Dragoos, maybe I misunderstand You. Do You mean that You want to see the documents? If yes, I can upload somewhere or send You via e-mail.
Petya, Please share scheme where the store scanned realties, so you can see them
You can download the documents here:
http://rapidshare.com/files/445620652/Turnir_manual.zip
Thanks a lot once again for Panther!
The thank, Petya, but почемуто does not boot with this page anything.
Click on "Slow download", than You have to wait about 2 seconds, than click on "Download now!"
Petya, why that the file does not want to be injected. Lay out here on a forum. Here it is possible to attach photographs and documents to the messages. Below, where you write characters. In archive it is better.
---------- Post added at 17:40 ---------- Previous post was at 17:33 ----------
Petya, all has downloaded a thank! Has utillized other browser is simple! :D Let's understand now....!!!!! :smile:
---------- Post added at 17:50 ---------- Previous post was at 17:40 ----------
Petya - wire, about which one you spoke on a board couples an aerial(antenna) wire to the shield. It is the reel under the schema L4 . She(it) should not be put away, she(it) correctly there is. :biggrin: :smile:
---------- Post added at 18:24 ---------- Previous post was at 17:50 ----------
Petya suggest only one I can - interchange necessarily all electrolytic capacitors. And if the cue goes on an exit, but map is not present, then try to augment C9 in the modulator up to 2.2 mF, and C3 up to 22 pF. It helps can for hooking up to new modern TV sets. And to tune on the channel television by the reel L2. The truth will take up it a little time, but if it for you is, then there is a sense to try. :redface: :biggrin:
Dragoos, писал бы ты лучше на русском. При переводе русский -> венгерский теряется гораздо меньше смысла, чем при переводе русский -> английский -> венгерский :)
Dragoos, you'd better write in Russian. When translating "Russian -> Hungarian" lost much less sense than when translating "Russian -> English -> Hungarian" :)
RST 0, А Я думал это была готовая коробка:v2_thumb:
