может у них вооще изначально 4 градации яркости
а потом кто то прикрутил цвет
щас прибигут бкшники
и заявят что так и должно быть
и что оптимальный экран в ширину 391 пиксель ровно
https://i.ibb.co/8M3LzPL/avatar7208-7.png
Код:.BYTE 15, 144
.BYTE 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377
.BYTE 377, 377, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377
.BYTE 377, 377, 377, 377, 37, 37, 376, 376, 377, 377, 377, 377, 377, 377, 17, 17, 377, 377
.BYTE 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 347, 7, 371, 370, 377, 377
.BYTE 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377
.BYTE 377, 377, 373, 163, 363, 360, 377, 377, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377
.BYTE 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 371, 161, 363, 360, 377, 377, 377, 377
.BYTE 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377
.BYTE 371, 1, 367, 360, 377, 377, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377
.BYTE 377, 377, 377, 377, 377, 377, 377, 377, 375, 1, 367, 360, 377, 377, 377, 377, 377, 377
.BYTE 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 371, 1
.BYTE 367, 360, 377, 377, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377
.BYTE 377, 377, 377, 377, 377, 377, 371, 1, 363, 360, 377, 377, 377, 377, 377, 377, 17, 17
.BYTE 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 363, 3, 361, 360
.BYTE 377, 377, 377, 377, 103, 3, 360, 370, 377, 377, 377, 377, 377, 377, 17, 17, 377, 377
.BYTE 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 7, 7, 374, 374, 377, 377
.BYTE 377, 377, 303, 303, 377, 377, 1, 1, 376, 376, 377, 377, 17, 17, 377, 377, 377, 377
.BYTE 377, 377, 0, 0, 370, 370, 377, 377, 377, 377, 313, 343, 377, 377, 16, 0, 370, 370
.BYTE 377, 377, 17, 17, 377, 377, 377, 377, 37, 37, 0, 36, 342, 343, 377, 377, 377, 377
.BYTE 313, 343, 177, 177, 377, 2, 360, 360, 377, 377, 17, 17, 377, 377, 377, 377, 343, 343
.BYTE 77, 177, 34, 34, 340, 340, 377, 377, 343, 343, 77, 77, 375, 14, 361, 360, 377, 377
.BYTE 17, 17, 377, 377, 377, 377, 261, 261, 377, 377, 70, 70, 0, 0, 377, 377, 340, 340
.BYTE 77, 77, 14, 4, 343, 340, 377, 377, 17, 17, 377, 377, 377, 377, 200, 274, 370, 370
.BYTE 160, 162, 30, 30, 176, 176, 344, 340, 277, 277, 4, 0, 304, 340, 377, 377, 17, 17
.BYTE 377, 377, 177, 177, 116, 136, 360, 360, 340, 354, 362, 362, 174, 174, 307, 307, 77, 77
.BYTE 74, 0, 304, 300, 377, 377, 17, 17, 377, 377, 77, 77, 177, 177, 30, 30, 300, 354
.BYTE 307, 347, 1, 1, 307, 307, 77, 77, 376, 74, 300, 300, 377, 377, 17, 17, 377, 377
.BYTE 277, 77, 375, 175, 10, 10, 307, 316, 215, 317, 367, 377, 300, 301, 37, 37, 204, 0
.BYTE 301, 300, 377, 377, 17, 17, 377, 377, 237, 237, 370, 370, 314, 314, 37, 277, 200, 301
.BYTE 7, 207, 203, 203, 3, 3, 0, 0, 300, 300, 377, 377, 17, 17, 377, 377, 237, 37
.BYTE 370, 370, 157, 157, 74, 74, 0, 303, 157, 157, 30, 76, 62, 362, 0, 0, 300, 300
.BYTE 377, 377, 17, 17, 377, 377, 337, 337, 10, 10, 66, 46, 174, 74, 0, 3, 316, 336
.BYTE 160, 175, 10, 370, 0, 75, 300, 300, 377, 377, 17, 17, 377, 377, 337, 337, 14, 10
.BYTE 40, 40, 174, 174, 170, 172, 300, 334, 303, 373, 1, 375, 0, 371, 300, 301, 377, 377
.BYTE 17, 17, 377, 377, 217, 317, 177, 17, 40, 40, 4, 4, 370, 372, 100, 134, 203, 227
.BYTE 1, 335, 0, 343, 300, 303, 377, 377, 17, 17, 377, 377, 17, 117, 77, 57, 140, 144
.BYTE 4, 4, 360, 362, 0, 30, 6, 46, 17, 237, 0, 7, 300, 307, 377, 377, 17, 17
.BYTE 377, 377, 17, 117, 0, 0, 300, 334, 7, 7, 340, 342, 1, 30, 2, 46, 0, 37
.BYTE 0, 16, 300, 314, 377, 377, 17, 17, 377, 377, 217, 317, 3, 3, 200, 236, 37, 3
.BYTE 0, 6, 0, 30, 200, 304, 0, 37, 0, 14, 300, 300, 377, 377, 17, 17, 377, 377
.BYTE 317, 317, 17, 17, 0, 36, 0, 0, 0, 6, 300, 330, 1, 311, 0, 37, 200, 314
.BYTE 200, 201, 377, 377, 17, 17, 377, 377, 57, 57, 76, 34, 360, 377, 1, 1, 140, 142
.BYTE 200, 230, 3, 313, 0, 37, 0, 14, 200, 200, 377, 377, 17, 17, 377, 377, 57, 57
.BYTE 74, 74, 60, 77, 7, 7, 0, 2, 0, 30, 3, 303, 0, 37, 0, 14, 0, 0
.BYTE 377, 377, 17, 17, 377, 377, 57, 17, 64, 64, 20, 36, 16, 16, 0, 0, 0, 30
.BYTE 0, 300, 0, 37, 0, 10, 0, 0, 376, 376, 17, 17, 377, 377, 57, 57, 2, 0
.BYTE 23, 37, 16, 16, 20, 20, 0, 30, 0, 320, 0, 37, 0, 10, 0, 0, 376, 376
.BYTE 17, 17, 377, 377, 117, 117, 342, 342, 37, 37, 12, 2, 70, 70, 0, 0, 0, 320
.BYTE 0, 17, 0, 0, 0, 0, 376, 376, 17, 17, 377, 377, 237, 237, 67, 63, 37, 37
.BYTE 3, 2, 170, 170, 0, 0, 0, 360, 0, 17, 0, 0, 0, 0, 376, 376, 17, 17
.BYTE 377, 377, 37, 37, 30, 20, 376, 276, 1, 1, 0, 0, 300, 300, 0, 300, 0, 17
.BYTE 0, 0, 0, 0, 377, 377, 17, 17, 377, 377, 37, 37, 20, 20, 316, 316, 1, 1
.BYTE 0, 0, 300, 300, 1, 300, 0, 17, 0, 0, 0, 0, 377, 377, 17, 17, 377, 377
.BYTE 77, 77, 20, 23, 2, 0, 0, 0, 4, 0, 200, 200, 0, 300, 0, 7, 0, 0
.BYTE 0, 0, 377, 377, 17, 17, 377, 377, 77, 77, 60, 66, 2, 2, 0, 0, 0, 0
.BYTE 0, 0, 0, 300, 0, 7, 0, 0, 200, 200, 377, 377, 17, 17, 377, 377, 177, 177
.BYTE 340, 344, 17, 3, 0, 0, 0, 0, 40, 40, 0, 300, 0, 3, 0, 0, 200, 200
.BYTE 377, 377, 17, 17, 377, 377, 377, 377, 300, 300, 7, 1, 0, 0, 0, 0, 0, 0
.BYTE 0, 300, 0, 3, 0, 0, 200, 200, 377, 377, 17, 17, 377, 377, 377, 377, 1, 1
.BYTE 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 200, 200, 377, 377
.BYTE 17, 17, 377, 377, 377, 377, 3, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
.BYTE 0, 0, 0, 0, 200, 200, 377, 377, 17, 17, 377, 377, 377, 377, 77, 77, 0, 0
.BYTE 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 200, 200, 377, 377, 17, 17
.BYTE 377, 377, 377, 377, 377, 377, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
.BYTE 0, 0, 300, 300, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 37, 37, 0, 0
.BYTE 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 300, 300, 377, 377, 17, 17, 377, 377
.BYTE 377, 377, 377, 377, 177, 177, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
.BYTE 340, 340, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 1, 1, 0, 0
.BYTE 0, 0, 0, 0, 0, 0, 0, 0, 360, 360, 377, 377, 17, 17, 377, 377, 377, 377
.BYTE 377, 377, 377, 377, 37, 37, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 370, 374
.BYTE 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 37, 37, 0, 0, 0, 0
.BYTE 0, 0, 0, 0, 0, 0, 376, 376, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377
.BYTE 377, 377, 37, 37, 0, 0, 0, 0, 0, 0, 40, 40, 0, 0, 376, 376, 377, 377
.BYTE 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 37, 37, 0, 0, 0, 0, 0, 0
.BYTE 60, 60, 0, 0, 376, 376, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377
.BYTE 37, 37, 0, 0, 0, 0, 0, 0, 60, 60, 6, 0, 376, 376, 377, 377, 17, 17
.BYTE 377, 377, 377, 377, 377, 377, 377, 377, 37, 37, 0, 0, 0, 0, 0, 0, 40, 40
.BYTE 0, 0, 376, 376, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 37, 137
.BYTE 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 376, 376, 377, 377, 17, 17, 377, 377
.BYTE 377, 377, 377, 377, 377, 377, 237, 337, 0, 1, 0, 0, 0, 0, 0, 0, 60, 0
.BYTE 376, 376, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 37, 337, 16, 17
.BYTE 0, 0, 0, 0, 0, 0, 40, 0, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377
.BYTE 377, 377, 377, 377, 37, 337, 360, 377, 1, 7, 0, 0, 0, 0, 0, 0, 377, 377
.BYTE 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 37, 337, 0, 377, 14, 17
.BYTE 0, 0, 0, 0, 214, 200, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377
.BYTE 377, 377, 37, 237, 0, 377, 0, 17, 0, 0, 0, 0, 210, 200, 377, 377, 377, 377
.BYTE 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 37, 37, 0, 376, 0, 17, 0, 0
.BYTE 0, 0, 200, 200, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377
.BYTE 77, 77, 0, 340, 0, 17, 0, 0, 0, 0, 300, 300, 377, 377, 377, 377, 17, 17
.BYTE 377, 377, 377, 377, 377, 377, 377, 377, 177, 177, 0, 0, 0, 0, 0, 0, 0, 0
.BYTE 341, 340, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377
.BYTE 0, 0, 0, 0, 0, 0, 0, 0, 360, 360, 377, 377, 377, 377, 17, 17, 377, 377
.BYTE 377, 377, 217, 217, 7, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 370, 370
.BYTE 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 43, 43, 340, 340, 177, 177, 0, 0
.BYTE 0, 0, 0, 0, 0, 0, 374, 374, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377
.BYTE 173, 173, 376, 376, 377, 377, 0, 0, 0, 0, 0, 0, 0, 0, 360, 360, 377, 377
.BYTE 377, 377, 17, 17, 377, 377, 377, 377, 173, 173, 16, 36, 300, 300, 6, 6, 0, 0
.BYTE 160, 160, 0, 0, 0, 0, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 170, 170
.BYTE 0, 0, 100, 0, 3, 7, 0, 0, 20, 0, 0, 0, 60, 20, 377, 377, 377, 377
.BYTE 17, 17, 377, 377, 77, 77, 36, 36, 0, 0, 0, 200, 3, 3, 3, 3, 70, 10
.BYTE 0, 0, 130, 30, 377, 377, 377, 377, 17, 17, 377, 377, 237, 237, 17, 17, 0, 0
.BYTE 200, 200, 1, 1, 3, 3, 20, 0, 0, 0, 70, 50, 376, 376, 377, 377, 17, 17
.BYTE 377, 377, 303, 303, 3, 1, 0, 0, 300, 300, 0, 1, 0, 0, 0, 0, 0, 0
.BYTE 74, 54, 374, 374, 377, 377, 17, 17, 177, 177, 374, 374, 200, 0, 0, 200, 301, 303
.BYTE 0, 1, 0, 0, 4, 0, 0, 1, 74, 14, 370, 370, 377, 377, 17, 17, 37, 37
.BYTE 177, 177, 140, 0, 370, 370, 361, 363, 1, 0, 0, 0, 200, 200, 17, 17, 34, 24
.BYTE 341, 340, 377, 377, 17, 17, 237, 237, 377, 377, 7, 7, 374, 374, 171, 171, 200, 0
.BYTE 3, 0, 220, 200, 77, 77, 234, 200, 203, 201, 377, 377, 17, 17, 337, 337, 377, 377
.BYTE 77, 77, 376, 376, 175, 75, 214, 200, 377, 160, 237, 236, 377, 377, 0, 0, 0, 0
.BYTE 376, 376, 17, 17, 337, 337, 377, 377, 77, 77, 376, 376, 375, 375, 211, 201, 377, 1
.BYTE 37, 4, 376, 376, 174, 174, 370, 370, 374, 374, 17, 17, 377, 377, 77, 77, 160, 100
.BYTE 376, 376, 374, 374, 203, 3, 377, 137, 17, 4, 174, 174, 376, 376, 377, 377, 370, 370
.BYTE 17, 17, 337, 337, 77, 77, 170, 100, 376, 376, 374, 374, 7, 7, 374, 0, 3, 0
.BYTE 174, 174, 377, 377, 177, 177, 370, 370, 17, 17, 337, 337, 37, 37, 170, 50, 74, 74
.BYTE 174, 74, 17, 17, 0, 0, 200, 200, 177, 177, 377, 377, 207, 3, 371, 371, 17, 17
.BYTE 237, 237, 37, 37, 170, 70, 14, 14, 74, 70, 16, 16, 0, 0, 374, 374, 177, 177
.BYTE 376, 376, 203, 203, 361, 361, 17, 17, 77, 77, 36, 36, 30, 0, 340, 340, 77, 77
.BYTE 4, 4, 374, 376, 377, 377, 377, 377, 376, 376, 203, 3, 301, 301, 17, 17, 177, 177
.BYTE 0, 0, 0, 0, 360, 360, 77, 77, 0, 0, 374, 374, 377, 377, 377, 377, 376, 376
.BYTE 203, 3, 301, 300, 17, 17, 377, 377, 0, 0, 200, 200, 371, 371, 77, 77, 300, 300
.BYTE 374, 374, 377, 377, 377, 377, 374, 374, 3, 3, 300, 300, 17, 17, 377, 377, 377, 377
.BYTE 377, 377, 371, 371, 77, 77, 370, 370, 375, 375, 377, 377, 377, 377, 341, 341, 3, 3
.BYTE 360, 360, 17, 17, 377, 377, 377, 377, 377, 377, 373, 373, 77, 77, 377, 376, 371, 371
.BYTE 377, 377, 377, 377, 3, 3, 0, 0, 376, 376, 17, 17, 377, 377, 377, 377, 377, 377
.BYTE 377, 377, 377, 377, 377, 377, 370, 370, 377, 377, 377, 377, 37, 37, 300, 300, 377, 377
.BYTE 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 177, 177, 370, 370, 377, 377
.BYTE 377, 377, 377, 377, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 373, 373
.BYTE 377, 377, 237, 37, 370, 370, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 17, 17
.BYTE 377, 377, 377, 377, 377, 377, 371, 371, 377, 377, 303, 303, 1, 0, 376, 376, 377, 377
.BYTE 377, 377, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 371, 371, 77, 77
.BYTE 360, 240, 0, 0, 376, 376, 377, 377, 377, 377, 377, 377, 377, 377, 17, 17, 377, 377
.BYTE 377, 377, 377, 377, 371, 371, 77, 77, 360, 40, 0, 0, 376, 376, 377, 377, 377, 377
.BYTE 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 363, 363, 77, 77, 160, 140
.BYTE 0, 0, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377
.BYTE 377, 377, 303, 303, 77, 77, 60, 0, 200, 200, 377, 377, 377, 377, 377, 377, 377, 377
.BYTE 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 7, 7, 76, 76, 0, 0, 360, 360
.BYTE 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377
.BYTE 37, 37, 0, 0, 0, 0, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377
.BYTE 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 3, 3, 360, 360, 377, 377, 377, 377
.BYTE 377, 377, 377, 377, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377
.BYTE 77, 77, 374, 374, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 17, 17
вот красота )
https://zx-pk.ru/threads/31550-bk001...=1#post1057485
A так видят РК'шники:v2_lol:
WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW WWWWWWWWWWWWWWWWWWWWWWWWWWWWW
WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW@=* *=#WWWWWWWWWWWWWWWWWWWWWWWWWW
WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW@=** **=#WWWWWWWWWWWWWWWWWWWWWWWWW
WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW@=== ==#@WWWWWWWWWWWWWWWWWWWWWWWWW
WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW## #@WWWWWWWWWWWWWWWWWWWWWWWWWWW
WWWWWWWWWWWWWWWWWWWW@@@@@@@WWWWWWWWWWWWWWWWWWWW##W WWWWWWWW@###@@@WWWWWWWWWWWWWW
WWWWWWWWWWWWWWW@#==*++++=##=*=@@@@WWWWWWWWWWWW@=WW WWWWWWW@#======#@WWWWWWWWWWWW
WWWWWWWWWWWWW#=====#@#++:*###=*===#===@WWWWW#++=@W WWWWWW@##==######@WWWWWWWWWWW
WWWWWWWWWWW@===+::*#@=*#=***======*##=**======###@ WWWWW@@##=#######@WWWWWWWWWWW
WWWWWWWWWW@==@#*====**=+*##+-:*#=#####==*====#====#WW#====##=######@WWWWWWWWWWW
WWWWWWWWWW#=**+*===@###*=@#*###@#==:-:=#==#==*=###====##==###====#@WWWWWWWWWWW
WWWWWWWWWW#====######===****==#@#=##===##=####=### =====####=########@WWWWWWWWWW
WWWWWWWWW@==@#+:+=#====****=#####=#===#@#=##+:=### =====###########@#@WWWWWWWWWW
WWWWWWWWW@==@#=####===*#@#*:+#@#@@#=#####==###@### =====###@###@###@@#@@WWWWWWWW
WWWWWWWWWW@=**==**#*::+*#=*#@@@###*++=@@@@@######= ====###@###########@WWWWWWWWW
WWWWWWWWWWWW###=*#@#*=##==##@@####=##@@##@@**##@@# ====###@##@#######@WWWWWWWWWW
WWWWWWWWWWWWW@##=+*+*==@####@#@@@###@@####==#@##@# ===#@#@##@########@WWWWWWWWWW
WWWWWWWWWWWWWWW@@@###@@@@@@##==#@#@@#####@@#@#@@@@ ##@@@@##@@#####@##@@WWWWWWWWW
WWWWWWWWWWWWWWWWWWWW@@WW@@@@@@@@@###@@##@@@@@@@@@@ ######@@@@###@@@@@WWWWWWWWWWW
WWWWWWWWWWWWWWWWWWWWWWWWWWWWW@@@@@@@@@@@@@@@@@@##@ @@@@@@###@@@@@@@WWWWWWWWWWWWW
WWWWWWWWWWWWWWWWWWWWWWWWWWWWWW@@@@@@@@@@@@@@@@@@@# ###@@@W@#####@@WWWWWWWWWWWWWW
WWWWWWWWWWWWWWWWWWWWWWWWWWWWWW@@@@@@@@@@@@@@@@@@@@ @@#@WWW#######@WWWWWWWWWWWWWW
WWWWWWWWWWWWWWWWWWWWWWWWWWWWW@###@@@@@@@@@@@@@@@@@ @@@#@W@######@WWWWWWWWWWWWWWW
WWWWWWWWWWWWWWWWWWWWWWWWWWWWWW#=======####@@@@@@@@ @#@@@@#######@WWWWWWWWWWWWWWW
WWWWWWWWWWWWWWWWWWWWWWWWWWWWWW@#=========#@@@@@### #@@########@WWWWWWWWWWWWWWWWW
WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW@@@#######@@@@@@@@ @########@@WWWWWWWWWWWWWWWWWW
WWWWWWWWWWWWWWWW@@WWWW@@@@@@###@W@@@@@@@@@@@@@@@@@ @@####@@W@WWWWWWWWWWWWWWWWWWW
WWWWWWWWWWWWWW@+--*#**====####**==#@#@@@@@@@@@@#**#####@@@@@#@WWWWW WWWWWWWWWWW
WWWWWWWWWWWW@=++=##@@@@@####@@#=*=#@##*:#@@@@@#=== #@########**=#WWWWWWWWWWWWWWW
WWWWWW@#==*:+=####=#@@@@@WW@@@=*=#@######=======#@ @WW@@@###**==#@WWWWWWWWWWWWWW
WWWW#*+::::++++*==#@WWWWWWW=::+#@#=##============# WWWWWWW@#==##===#@@WWWWWWWWWW
WWWW*:::::+====**==@WWWWWW@*::::+*==@#=******=*==# @@WWWWW@*++++++++:::*@WWWWWWW
WWWW#*::::*#@##=**=@WWWWW@#*+:*#*:+#W@@@@####@@@@@ WWWWWWW#+::::::*==#===WWWWWWW
WWWWWW@#=*=#@@#=#@@@@@=+::++-:*####@@@@WWWWWWWWWWWWWWWWWW@*::::::*@@#=*=##@WWWW
WWWWWWWWWWWWWWWWWWWW@*::::++::=##=*+::+#WWWWWWWWWW WWWWWWWWW@#=***=@@@@@W@WWWWWW
WWWWWWWWWWWWWWWWWWWW@+++:::::::::::::+*#@WWWWWWWWW WWWWWWWWWWWWWWWWWWWWWWWWWWWWW
WWWWWWWWWWWWWWWWWWWW@*::::+++++**====*=#@@@@WWWWWW WWWWWWWWWWWWWWWWWWWWWWWWWWWWW
WWWWWWWWWWWWWWWWWWWWW@*:::::::*#@@#=*=##=##@@WWWWW WWWWWWWWWWWWWWWWWWWWWWWWWWWWW
WWWWWWWWWWWWWWWWWWWWWWWW@#=*++=@@@@@@WWWWWWWWWWWWW WWWWWWWWWWWWWWWWWWWWWWWWWWWWW
WWWWWWWWWWWWWWWWWWWWWWWWWWWW@@@@@@WWWWWWWWWWWWWWWW WWWWWWWWWWWWWWWWWWWWWWWWWWWWW
Радио-86РК, а можно на 80 символов в строку переделать, тогда на Фрязинский терминал влезет?
