новая игра от TomD - Maze Death Rally-X
топик на WoS
топик на WoS
версия 1.1.
-fixed crash due to a stray pop bc
-fixed issue were the player can get trapped in corners when pressing the opposite direction just after turning or multiple keys at once, car will now pull out of the corner first before allowing a turn
-fixed bug were you could go through walls when fuel is low and the car slows down
-no slide round corners when going slow (low fuel)
-improved smoke check for enemies so cars on the edge of the screen will crash into the smoke were before they went through it as if immune
-fixed issue where in some cases the red cars can get trapped, now they will try and get out of the block[свернуть]
финальная версия.
- fixed bug were a slow car suddenly speeds up
- fixed bug were with zero fuel getting the L flag causes screen corruption as it tries to refill the tank
- fixed bug were if you get extra life at the same time as collecting a flag sometimes they are not erased from the radar[свернуть]
версия 1.6.
