Хобот подскажи как запустить ваш код?Цитата:
https://i.ibb.co/8M3LzPL/avatar7208-7.png
Код:.BYTE 15, 144
.BYTE 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377
.BYTE 377, 377, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377
.BYTE 377, 377, 377, 377, 37, 37, 376, 376, 377, 377, 377, 377, 377, 377, 17, 17, 377, 377
.BYTE 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 347, 7, 371, 370, 377, 377
.BYTE 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377
.BYTE 377, 377, 373, 163, 363, 360, 377, 377, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377
.BYTE 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 371, 161, 363, 360, 377, 377, 377, 377
.BYTE 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377
.BYTE 371, 1, 367, 360, 377, 377, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377
.BYTE 377, 377, 377, 377, 377, 377, 377, 377, 375, 1, 367, 360, 377, 377, 377, 377, 377, 377
.BYTE 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 371, 1
.BYTE 367, 360, 377, 377, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377
.BYTE 377, 377, 377, 377, 377, 377, 371, 1, 363, 360, 377, 377, 377, 377, 377, 377, 17, 17
.BYTE 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 363, 3, 361, 360
.BYTE 377, 377, 377, 377, 103, 3, 360, 370, 377, 377, 377, 377, 377, 377, 17, 17, 377, 377
.BYTE 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 7, 7, 374, 374, 377, 377
.BYTE 377, 377, 303, 303, 377, 377, 1, 1, 376, 376, 377, 377, 17, 17, 377, 377, 377, 377
.BYTE 377, 377, 0, 0, 370, 370, 377, 377, 377, 377, 313, 343, 377, 377, 16, 0, 370, 370
.BYTE 377, 377, 17, 17, 377, 377, 377, 377, 37, 37, 0, 36, 342, 343, 377, 377, 377, 377
.BYTE 313, 343, 177, 177, 377, 2, 360, 360, 377, 377, 17, 17, 377, 377, 377, 377, 343, 343
.BYTE 77, 177, 34, 34, 340, 340, 377, 377, 343, 343, 77, 77, 375, 14, 361, 360, 377, 377
.BYTE 17, 17, 377, 377, 377, 377, 261, 261, 377, 377, 70, 70, 0, 0, 377, 377, 340, 340
.BYTE 77, 77, 14, 4, 343, 340, 377, 377, 17, 17, 377, 377, 377, 377, 200, 274, 370, 370
.BYTE 160, 162, 30, 30, 176, 176, 344, 340, 277, 277, 4, 0, 304, 340, 377, 377, 17, 17
.BYTE 377, 377, 177, 177, 116, 136, 360, 360, 340, 354, 362, 362, 174, 174, 307, 307, 77, 77
.BYTE 74, 0, 304, 300, 377, 377, 17, 17, 377, 377, 77, 77, 177, 177, 30, 30, 300, 354
.BYTE 307, 347, 1, 1, 307, 307, 77, 77, 376, 74, 300, 300, 377, 377, 17, 17, 377, 377
.BYTE 277, 77, 375, 175, 10, 10, 307, 316, 215, 317, 367, 377, 300, 301, 37, 37, 204, 0
.BYTE 301, 300, 377, 377, 17, 17, 377, 377, 237, 237, 370, 370, 314, 314, 37, 277, 200, 301
.BYTE 7, 207, 203, 203, 3, 3, 0, 0, 300, 300, 377, 377, 17, 17, 377, 377, 237, 37
.BYTE 370, 370, 157, 157, 74, 74, 0, 303, 157, 157, 30, 76, 62, 362, 0, 0, 300, 300
.BYTE 377, 377, 17, 17, 377, 377, 337, 337, 10, 10, 66, 46, 174, 74, 0, 3, 316, 336
.BYTE 160, 175, 10, 370, 0, 75, 300, 300, 377, 377, 17, 17, 377, 377, 337, 337, 14, 10
.BYTE 40, 40, 174, 174, 170, 172, 300, 334, 303, 373, 1, 375, 0, 371, 300, 301, 377, 377
.BYTE 17, 17, 377, 377, 217, 317, 177, 17, 40, 40, 4, 4, 370, 372, 100, 134, 203, 227
.BYTE 1, 335, 0, 343, 300, 303, 377, 377, 17, 17, 377, 377, 17, 117, 77, 57, 140, 144
.BYTE 4, 4, 360, 362, 0, 30, 6, 46, 17, 237, 0, 7, 300, 307, 377, 377, 17, 17
.BYTE 377, 377, 17, 117, 0, 0, 300, 334, 7, 7, 340, 342, 1, 30, 2, 46, 0, 37
.BYTE 0, 16, 300, 314, 377, 377, 17, 17, 377, 377, 217, 317, 3, 3, 200, 236, 37, 3
.BYTE 0, 6, 0, 30, 200, 304, 0, 37, 0, 14, 300, 300, 377, 377, 17, 17, 377, 377
.BYTE 317, 317, 17, 17, 0, 36, 0, 0, 0, 6, 300, 330, 1, 311, 0, 37, 200, 314
.BYTE 200, 201, 377, 377, 17, 17, 377, 377, 57, 57, 76, 34, 360, 377, 1, 1, 140, 142
.BYTE 200, 230, 3, 313, 0, 37, 0, 14, 200, 200, 377, 377, 17, 17, 377, 377, 57, 57
.BYTE 74, 74, 60, 77, 7, 7, 0, 2, 0, 30, 3, 303, 0, 37, 0, 14, 0, 0
.BYTE 377, 377, 17, 17, 377, 377, 57, 17, 64, 64, 20, 36, 16, 16, 0, 0, 0, 30
.BYTE 0, 300, 0, 37, 0, 10, 0, 0, 376, 376, 17, 17, 377, 377, 57, 57, 2, 0
.BYTE 23, 37, 16, 16, 20, 20, 0, 30, 0, 320, 0, 37, 0, 10, 0, 0, 376, 376
.BYTE 17, 17, 377, 377, 117, 117, 342, 342, 37, 37, 12, 2, 70, 70, 0, 0, 0, 320
.BYTE 0, 17, 0, 0, 0, 0, 376, 376, 17, 17, 377, 377, 237, 237, 67, 63, 37, 37
.BYTE 3, 2, 170, 170, 0, 0, 0, 360, 0, 17, 0, 0, 0, 0, 376, 376, 17, 17
.BYTE 377, 377, 37, 37, 30, 20, 376, 276, 1, 1, 0, 0, 300, 300, 0, 300, 0, 17
.BYTE 0, 0, 0, 0, 377, 377, 17, 17, 377, 377, 37, 37, 20, 20, 316, 316, 1, 1
.BYTE 0, 0, 300, 300, 1, 300, 0, 17, 0, 0, 0, 0, 377, 377, 17, 17, 377, 377
.BYTE 77, 77, 20, 23, 2, 0, 0, 0, 4, 0, 200, 200, 0, 300, 0, 7, 0, 0
.BYTE 0, 0, 377, 377, 17, 17, 377, 377, 77, 77, 60, 66, 2, 2, 0, 0, 0, 0
.BYTE 0, 0, 0, 300, 0, 7, 0, 0, 200, 200, 377, 377, 17, 17, 377, 377, 177, 177
.BYTE 340, 344, 17, 3, 0, 0, 0, 0, 40, 40, 0, 300, 0, 3, 0, 0, 200, 200
.BYTE 377, 377, 17, 17, 377, 377, 377, 377, 300, 300, 7, 1, 0, 0, 0, 0, 0, 0
.BYTE 0, 300, 0, 3, 0, 0, 200, 200, 377, 377, 17, 17, 377, 377, 377, 377, 1, 1
.BYTE 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 200, 200, 377, 377
.BYTE 17, 17, 377, 377, 377, 377, 3, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
.BYTE 0, 0, 0, 0, 200, 200, 377, 377, 17, 17, 377, 377, 377, 377, 77, 77, 0, 0
.BYTE 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 200, 200, 377, 377, 17, 17
.BYTE 377, 377, 377, 377, 377, 377, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
.BYTE 0, 0, 300, 300, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 37, 37, 0, 0
.BYTE 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 300, 300, 377, 377, 17, 17, 377, 377
.BYTE 377, 377, 377, 377, 177, 177, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
.BYTE 340, 340, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 1, 1, 0, 0
.BYTE 0, 0, 0, 0, 0, 0, 0, 0, 360, 360, 377, 377, 17, 17, 377, 377, 377, 377
.BYTE 377, 377, 377, 377, 37, 37, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 370, 374
.BYTE 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 37, 37, 0, 0, 0, 0
.BYTE 0, 0, 0, 0, 0, 0, 376, 376, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377
.BYTE 377, 377, 37, 37, 0, 0, 0, 0, 0, 0, 40, 40, 0, 0, 376, 376, 377, 377
.BYTE 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 37, 37, 0, 0, 0, 0, 0, 0
.BYTE 60, 60, 0, 0, 376, 376, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377
.BYTE 37, 37, 0, 0, 0, 0, 0, 0, 60, 60, 6, 0, 376, 376, 377, 377, 17, 17
.BYTE 377, 377, 377, 377, 377, 377, 377, 377, 37, 37, 0, 0, 0, 0, 0, 0, 40, 40
.BYTE 0, 0, 376, 376, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 37, 137
.BYTE 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 376, 376, 377, 377, 17, 17, 377, 377
.BYTE 377, 377, 377, 377, 377, 377, 237, 337, 0, 1, 0, 0, 0, 0, 0, 0, 60, 0
.BYTE 376, 376, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 37, 337, 16, 17
.BYTE 0, 0, 0, 0, 0, 0, 40, 0, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377
.BYTE 377, 377, 377, 377, 37, 337, 360, 377, 1, 7, 0, 0, 0, 0, 0, 0, 377, 377
.BYTE 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 37, 337, 0, 377, 14, 17
.BYTE 0, 0, 0, 0, 214, 200, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377
.BYTE 377, 377, 37, 237, 0, 377, 0, 17, 0, 0, 0, 0, 210, 200, 377, 377, 377, 377
.BYTE 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 37, 37, 0, 376, 0, 17, 0, 0
.BYTE 0, 0, 200, 200, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377
.BYTE 77, 77, 0, 340, 0, 17, 0, 0, 0, 0, 300, 300, 377, 377, 377, 377, 17, 17
.BYTE 377, 377, 377, 377, 377, 377, 377, 377, 177, 177, 0, 0, 0, 0, 0, 0, 0, 0
.BYTE 341, 340, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377
.BYTE 0, 0, 0, 0, 0, 0, 0, 0, 360, 360, 377, 377, 377, 377, 17, 17, 377, 377
.BYTE 377, 377, 217, 217, 7, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 370, 370
.BYTE 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 43, 43, 340, 340, 177, 177, 0, 0
.BYTE 0, 0, 0, 0, 0, 0, 374, 374, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377
.BYTE 173, 173, 376, 376, 377, 377, 0, 0, 0, 0, 0, 0, 0, 0, 360, 360, 377, 377
.BYTE 377, 377, 17, 17, 377, 377, 377, 377, 173, 173, 16, 36, 300, 300, 6, 6, 0, 0
.BYTE 160, 160, 0, 0, 0, 0, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 170, 170
.BYTE 0, 0, 100, 0, 3, 7, 0, 0, 20, 0, 0, 0, 60, 20, 377, 377, 377, 377
.BYTE 17, 17, 377, 377, 77, 77, 36, 36, 0, 0, 0, 200, 3, 3, 3, 3, 70, 10
.BYTE 0, 0, 130, 30, 377, 377, 377, 377, 17, 17, 377, 377, 237, 237, 17, 17, 0, 0
.BYTE 200, 200, 1, 1, 3, 3, 20, 0, 0, 0, 70, 50, 376, 376, 377, 377, 17, 17
.BYTE 377, 377, 303, 303, 3, 1, 0, 0, 300, 300, 0, 1, 0, 0, 0, 0, 0, 0
.BYTE 74, 54, 374, 374, 377, 377, 17, 17, 177, 177, 374, 374, 200, 0, 0, 200, 301, 303
.BYTE 0, 1, 0, 0, 4, 0, 0, 1, 74, 14, 370, 370, 377, 377, 17, 17, 37, 37
.BYTE 177, 177, 140, 0, 370, 370, 361, 363, 1, 0, 0, 0, 200, 200, 17, 17, 34, 24
.BYTE 341, 340, 377, 377, 17, 17, 237, 237, 377, 377, 7, 7, 374, 374, 171, 171, 200, 0
.BYTE 3, 0, 220, 200, 77, 77, 234, 200, 203, 201, 377, 377, 17, 17, 337, 337, 377, 377
.BYTE 77, 77, 376, 376, 175, 75, 214, 200, 377, 160, 237, 236, 377, 377, 0, 0, 0, 0
.BYTE 376, 376, 17, 17, 337, 337, 377, 377, 77, 77, 376, 376, 375, 375, 211, 201, 377, 1
.BYTE 37, 4, 376, 376, 174, 174, 370, 370, 374, 374, 17, 17, 377, 377, 77, 77, 160, 100
.BYTE 376, 376, 374, 374, 203, 3, 377, 137, 17, 4, 174, 174, 376, 376, 377, 377, 370, 370
.BYTE 17, 17, 337, 337, 77, 77, 170, 100, 376, 376, 374, 374, 7, 7, 374, 0, 3, 0
.BYTE 174, 174, 377, 377, 177, 177, 370, 370, 17, 17, 337, 337, 37, 37, 170, 50, 74, 74
.BYTE 174, 74, 17, 17, 0, 0, 200, 200, 177, 177, 377, 377, 207, 3, 371, 371, 17, 17
.BYTE 237, 237, 37, 37, 170, 70, 14, 14, 74, 70, 16, 16, 0, 0, 374, 374, 177, 177
.BYTE 376, 376, 203, 203, 361, 361, 17, 17, 77, 77, 36, 36, 30, 0, 340, 340, 77, 77
.BYTE 4, 4, 374, 376, 377, 377, 377, 377, 376, 376, 203, 3, 301, 301, 17, 17, 177, 177
.BYTE 0, 0, 0, 0, 360, 360, 77, 77, 0, 0, 374, 374, 377, 377, 377, 377, 376, 376
.BYTE 203, 3, 301, 300, 17, 17, 377, 377, 0, 0, 200, 200, 371, 371, 77, 77, 300, 300
.BYTE 374, 374, 377, 377, 377, 377, 374, 374, 3, 3, 300, 300, 17, 17, 377, 377, 377, 377
.BYTE 377, 377, 371, 371, 77, 77, 370, 370, 375, 375, 377, 377, 377, 377, 341, 341, 3, 3
.BYTE 360, 360, 17, 17, 377, 377, 377, 377, 377, 377, 373, 373, 77, 77, 377, 376, 371, 371
.BYTE 377, 377, 377, 377, 3, 3, 0, 0, 376, 376, 17, 17, 377, 377, 377, 377, 377, 377
.BYTE 377, 377, 377, 377, 377, 377, 370, 370, 377, 377, 377, 377, 37, 37, 300, 300, 377, 377
.BYTE 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 177, 177, 370, 370, 377, 377
.BYTE 377, 377, 377, 377, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 373, 373
.BYTE 377, 377, 237, 37, 370, 370, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 17, 17
.BYTE 377, 377, 377, 377, 377, 377, 371, 371, 377, 377, 303, 303, 1, 0, 376, 376, 377, 377
.BYTE 377, 377, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 371, 371, 77, 77
.BYTE 360, 240, 0, 0, 376, 376, 377, 377, 377, 377, 377, 377, 377, 377, 17, 17, 377, 377
.BYTE 377, 377, 377, 377, 371, 371, 77, 77, 360, 40, 0, 0, 376, 376, 377, 377, 377, 377
.BYTE 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 363, 363, 77, 77, 160, 140
.BYTE 0, 0, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377
.BYTE 377, 377, 303, 303, 77, 77, 60, 0, 200, 200, 377, 377, 377, 377, 377, 377, 377, 377
.BYTE 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 7, 7, 76, 76, 0, 0, 360, 360
.BYTE 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377
.BYTE 37, 37, 0, 0, 0, 0, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377
.BYTE 17, 17, 377, 377, 377, 377, 377, 377, 377, 377, 3, 3, 360, 360, 377, 377, 377, 377
.BYTE 377, 377, 377, 377, 377, 377, 377, 377, 17, 17, 377, 377, 377, 377, 377, 377, 377, 377
.BYTE 77, 77, 374, 374, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 377, 17, 17
