вот что получилось после перепрошивки боoт:
Speccy2010 boot ver 1.2(extra log for Ricia)!
SD card init error :(
Jumping to MainProg.
SD card init OK..
Started comparing.
Found difference - at pos =620, value on card = 210, value in flash = 255
Firmware upgrade started.
SD card init OK..
Started comparing.
Found difference - at pos =507, value on card = 225, value in flash = 193
.............................Firmware upgrade finished.
SD card init OK..
Started comparing.
Found difference - at pos =987, value on card = 229, value in flash = 197
SD card init OK..
Started comparing.
Found difference - at pos =815, value on card = 227, value in flash = 195
SD card init OK..
Started comparing.
Found difference - at pos =179, value on card = 229, value in flash = 197
SD card init OK..
Started comparing.
Found difference - at pos =427, value on card = 228, value in flash = 196
SD card init OK..
Started comparing.
Found difference - at pos =175, value on card = 229, value in flash = 197
SD card init OK..
Started comparing.
Found difference - at pos =1207, value on card = 52, value in flash = 20
