Вложений: 1
вот третья кассета, обновил файлы.
замени вложения.
третья и четвёртая кассеты вообще класс столько моих любимых игр:
swat, alley cat, dropzone.
space dungeon, spark bugs и fire chief - вообще шикарно.
atariki, а можешь записать ту кассету где у тебя Oils well, pole position, panther ?
у меня обложки давно сохранены, ты их ещё несколько лет назад выкладывал.
Вложений: 1
это мой новодел, делал для себя. Кассету я "забраковал", но скину то, что на ней есть, без проблем.
всё переписано с этих же кассет.
Вложений: 1
http://www.virtualdub.org/beta/Altirra-2.99-test20.zip
20ый бета выпуск эмулятора.
полный список изменений:
Current prerelease version:
changes
Devices: Internal device tree storage has changed. Device trees may need to be remade.
Input: Added detection and button naming for DualShock 4 controllers.
VBXE: VideoBoard XE configuration has been moved from the menu to a device entry.
features added
Cassette: Added initial support for turbo tape decoding.
Cassette: Mounted tape is now persisted along with other mounted images.
Cassette: %-age position is now shown on HUD.
Cassette: Improved FSK decoder.
Cassette: Added analysis tool to compare raw signal against FSK and turbo decoder outputs.
Cassette: Added option to export decoded tape back out as audio.
Debugger: History pane now has a more powerful loop detector that can handle larger loops and call/loop nesting.
Debugger: History pane can now label each instruction with tape position.
Debugger: .tapedata command now accepts position by sample (-s).
Debugger: Added bsc command to change condition on a breakpoint.
Debugger: Undocumented store and read/modify/write instructions are now shown with write symbols rather than read symbols.
Debugger: Extended .pia command output.
Debugger: .basic_dumpline now supports reading program text from extended memory.
Debugger: ~ (target info) command displays coprocessor types and speeds.
Debugger: Added support for per-instruction breakpoints.
Debugger: u (unassemble) command now has switches to track 65C816 M/X/E state.
Debugger: Memory access breakpoints are now supported in banks $01-FF.
Debugger: added bta (set tracepoint on memory access) command.
Debugger: db/dw/dsb/dsw/dsd expression operators now accept 24-bit addresses.
Debugger: Symbols can now be present above bank 0.
Devices: Added browser device (B:).
Devices: Added feature to IDEPlus 2.0 to guard against NVRAM corruption on reset during clock reads.
Devices: Added XEL-CF adapter emulation.
Devices: Added Rapidus Accelerator emulation.
Devices: An automatic reboot is now requested before adding or removing devices that practically require one.
Disk: ATX images are now saved with a unique creator code.
Disk: Added support for ATX images with MFM tracks.
PCLink: Added option to use creation timestamps passed in commands.
SCSI: Fast/slow block storage speed is now implemented on SCSI buses.
UI: Added support for per-monitor V2 DPI awareness in Windows 10 Creator's Update.
VBXE: Added option to emulate FX1.24 or FX1.26 behavior.
VBXE: Overlay collision detection is now implemented.
VBXE: Improved blitter timing precision to sub-scanline.
bugs fixed
AltirraOS: Fixed polarity of CKEY flag.
ATBasic: Added compatibility workaround for programs that use locations 183 and 184 to read the current DATA line.
Cartridge: Fixed error when loading untagged cartridge from drag-and-drop stream source.
Cheats: Fixed sorting issues in active list.
CPU: Fixed 65C816 being reverted to emulation mode when changing CPU speed dynamically.
CPU: Interrupts in 65C816 emulation mode now force K=0.
CPU: Fix incorrect extra cycle for opcode $04 (NOP zp).
Debugger: Disassembly window now scrolls properly above bank 0.
Debugger: Improved breakpoint and stepping behavior with coprocessors.
Debugger: Fixed incorrect execution history timings for Percom disk drives.
Debugger: Fixed crash when toggling breakpoints through UI on top of hidden break/tracepoints from loaded symbols.
Debugger: Fixed crash with certain command alias patterns using wildcards.
Devices: Fixed IDEPlus 2.0 to have internal SDX at higher priority than external cart.
Disk: Tightened validation when mounting MyDOS filesystems.
Disk: Fixed crash when expanding archives in filesystems with empty directories.
Display: Improved display recovery when secondary monitors are turned on or off.
Display: Added workaround for breaking change in Windows 10 build 1709 that caused D3D9 exclusive fullscreen mode to not render.
IDE: Serial number field in identify command data is now padded with spaces.
PCLink: Directory search operations now return creation time instead of last write time.
POKEY: Serial output data is now truncated when the output clock is stopped.
POKEY: Fixed keys not being immediately recognized in raw mode when exiting init mode.
UI: Fixed /type not working on cold boot.
UI: Fix garbage when pasting text copied from WordPad.
VBXE: Attribute map is now constrained to 43 cells rather than a lower limit of 8 pixels horizontally.
VBXE: Added emulation of color 0 bug in GR.11 in FX1.24 core.
VBXE: Blit pattern width field is now 6 bits instead of 7.
VBXE: Overlay priority is reset to $FF at top of XDL.
5ая кассета готова.
Можешь попросить Avery Lee чтобы в эмуляторе когда например я загрузил загрузчик Turbo 2000 и добавляю вавник, чтобы не скидывалось, т.е чтобы эмулятор не перезагружался а просто добавлял образ кассеты.
Или наоборот, вавник загружен, гружу *.xex файл чтобы не скидывало из буфера вавник.
так он так и делает.
вначале открывай загрузчик, например T2000 loader.xex.
затем в меню file --->cassette --->load
открываешь wav файл.
и всё.
можно ещё tape control открыть для удобства.
второй вариант не выйдет сделать.
хех файлы - это голая программа, её ещё можно со снимком памяти сравнить.
хех файл грузится сразу в память компа, и он автоматически выполняется.
вот именно, постоянно перезагружать вавник, было бы проще если бы он там висел после загрузки xex файла.
хорошо, я попрошу автора добавить такое в эмулятор.
нифига не пойму.
с шестой кассеты со стороны А распозналось всё кроме трёх последних игр.
а вот сторона Б почему-то чудит, игры там распознались все, но ни одна из них не хочет работать в эмуляторе. или синий экран висит или крах эмулятора.
там на второй стороне загрузчик Auto Turbo
