А что там за ошибка? Я, помню, толкал в свой ДВК-шник контроллер RK от новосибирского СКБ НП, с двумя ИЗОТ-1370. B RK0 работало...
Вместо
Код:.@TRK2
.time
07:29:25
.copy/device/noquery rk0: nl:
.time
07:29:27
.SHO DEV
Device Status CSR Vector(s)
NL Installed 000000 000
VM Installed 177572 000
LD Installed 000000 000
SL Installed 000000 000
ZA Installed 161014 350
ZB Installed 161054 354
ZC Installed 161114 360
ZD Installed 161154 364
ZE Not installed 161214 370
ZF Resident 161254 374
WQ Installed 177134 204
WS Installed 177134 204
RK Installed 177400 220
Вдогонку
Код:.@TRK
.DUMP/TERM/END:0 RK:
RK:
BLOCK NUMBER 000000
000/ 000240 000415 000000 000000 000000 000000 000000 000000 * ...............*
020/ 000000 000000 000000 000000 000000 041420 116020 000400 *...........C....*
040/ 000137 000574 000000 000000 000000 000000 000000 000000 *_.|.............*
060/ 000000 000000 000000 000000 000000 000000 000000 000000 *................*
100/ 000000 000000 000000 000000 000000 000000 000000 000000 *................*
120/ 000000 000000 000000 000000 000000 000000 000000 000000 *................*
140/ 000000 000000 000000 000000 000000 000000 000000 000000 *................*
160/ 000000 000000 000000 000000 000000 000000 000000 000000 *................*
200/ 000000 000000 000000 000000 012703 000014 000402 062703 *........C.....Ce*
220/ 000020 162700 000014 100373 060300 016703 000344 042713 *..@e..{.@`C.d.KE*
240/ 017777 050013 010243 010143 005413 012743 000005 105713 *...P#.c...c...K.*
260/ 100376 005713 100577 000207 000000 000000 000000 000000 *~.K.............*
300/ 000000 000000 000000 000000 000000 000000 000000 000000 *................*
320/ 000000 000000 000000 000000 000000 000000 000000 000000 *................*
340/ 000000 000000 000000 000000 000000 000000 000000 000000 *................*
360/ 000000 000000 000000 000000 000000 000000 000000 000000 *................*
400/ 000000 000000 000000 000000 000000 000000 000000 000000 *................*
420/ 000000 000000 000000 000000 000000 000000 000000 000000 *................*
440/ 000000 000000 000000 000000 000000 000000 000000 000000 *................*
460/ 000000 000000 000000 000000 000000 000000 000000 000000 *................*
500/ 000000 000000 000000 000000 000000 000000 000000 000000 *................*
520/ 000000 000000 000000 000000 000000 000000 000000 000000 *................*
540/ 000000 000000 000000 000000 000000 000000 000000 000000 *................*
560/ 000000 000000 000000 000000 000000 000000 012706 010000 *............F...*
600/ 013746 177412 006116 006116 006116 006116 042716 177770 *f...N.N.N.N.NEx.*
620/ 012700 000002 012701 002000 012702 001000 004767 177350 *@...A...B...w.h~*
640/ 012737 000210 004730 012737 071070 004716 012637 004722 *_...X._.8rN...R.*
660/ 000137 001000 004167 000002 000753 012700 000740 012702 *_...w...k.@.`.B.*
700/ 000722 004712 011100 004712 012700 000764 004712 000000 *R.J.@.J.@.t.J...*
720/ 000776 105737 177564 100375 112037 177566 001372 000207 *~._.t.}...v.z...*
740/ 005015 041077 047517 026524 026525 044400 047457 062440 *..?BOOT-U-.I/O e*
760/ 071162 071157 005015 000012 177777 177777 177777 177777 *rror............*
У DEC под шифром - RK чего-то там скрываются не только разные диски, но и разные контроллеры... Так что загрузчик в ПЗУ скорее всего поддерживает только первый RK, а остальные RK в системе носят другие имена, дай бог памяти, например DM и прочая...
И вполне понятно, почему работал... Скорее всего памяти было 256К, и драйвер RK - скорее всего ни о каких регистрах UNIBUS не ведает... А если ещё было загружено что-то в нижней памяти(например SJ/FB), либо процессор вообще без диспетчера памяти... В этом случае проблем вообще нет.
Проблемы начались бы, если памяти более 256К и система пользуется диспетчером памяти и писать в память надо выше 256К...
Интересно, а ошибка в какой-то определённой прошивке или во всех ПЗУ ДВК?
Исходная 134-ая и 377-ая. Думаю, что и английский вариант 134-ой.
Но в принципе - не актуально - вроде как контроллер RK11 для ДВК не всплывал, да и обладателей СМ5400 как то не на каждом углу встретишь, так что риск совпадения - у человека есть ДВК с 1201.03 или .04, контроллер RK11 для него и дисководы я ля RK05 (СМ5400) - минимален.
Контроллер был, от новосибирского СКБ НП, коллега Andrey_Ak открывал тему по его ремонту и, если вдруг он его починит, то оно таки всплывет.
У меня тоже был такой контроллер. Да, с 18-разрядной адресацией, о 22 разрядах о ничего не знал, тем не менее, у меня он работал. Вот только не помню, как оно загружалось на ВМ3. На ВМ2 - без вопросов, B RK0 и вперед. Потом я заменил 1201.02 на 1201.03, сразу же воткнул КЖД с винчестером и перелил всё со всех RK на этот винчестер, а дисководы ИЗОТ-1370 и СМ 5400 продал вместе с контроллером. Это было где-то в самом начале 90-х. И вот как я загружался там - не помню, хоть стреляй! Зато хорошо помню, что был разочарован скоростью винчестера. Одно и то же задание - компиляция с МАКРО программули в 3-5 страничек и линковка ее же, на RK пролетала за 3-5 сек, а на DW - секунд 10-15...
Программа минимум (записи пока нет, unibus регистров нет - то есть запись только в первые 256 кб, драйвера стандартные)
Несколько смущает HD.SYS, сейчас поищу нетронутый дистрибутив и посмотрю, как с нимКод:***** ДОСТУПНОЕ ОЗУ - 3,7 M *
@ 001000
@B
$DK0
RT-11SJ V05.04 F
.R MSCPCK
.DIR
SWAP .SYS 27P 06-Sep-88 RT11FB.SYS 93P 06-Sep-88
CR .SYS 3P 06-Sep-88 CT .SYS 6P 06-Sep-88
DD .SYS 5P 06-Sep-88 DL .SYS 4P 06-Sep-88
DM .SYS 5P 06-Sep-88 DP .SYS 3P 06-Sep-88
DS .SYS 3P 06-Sep-88 DT .SYS 3P 06-Sep-88
DU .SYS 7P 06-Sep-88 DX .SYS 4P 06-Sep-88
DY .SYS 4P 06-Sep-88 PD .SYS 3P 06-Sep-88
RF .SYS 3P 06-Sep-88 RK .SYS 3P 06-Sep-88
LD .SYS 8P 06-Sep-88 LP .SYS 2P 06-Sep-88
LS .SYS 5P 06-Sep-88 MM .SYS 10P 06-Sep-88
MS .SYS 10P 06-Sep-88 MT .SYS 9P 06-Sep-88
MU .SYS 13P 06-Sep-88 NL .SYS 2P 06-Sep-88
PC .SYS 2P 06-Sep-88 SL .SYS 17P 06-Sep-88
SLMIN .SYS 12P 06-Sep-88 SP .SYS 6P 06-Sep-88
TT .SYS 2P 06-Sep-88 VM .SYS 3P 06-Sep-88
XL .SYS 4P 06-Sep-88 STARTF.COM 6P 06-Sep-88
HELP .SAV 143P 06-Sep-88 V5USER.TXT 2P 06-Sep-88
DUP .SAV 49P 06-Sep-88 PIP .SAV 30P 06-Sep-88
DIR .SAV 19P 06-Sep-88 IND .SAV 58P 06-Sep-88
RESORC.SAV 26P 06-Sep-88 KED .SAV 58P 06-Sep-88
MACRO .SAV 63P 06-Sep-88 CREF .SAV 6P 06-Sep-88
LINK .SAV 49P 06-Sep-88 SYSMAC.SML 66P 06-Sep-88
SYSLIB.OBJ 47P 06-Sep-88 DATIME.SAV 4P 06-Sep-88
DATIME.COM 3P 06-Sep-88 LET .SAV 5P 06-Sep-88
SPLIT .SAV 3P 06-Sep-88 UCL .SAV 16P 06-Sep-88
SPOOL .REL 11P 06-Sep-88 VERIFY.COM 2P 06-Sep-88
MSCPCK.SAV 3P 06-Sep-88 RT11BL.SYS 78P 06-Sep-88
RT11SJ.SYS 79P 06-Sep-88 RT11XM.SYS 107P 06-Sep-88
DDX .SYS 5P 06-Sep-88 DLX .SYS 5P 06-Sep-88
DMX .SYS 5P 06-Sep-88 DUX .SYS 10P 06-Sep-88
DXX .SYS 4P 06-Sep-88 DYX .SYS 4P 06-Sep-88
LDX .SYS 8P 06-Sep-88 LPX .SYS 2P 06-Sep-88
LSX .SYS 5P 06-Sep-88 MMX .SYS 10P 06-Sep-88
MSX .SYS 11P 06-Sep-88 MTX .SYS 9P 06-Sep-88
MUX .SYS 16P 06-Sep-88 NLX .SYS 2P 06-Sep-88
NQX .SYS 7P 06-Sep-88 NUX .SYS 9P 06-Sep-88
RKX .SYS 3P 06-Sep-88 SLX .SYS 20P 06-Sep-88
SPX .SYS 6P 06-Sep-88 VMX .SYS 3P 06-Sep-88
XCX .SYS 4P 06-Sep-88 XLX .SYS 4P 06-Sep-88
STARTS.COM 1P 06-Sep-88 STARTX.COM 9P 06-Sep-88
KEX .SAV 53P 06-Sep-88 LIBR .SAV 24P 06-Sep-88
FILEX .SAV 22P 06-Sep-88 SRCCOM.SAV 26P 06-Sep-88
BINCOM.SAV 24P 06-Sep-88 SLP .SAV 13P 06-Sep-88
DUMP .SAV 9P 06-Sep-88 SIPP .SAV 21P 06-Sep-88
BUP .SAV 56P 06-Sep-88 PAT .SAV 10P 06-Sep-88
QUEMAN.SAV 15P 06-Sep-88 FORMAT.SAV 27P 06-Sep-88
SETUP .SAV 41P 06-Sep-88 VTCOM .SAV 24P 06-Sep-88
VBGEXE.SAV 16P 06-Sep-88 QUEUE .REL 14P 06-Sep-88
VTCOM .REL 27P 06-Sep-88 ODT .OBJ 8P 06-Sep-88
VDT .OBJ 8P 06-Sep-88 DBGSYM.SAV 10P 06-Sep-88
SDS .SYS 21P 06-Sep-88 SDH .SYS 21P 06-Sep-88
SDSX .SYS 21P 06-Sep-88 SDHX .SYS 21P 06-Sep-88
DW .SYS 6P 06-Sep-88 DZ .SYS 4P 06-Sep-88
PI .SYS 60P 06-Sep-88 XC .SYS 4P 06-Sep-88
DWX .SYS 6P 06-Sep-88 DZX .SYS 4P 06-Sep-88
NCX .SYS 9P 06-Sep-88 PIX .SYS 68P 06-Sep-88
RTMON .REL 8P 06-Sep-88 TRANSF.SAV 16P 06-Sep-88
TRANSF.TSK 76P 06-Sep-88 TRANSF.EXE 45P 06-Sep-88
MDUP .SAV 21P 06-Sep-88 MBOOT .BOT 1P 06-Sep-88
MBOT16.BOT 1P 06-Sep-88 MSBOOT.BOT 3P 06-Sep-88
MDUP .AI 56P 06-Sep-88 MDUP .MM 56P 06-Sep-88
MDUP .MS 56P 06-Sep-88 MDUP .MT 56P 06-Sep-88
MDUP .MU 56P 06-Sep-88 MTB .COM 15P 06-Sep-88
MSB .COM 15P 06-Sep-88 MUB .COM 15P 06-Sep-88
SYSGEN.COM 234P 06-Sep-88 BL .ANS 10P 06-Sep-88
SJFB .ANS 10P 06-Sep-88 XM .ANS 10P 06-Sep-88
HD .SYS 3 -BAD-
133 Files, 2832 Blocks
1930 Free blocks
@ 151532
@B
$ZF1
RT-11XM (S) V05.07
.RUN SY:TD3E
SUNDAY, 08-MAR-2020 14:40:07
.DIR RK:
08-Mar-2020
SWAP .SYS 27P 06-Sep-1988 RT11FB.SYS 93P 06-Sep-1988
CR .SYS 3P 06-Sep-1988 CT .SYS 6P 06-Sep-1988
DD .SYS 5P 06-Sep-1988 DL .SYS 4P 06-Sep-1988
DM .SYS 5P 06-Sep-1988 DP .SYS 3P 06-Sep-1988
DS .SYS 3P 06-Sep-1988 DT .SYS 3P 06-Sep-1988
DU .SYS 7P 06-Sep-1988 DX .SYS 4P 06-Sep-1988
DY .SYS 4P 06-Sep-1988 PD .SYS 3P 06-Sep-1988
RF .SYS 3P 06-Sep-1988 RK .SYS 3P 06-Sep-1988
LD .SYS 8P 06-Sep-1988 LP .SYS 2P 06-Sep-1988
LS .SYS 5P 06-Sep-1988 MM .SYS 10P 06-Sep-1988
MS .SYS 10P 06-Sep-1988 MT .SYS 9P 06-Sep-1988
MU .SYS 13P 06-Sep-1988 NL .SYS 2P 06-Sep-1988
PC .SYS 2P 06-Sep-1988 SL .SYS 17P 06-Sep-1988
SLMIN .SYS 12P 06-Sep-1988 SP .SYS 6P 06-Sep-1988
TT .SYS 2P 06-Sep-1988 VM .SYS 3P 06-Sep-1988
XL .SYS 4P 06-Sep-1988 STARTF.COM 6P 06-Sep-1988
HELP .SAV 143P 06-Sep-1988 V5USER.TXT 2P 06-Sep-1988
DUP .SAV 49P 06-Sep-1988 PIP .SAV 30P 06-Sep-1988
DIR .SAV 19P 06-Sep-1988 IND .SAV 58P 06-Sep-1988
RESORC.SAV 26P 06-Sep-1988 KED .SAV 58P 06-Sep-1988
MACRO .SAV 63P 06-Sep-1988 CREF .SAV 6P 06-Sep-1988
LINK .SAV 49P 06-Sep-1988 SYSMAC.SML 66P 06-Sep-1988
SYSLIB.OBJ 47P 06-Sep-1988 DATIME.SAV 4P 06-Sep-1988
DATIME.COM 3P 06-Sep-1988 LET .SAV 5P 06-Sep-1988
SPLIT .SAV 3P 06-Sep-1988 UCL .SAV 16P 06-Sep-1988
SPOOL .REL 11P 06-Sep-1988 VERIFY.COM 2P 06-Sep-1988
MSCPCK.SAV 3P 06-Sep-1988 RT11BL.SYS 78P 06-Sep-1988
RT11SJ.SYS 79P 06-Sep-1988 RT11XM.SYS 107P 06-Sep-1988
DDX .SYS 5P 06-Sep-1988 DLX .SYS 5P 06-Sep-1988
DMX .SYS 5P 06-Sep-1988 DUX .SYS 10P 06-Sep-1988
DXX .SYS 4P 06-Sep-1988 DYX .SYS 4P 06-Sep-1988
LDX .SYS 8P 06-Sep-1988 LPX .SYS 2P 06-Sep-1988
LSX .SYS 5P 06-Sep-1988 MMX .SYS 10P 06-Sep-1988
MSX .SYS 11P 06-Sep-1988 MTX .SYS 9P 06-Sep-1988
MUX .SYS 16P 06-Sep-1988 NLX .SYS 2P 06-Sep-1988
NQX .SYS 7P 06-Sep-1988 NUX .SYS 9P 06-Sep-1988
RKX .SYS 3P 06-Sep-1988 SLX .SYS 20P 06-Sep-1988
SPX .SYS 6P 06-Sep-1988 VMX .SYS 3P 06-Sep-1988
XCX .SYS 4P 06-Sep-1988 XLX .SYS 4P 06-Sep-1988
STARTS.COM 1P 06-Sep-1988 STARTX.COM 9P 06-Sep-1988
KEX .SAV 53P 06-Sep-1988 LIBR .SAV 24P 06-Sep-1988
FILEX .SAV 22P 06-Sep-1988 SRCCOM.SAV 26P 06-Sep-1988
BINCOM.SAV 24P 06-Sep-1988 SLP .SAV 13P 06-Sep-1988
DUMP .SAV 9P 06-Sep-1988 SIPP .SAV 21P 06-Sep-1988
BUP .SAV 56P 06-Sep-1988 PAT .SAV 10P 06-Sep-1988
QUEMAN.SAV 15P 06-Sep-1988 FORMAT.SAV 27P 06-Sep-1988
SETUP .SAV 41P 06-Sep-1988 VTCOM .SAV 24P 06-Sep-1988
VBGEXE.SAV 16P 06-Sep-1988 QUEUE .REL 14P 06-Sep-1988
VTCOM .REL 27P 06-Sep-1988 ODT .OBJ 8P 06-Sep-1988
VDT .OBJ 8P 06-Sep-1988 DBGSYM.SAV 10P 06-Sep-1988
SDS .SYS 21P 06-Sep-1988 SDH .SYS 21P 06-Sep-1988
SDSX .SYS 21P 06-Sep-1988 SDHX .SYS 21P 06-Sep-1988
DW .SYS 6P 06-Sep-1988 DZ .SYS 4P 06-Sep-1988
PI .SYS 60P 06-Sep-1988 XC .SYS 4P 06-Sep-1988
DWX .SYS 6P 06-Sep-1988 DZX .SYS 4P 06-Sep-1988
NCX .SYS 9P 06-Sep-1988 PIX .SYS 68P 06-Sep-1988
RTMON .REL 8P 06-Sep-1988 TRANSF.SAV 16P 06-Sep-1988
TRANSF.TSK 76P 06-Sep-1988 TRANSF.EXE 45P 06-Sep-1988
MDUP .SAV 21P 06-Sep-1988 MBOOT .BOT 1P 06-Sep-1988
MBOT16.BOT 1P 06-Sep-1988 MSBOOT.BOT 3P 06-Sep-1988
MDUP .AI 56P 06-Sep-1988 MDUP .MM 56P 06-Sep-1988
MDUP .MS 56P 06-Sep-1988 MDUP .MT 56P 06-Sep-1988
MDUP .MU 56P 06-Sep-1988 MTB .COM 15P 06-Sep-1988
MSB .COM 15P 06-Sep-1988 MUB .COM 15P 06-Sep-1988
SYSGEN.COM 234P 06-Sep-1988 BL .ANS 10P 06-Sep-1988
SJFB .ANS 10P 06-Sep-1988 XM .ANS 10P 06-Sep-1988
HD .SYS 3 28-Sep-2017
1930 Free blocks
.@TRK2
.time
14:40:36
.time
14:40:39
Ожидаемо - ничего не изменилось :)
Нуууу.. Теперь у меня есть Квант-2018, который думает, что у него есть RK11 :)Код:@B
$DK
?IND-F-File read error
No file accessed on channel
$BOOT 'INSPEC'
.BOO RT11SJ
RT-11SJ V05.02
.DIR
SWAP .SYS 27P 17-Jun-85 RT11AI.SYS 80P 17-Jun-85
RT11PI.SYS 94P 17-Jun-85 RT11BL.SYS 78P 17-Jun-85
RT11SJ.SYS 78P 17-Jun-85 RT11FB.SYS 92P 17-Jun-85
RT11XM.SYS 105P 17-Jun-85 CR .SYS 3P 17-Jun-85
CT .SYS 6P 17-Jun-85 DD .SYS 5P 17-Jun-85
DL .SYS 4P 17-Jun-85 DM .SYS 5P 17-Jun-85
DP .SYS 3P 17-Jun-85 DS .SYS 3P 17-Jun-85
DT .SYS 3P 17-Jun-85 DU .SYS 4P 17-Jun-85
DW .SYS 5P 17-Jun-85 DX .SYS 4P 17-Jun-85
DY .SYS 4P 17-Jun-85 DZ .SYS 4P 17-Jun-85
PD .SYS 3P 17-Jun-85 RF .SYS 3P 17-Jun-85
RK .SYS 3P 17-Jun-85 LD .SYS 8P 17-Jun-85
LP .SYS 2P 17-Jun-85 LS .SYS 3P 17-Jun-85
MM .SYS 9P 17-Jun-85 MS .SYS 10P 17-Jun-85
MT .SYS 9P 17-Jun-85 NL .SYS 2P 17-Jun-85
PC .SYS 2P 17-Jun-85 PI .SYS 59P 17-Jun-85
SL .SYS 14P 17-Jun-85 SLMIN .SYS 12P 17-Jun-85
SP .SYS 6P 17-Jun-85 TT .SYS 2P 17-Jun-85
VM .SYS 3P 17-Jun-85 XC .SYS 4P 17-Jun-85
XL .SYS 4P 17-Jun-85 DDX .SYS 5P 17-Jun-85
DLX .SYS 5P 17-Jun-85 DMX .SYS 5P 17-Jun-85
DUX .SYS 4P 17-Jun-85 DWX .SYS 5P 17-Jun-85
DXX .SYS 4P 17-Jun-85 DYX .SYS 4P 17-Jun-85
DZX .SYS 4P 17-Jun-85 LDX .SYS 8P 17-Jun-85
LPX .SYS 2P 17-Jun-85 LSX .SYS 3P 17-Jun-85
MMX .SYS 10P 17-Jun-85 MSX .SYS 11P 17-Jun-85
MTX .SYS 9P 17-Jun-85 NCX .SYS 9P 17-Jun-85
NLX .SYS 2P 17-Jun-85 NQX .SYS 7P 17-Jun-85
PIX .SYS 68P 17-Jun-85 RKX .SYS 3P 17-Jun-85
SLX .SYS 16P 17-Jun-85 SPX .SYS 6P 17-Jun-85
VMX .SYS 3P 17-Jun-85 XCX .SYS 4P 17-Jun-85
XLX .SYS 4P 17-Jun-85 STARTA.COM 60P 17-Jun-85
STARTF.COM 5P 17-Jun-85 STARTS.COM 1P 17-Jun-85
STARTX.COM 8P 17-Jun-85 PIP .SAV 30P 17-Jun-85
DUP .SAV 45P 17-Jun-85 DIR .SAV 19P 17-Jun-85
IND .SAV 56P 17-Jun-85 RESORC.SAV 24P 17-Jun-85
EDIT .SAV 19P 17-Jun-85 K52 .SAV 54P 17-Jun-85
KED .SAV 58P 17-Jun-85 KEX .SAV 53P 17-Jun-85
MACRO .SAV 61P 17-Jun-85 CREF .SAV 6P 17-Jun-85
LINK .SAV 49P 17-Jun-85 LIBR .SAV 24P 17-Jun-85
FILEX .SAV 22P 17-Jun-85 SRCCOM.SAV 26P 17-Jun-85
BINCOM.SAV 24P 17-Jun-85 SLP .SAV 13P 17-Jun-85
DUMP .SAV 9P 17-Jun-85 SIPP .SAV 21P 17-Jun-85
BUP .SAV 49P 17-Jun-85 PAT .SAV 10P 17-Jun-85
HELP .SAV 130P 17-Jun-85 SYSMAC.SML 50P 17-Jun-85
BATCH .SAV 26P 17-Jun-85 ERROUT.SAV 18P 17-Jun-85
QUEMAN.SAV 15P 17-Jun-85 FORMAT.SAV 24P 17-Jun-85
SETUP .SAV 41P 17-Jun-85 VTCOM .SAV 24P 17-Jun-85
SPEED .SAV 4P 17-Jun-85 DATIME.SAV 4P 17-Jun-85
DATIME.COM 3P 17-Jun-85 LET .SAV 5P 17-Jun-85
SPLIT .SAV 3P 17-Jun-85 UCL .SAV 15P 17-Jun-85
VBGEXE.SAV 16P 17-Jun-85 TERMID.SAV 3P 17-Jun-85
QUEUE .REL 14P 17-Jun-85 RTMON .REL 8P 17-Jun-85
SPOOL .REL 11P 17-Jun-85 VTCOM .REL 27P 17-Jun-85
TRANSF.SAV 16P 17-Jun-85 GIDIS .SAV 72P 17-Jun-85
ALPH00.FNT 9P 17-Jun-85 ODT .OBJ 8P 17-Jun-85
VDT .OBJ 8P 17-Jun-85 VTMAC .MAC 7P 17-Jun-85
VTHDLR.OBJ 8P 17-Jun-85 SYSLIB.OBJ 51P 17-Jun-85
PUTSTR.FOR 2P 17-Jun-85 GETSTR.FOR 2P 17-Jun-85
MDUP .SAV 20P 17-Jun-85 MBOOT .BOT 1P 17-Jun-85
MBOT16.BOT 1P 17-Jun-85 MSBOOT.BOT 3P 17-Jun-85
MDUP .MM 56P 17-Jun-85 MDUP .MS 56P 17-Jun-85
MDUP .MT 56P 17-Jun-85 DEMOBG.MAC 2P 17-Jun-85
DEMOFG.MAC 3P 17-Jun-85 DEMOX1.MAC 3P 17-Jun-85
DEMOF1.FOR 2P 17-Jun-85 DEMOED.TXT 1P 17-Jun-85
SAMPLE.KED 4P 17-Jun-85 VERIFY.COM 3P 17-Jun-85
IVP .COM 16P 17-Jun-85 IVP .MAC 25P 17-Jun-85
DISMT1.COM 9P 17-Jun-85 DISMT2.COM 7P 17-Jun-85
FB .MAC 1P 17-Jun-85 SJ .MAC 1P 17-Jun-85
XM .MAC 1P 17-Jun-85 BSTRAP.MAC 70P 17-Jun-85
EDTGBL.MAC 33P 17-Jun-85 KMON .MAC 122P 17-Jun-85
KMOVLY.MAC 217P 17-Jun-85 MTTEMT.MAC 18P 17-Jun-85
MTTINT.MAC 46P 17-Jun-85 RMONFB.MAC 149P 17-Jun-85
RMONSJ.MAC 71P 17-Jun-85 TRMTBL.MAC 19P 17-Jun-85
USR .MAC 67P 17-Jun-85 XMSUBS.MAC 40P 17-Jun-85
BA .MAC 20P 17-Jun-85 CR .MAC 15P 17-Jun-85
CT .MAC 33P 17-Jun-85 DD .MAC 26P 17-Jun-85
DL .MAC 36P 17-Jun-85 DM .MAC 26P 17-Jun-85
DP .MAC 11P 17-Jun-85 DS .MAC 10P 17-Jun-85
DT .MAC 9P 17-Jun-85 DU .MAC 33P 17-Jun-85
DW .MAC 31P 17-Jun-85 DX .MAC 21P 17-Jun-85
DY .MAC 23P 17-Jun-85 DZ .MAC 18P 17-Jun-85
EL .MAC 16P 17-Jun-85 LD .MAC 46P 17-Jun-85
LP .MAC 11P 17-Jun-85 LS .MAC 21P 17-Jun-85
NC .MAC 43P 17-Jun-85 NI .MAC 22P 17-Jun-85
NL .MAC 3P 17-Jun-85 NQ .MAC 26P 17-Jun-85
PC .MAC 5P 17-Jun-85 PD .MAC 12P 17-Jun-85
RF .MAC 7P 17-Jun-85 RK .MAC 11P 17-Jun-85
SP .MAC 42P 17-Jun-85 TJ .MAC 31P 17-Jun-85
TM .MAC 26P 17-Jun-85 TS .MAC 34P 17-Jun-85
TT .MAC 7P 17-Jun-85 VM .MAC 20P 17-Jun-85
XC .MAC 1P 17-Jun-85 XL .MAC 28P 17-Jun-85
FSM .MAC 32P 17-Jun-85 ELCOPY.MAC 15P 17-Jun-85
ELINIT.MAC 16P 17-Jun-85 ELTASK.MAC 9P 17-Jun-85
ERRTXT.MAC 6P 17-Jun-85 ERROUT.OBJ 15P 17-Jun-85
RTBL .MAP 21P 17-Jun-85 RTSJ .MAP 21P 17-Jun-85
RTFB .MAP 29P 17-Jun-85 RTXM .MAP 33P 17-Jun-85
SYSGEN.COM 217P 17-Jun-85 BL .ANS 9P 17-Jun-85
SJFB .ANS 9P 17-Jun-85 XM .ANS 9P 17-Jun-85
CONFIG.COM 27P 17-Jun-85 CONFIG.SAV 2P 17-Jun-85
V5USER.TXT 3P 17-Jun-85 V5NOTE.TXT 52P 17-Jun-85
CUSTOM.TXT 9P 17-Jun-85 CONSOL.MAC 6P 17-Jun-85
204 Files, 4723 Blocks
9 Free blocks
.SH A\A \ALL
?UCL-F-File not found SY:UCL.DAT
.SHO ALL
RT-11SJ V05.02
Booted from RK0:RT11SJ
USR is set SWAP
EXIT is set SWAP
KMON is set NOIND
TT is set NOQUIET
ERROR is set ERROR
SL is set OFF
EDIT is set KED
KMON nesting depth is 3
PDP 11/34 Processor
3840KB of memory
Extended Instruction Set (EIS)
Memory Management Unit
60 Cycle System Clock
FPU support
CR Not installed 177160 230
CT Not installed 177500 260
DD Not installed 176500 300 304
DL Not installed 174400 160
DM Not installed 177440 210
DP Not installed 176710 254
DS Not installed 172040 204
DT Not installed 177340 214
DU Not installed 172150 154
DW Not installed 000000
DX Not installed 177170 264
DY Not installed 177170 264
DZ Not installed 000000
PD Not installed 000000
RF Not installed 177460 204
RK Resident 177400 220
LP Not installed 177514 200
LS Not installed 173400 220 224
MM Not installed 172440 224
MS Not installed 172522 224 300
MT Not installed 172520 224
PC Not installed 177550 070 074
PI Not installed 000000 000
SP Installed 000000 110
TT Installed 000000 000
VM Installed 177572 250
XC Not installed 173300 210 214
XL Not installed 176500 300 304
TT
RK (Resident)
RK0 = DK , SY
LD
SL
VM
SP
NL
22 free slots
Job Name Console Level State Low High Impure
0 RESORC 0 0 Run 000000 147034 N/A
No multi-terminal support
Address Module Words
160000 IOPAGE 4096.
157402 RK 127.
147076 RMON 2146.
001000 ..BG.. 26143.
No LD units mounted
Пошел запись допиливать... Потом Unibus регистры... Потом посмотрю, на какой функционал, помимо чтения/записи можно будет налететь в операционках - проверю-доделаю его
Вдогонку - загрузчик RK поправил. Там вообще какая то странная хрень и похоже - не только с ним. Но поскольку других контроллеров из списка нет ни в каком виде - разбираться не полезу. Жаль только, что RL11 нет - придётся добавлять, а места там фактически нету - надо будет что то выкидывать. Но пока - не горит
О, надо XM проверить :)
А работает :)
Хм.. А вот, наверное, стоит ещё DP (RP11 - RP02(20Мб) - RP03(40 мб), если не ошибаюсь) диски сделать - вроде по сложности контроллера они похожи на RK11, а емкость уже значительно получше. И в отличии от RL11 - сектор 512 байт, а не 256. И загрузчик (рабочий?) в 134-ой прошивке есть.
По поводу ХМ на 1801ВМ3 в R11 5.2 прикол такой, если задача не использует расширенную память, то можно пользоваться драйвером от монитора сгенерённым не для диспетчера памяти. А вот ежели использует, то крах ...:v2_dizzy_tired2:
Конечно нужно флаги генерации выставить соответствующе и название файла изменить...
