TR-DOS support in system ESXDOS
System ESXDOS for DIVIDE interface support TR-DOS,FAT16,FAT32,TAP,SNA,Z80
http://velesoft.speccy.cz/zx/divide/...4_example1.gif
Info about TR-DOS emulation in esxdos:
- WD1793 ports are emulated (all IN/OUT instrutions) with special software emulator
- trdos 5.04T source code are recompiled to 8kB external ram and some parts are loaded from IDE device
- software calling tr-dos via #3D2F/#3D30 also work, only timing of FDC emulation is similar than real FDD.
Compatibility is better than in vTR-DOS in ATM TURBO 2+.
This version of ESXDOS will support also cutted TRD images with any size (up to 1MB) and all 4 drives.
Now will possible easy transfer data between FAT16/32/TAP/TRD in one system.
For more details you can contact author.
