Как оно выглядит:
- - - Добавлено - - -Код:...
signal Display0 : typeBus;
signal CF_A : typeBus;
DisplayInst0: Display
port map
baseAddr => DisplayBase(12 downto 0)
, busClock => extClock
, FromBus => Display0.FromBus
, ToBus => Display0.ToBus
, displayClock => intEighthExtClock
, D_OUT => D_OUT
, SHIFT => SHIFT
, STORE => STORE
-- --- синий -------------------------------------------------------------------
CFInstA : CF
generic map
miniversion => "no"
port map
baseAddr => CF_A_BaseAddr(12 downto 0)
, baseVec => CF_A_Vector
, FromBus => CF_A.FromBus
, ToBus => CF_A.ToBus
, isWriting => intIsCF_A_Writing
, devCS0_L => devCF_AA_CS0_L
, devCS1_L => devCF_AA_CS1_L
, devReady => devCF_AA_Ready
-- , devReset_L =>
, devIORead_L => intCF_A_IORead_L
, devIOWrite_L => intCF_A_IOWrite_L
, devInData => intCF_AC_Data
, devOutData => intOutCF_A_Data
, devIRQ => devCF_AA_IRQ
, devDMAAck_L => devCF_AA_DMAAck_L
Chasis0: Chasis
generic map
SlotsCount => 8
port map
FromBus => slaveFromBus
, slotsTo(0) => Display0.FromBus
, slotsFrom(0) => Display0.ToBus
, slotsTo(1) => CF_A.FromBus
, slotsFrom(1) => CF_A.ToBus
, slotsTo(2) => CF_B.FromBus
, slotsFrom(2) => CF_B.ToBus
, slotsTo(3) => CF_C.FromBus
, slotsFrom(3) => CF_C.ToBus
, slotsTo(4) => CF_D.FromBus
, slotsFrom(4) => CF_D.ToBus
, slotsTo(5) => Uart0.FromBus
, slotsFrom(5) => Uart0.ToBus
, slotsTo(6) => Uart1.FromBus
, slotsFrom(6) => Uart1.ToBus
, slotsTo(7) => RK0.FromBus
, slotsFrom(7) => RK0.ToBus
, ToBus => slaveToBus
Малость переименовал :)
На очереди - unibus mapping регистры
Было
СталоКод:.sho conf
RT-11XM (S) V05.07
Booted from RK0:RT11XM
22 bit addressing is on
USR is set NOSWAP
EXIT is set SWAP
KMON is set NOIND
RUN is set NOVBGEXE
MODE is set NOSJ
TT is set NOQUIET
ERROR is set ERROR
SL is set OFF
EDIT is set KEX
FORTRAN is set FORTRA
KMON nesting depth is 3
Global .SCCA flag is disabled
CLI is set DCL, CCL, UCL, NO UCF
PDP 11/34 Processor
3840KB of memory
Extended Instruction Set (EIS)
Memory Management Unit
50 Hertz System Clock
Device I/O time-out support
Global .SCCA support
Extended unit support
UNIBUS mapping unavailable
Теперь собственно трансляция.Код:
.sho conf
RT-11XM (S) V05.07
USR is set NOSWAP
EXIT is set SWAP
KMON is set NOIND
RUN is set NOVBGEXE
MODE is set NOSJ
TT is set NOQUIET
ERROR is set ERROR
SL is set OFF
EDIT is set KEX
PDP 11/34 Processor
3840KB of memory
UNIBUS mapping disabled
Уф.. Как хорошо с корзинкой то :D
Хе хе, в RSX тоже:
Код:>con display attributes for sys
SYS
PDP-11/34, EIS,UNIBUS_Map,
Clock=KW11-L, $TKPS=50., $TTPRM=000002
