Shockwav3, I have a 3.5 "drive, and everything is fine loading. The image is unfolded winimage
I don't have a windows PC anymore with a floppy drive.
I'm using the image by velesoft + rawrite3 from FreeDOS on my 486 machine.
Shockwav3, try to check fdd cable. you must use zx spectrum like cable, not as for PC with inverted lines!
what the OS you use on your PC? MAC OS or Linux? you can try to manually format fdd (FAT12, 1.44mb size) and then use "dd" command for write image.
Он же написал, что у него нет писюка с флоппарем.
FDD cable is fine, it's a 1:1 cable that I usually use with my Pentagon48.
I'm quite sure the image is fine ... I can see the files like with any FAT12 floppy on my MSDOS machine.
I've tried extracting the files from the image and copying them over manually (and setting the file attributes manually), no improvement. My current guess is that the VG93 controllers are having an issue with the HD mode.
Мак с дисководом?:-) Только, если прошлого тысячелетия.
Same issue with the MB8877.
The sprinter detects the bootdisk, the disk drive then steps maybe 4-5 times and then hangs :(
Now installing Windows98 on my 486 so I can use the included image program with the bootdisk image.
Booting worked :) Seems like my HD floppies were bad.
Booting from HDD also works now.
Where do I need to put the ZX ROMs? And which ones does I need? I've read that TRDOS has a special Sprinter Version?
images in the standard trd, before launch you need to run the configurator spectrum
Отправлено с моего M2 Note через Tapatalk
