Страница 13 из 13 ПерваяПервая ... 910111213
Показано с 121 по 125 из 125
Тема: New Vortex Tracker imroved (again)
  1. #121
    dig out your soul Аватар для scl^mc
    Russia, Ulianovsk
    30
    19 сообщений
    Lee James, welcome.
    there are so many reasons not to use names for samples and ornamets, such like keeping full compatibility with real spectrum and programms like protracker, wildplayer, etc...
    31 ornaments are not necessary there are huge quantity of tunes which written in vortex with using of 2-5 ornaments. you can listen them here or here.
    due the limitation of track-format, there no way to realize 4 and 5 in vortex, but all of 5 features requests can be included in the new-aged tracker. unfortunately, there is no projects of new vortex-alike tracker.
    speccy merchandise
  2. #121
  3. #122
    Junior
    England, UK
    Цитата Сообщение от scl^mc Посмотреть сообщение
    Lee James, welcome.
    Thank you!
    But Vortex Tracker allows you to save files as "module in text file (only for work)". These are "work files". Couldn't they allow sample names, just for the purpose of working on the song? Then when you save the file as pt3, the sample names could be removed then?
    Yes, I know that many tunes don't need a lot of ornaments. But 15 is not always enough ornaments. For example, I have been working on the 4 tunes from OutRun. Those tunes contain a lot of complex chords. It is impossible to create those tunes properly in Vortex Tracker with only 15 ornaments. So I have had to simplify some of the chords because I didn't have enough ornaments to do them properly.
    Последний раз редактировалось Lee James; 12.05.2017 в 23:39.
  4. #123
    Member
    Тутаев
    Command number 4.
    Starts sample playing from position 'Pp'. During note setting, sample starts
    playing from zero position (i.e. from its begin). Command 4 allows to start
    sample playing from any place.
    Command number 5.
    Works like command 4, but for ornament. << try this.
  5. #124
    Junior
    England, UK
    Цитата Сообщение от korovkin Посмотреть сообщение
    Command number 5.
    THANK YOU KOROVKIN!!!!!
    Command number 5 is exactly what I needed! Now I can include loads more ornaments, which means much better quality of music
    благодаря!!!
  6. #125
    Member
    Тутаев
    \o/
  1. Vortex Tracker
    от AAA в разделе Музыка
    Ответов: 47
    Последнее: 20.04.2024, 19:09
  2. Конвертер MIDI в формат Vortex Tracker II
    от shadwork в разделе Утилиты
    Ответов: 25
    Последнее: 05.07.2021, 21:17
  3. Нужны исходники АУ плеера Vortex Tracker II
    от jerri в разделе Музыка
    Последнее: 27.02.2014, 21:34
  4. Vortex подтяжка.
    от Biozoom в разделе Музыка
    Ответов: 19
    Последнее: 16.11.2011, 23:31
  5. Vortex Tracker & ProTracker TODO
    от Знахарь в разделе Музыка
    Последнее: 18.08.2006, 16:24
