C:\A>str750prog.exe --port COM3 --write --address 0x20008000 speccy2010.bin
str75x prog v1.2
initializing device - error
done with 1 error(s)..
каждый раз пишет одно и тоже
получилось, после ручной прошивки log такой:
Speccy2010 boot ver 1.1!
SD card init OK..
Speccy2010, ver 1.0, rev 64 !
RTC init OK..
SD card init OK..
FPGA cofiguration file /speccy2010.rbf is opened...
FPGA configuration started...
FPGA configuration status OK...
..................................FPGA configuration conf done...
FPGA configuration finished...
Speccy2010 FPGA configuration found...
FPGA clock - 19.99632 MHz
FPGA PLL clock - 83.98452 MHz
ROM configuration started...
ROM configuration finished...
