions UA858D or original new DMA from ZILOG.
    http://www.zilog.com/download/defaul...1886&from=onyx
    DATA-GEAR is DMA part from MB02+ schematic (100 % compatible with DMA chip in MB02 diskdrive: http://www.8bc.com/sinclair/
    DMA use port 23(dec) for programming. Clock for DMA is connect to CLK signal from Z80CPU. Maximum speed of data transfer is 1byte / 4T cpu (2T for read source byte + 2T for write byte). Z80 DMA support more transfer modes:
    - memory to memory
    - memory to port
    - port to memory
    - port to port
    Source or target adress can be inc(dec)remented or fixed.
    Is possible use different speed for read and write (2 - 4T).
    For test you can play any games or demos with DMA support.
    Emulator REALSPECTRUM( + ZX128 mode + MB02) is compatible with
    DATA-GEAR (= MB02 without memory and FDD ).
    Example of DMA transfer (fullscreen scroll 50fps - green border is DMA transfer )
    http://velesoft.speccy.cz/data-gear/dma-scr-rol.avi
    Последний раз редактировалось VELESOFT; 05.04.2007 в 22:47.
    Москва, Ногинск
    - memory to memory
    - memory to port
    - port to memory
    - port to port
    Thanks.
    Moderator Аватар для Mick
    695
    368 сообщений
    19 Post(s)
    А вы попробуйте К580ВТ57 тоже контроллер DMA и стоит очень дешево(по моему в платане 3 руб штука).
    Banned
    г. Дзержинск, Украина
    658
    512 сообщений
    Цитата Сообщение от drbars Посмотреть сообщение
    Да где хотя бы эмуляция этого контроллера?
    после полу часа плясок с бубном...
    или рекомендации как запустить что нибудь что хочет mb02+ (оно же местами data gear)
    на доисторическом realspec и не попасть к санитарам
    качаем
    http://zxm.speccy.cz/realspec/
    http://zxm.speccy.cz/realspec/emul/rs32-r14b-i686.zip
    http://zxm.speccy.cz/realspec/emul/rs32-r14b-amd.zip
    закидываем ромы от сюда в папку с эмулем
    http://zxm.speccy.cz/realspec/emul/rspec-roms.zip
    закидываем туда же mb02.rom mb02.7z
    который я нашел в папке с моим унриалом
    в realspec.ini ставим единичко чтоб меньше делать телодвижений
    MB02-Enabled: 1 # Enable MB-02+ interface
    или делаем в эмуле
    shift+f3
    tab для перехода в peripherals
    и там ужо disk i/f меняем на mb-02+
    далее чтоб проскипать *****е вставляение дискеты (эмуль поддерживает драгндроп на свою иконку но от этой менюшки оно не спасает)
    жмем shift + space
    и наконец попадаем в менюшку 128-го и грузим свои mb02+ демы
    у меня заработало демко для 11-го порта
    при попытке запуска dma-elite.tap
    эмуль крашитсо...
    Последний раз редактировалось NEO SPECTRUMAN; 26.10.2017 в 19:41.
    1,180
    776 сообщений
    эмуль крашитсо...
    не любит она 128ой бейсик.
    Последний раз редактировалось goodboy; 26.10.2017 в 22:06.
    Banned
    658
    512 сообщений
    А к чему здесь 128 басик?
    Эмуль с таким же успехом падает и в 48-м басике
    и в режиме резинке тоже...
  1. Контроллер LA15-312 для Interface-I
    от alex-amur в разделе Несортированное железо
    Последнее: 21.06.2017, 14:06
  2. Ленинград-1 + Beta Disc Interface
    от Иван в разделе Ленинград
    Ответов: 14
    Последнее: 16.11.2006, 15:04
  3. Beta Disc Interface
    от Addison в разделе Внешние накопители
    Ответов: 17
    Последнее: 03.11.2006, 15:02
  4. Ответов: 8
    Последнее: 22.08.2006, 22:36
